I am using this code from Robjax for a 4 button/relay controller for a sprinkler. I would like to have a fail-safe timer (say, 25 minutes) in case the button does not get pushed to turn off the relay. Or, in maybe a timer begins when the relay makes, and the button can be used to turn it off before it times out. Any help will be appreciated. I will be tinkering with it myself in the meantime.
Arduino code to push-ON and push-OFF 4 relays
when button pushed, relay ON and stay ON
push again to make it OFF and stay OFF
this can be done with 4 push button to control 4 relays.
written by Ahmad Shamshiri for Robojax. com
on December 11, 2018 at 19:39 in Ajax, Ontario, Canada
This code is "AS IS" without warranty or liability. Free to be used as long as you keep this note intact.*
This code has been download from Robojax .com
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
const int pushButton[] ={2,3,4,5};// define push button inputs
const int relayPin[]={11,10,9,8};// output pins where 4 relays will be connected
String relayNames[] ={"CH1", "CH2","CH3","CH4"};// Just put name for 4 relays
int pushed[] ={0,0,0,0};// status of each buttons
int relayStatus[] ={HIGH,HIGH,HIGH,HIGH};// initial status of relay
// Robojax.com 4-Relay-4-Push button 20181211
Serial.begin(9600);// initialize serial monitor
for(int i=0; i<4; i++)
pinMode(pushButton[i], INPUT_PULLUP);
pinMode(relayPin[i], OUTPUT);
digitalWrite(relayPin[i], HIGH);// initial relay status to be OFF
// Robojax . com 4-Relay-4-Push button 20181211
int val = digitalRead(pushButton[i]);
if(val == HIGH && relayStatus[i] == LOW){
pushed[i] = 1-pushed[i];
delay(100);
}// if
relayStatus[i] = val;
if(pushed[i] == HIGH){
Serial.print(relayNames[i]);
Serial.println(" ON");
digitalWrite(relayPin[i], LOW);
}else{
Serial.println(" OFF");
}// else
}// for
Serial.println("==");
delay(100);
// Robojax. com 4-Relay-4-Push button 20181211
}// loop end
