Adding Information about traps with the function maps
Hi Arduino-Website-Maintenance-Team,
the map()-function screws up values if you use "bad" parameters.
In the section notes & warnings you should add this information
with a compilable example-code that demonstrates what happens.
if you try to use map in this wrong way
unsigned long rawToBeMapped = 1000000;
unsigned int mappedValue;
  mappedValue = map(rawToBeMapped, 123, 255, 0, 1023);
best regards Stefan
This is a programming error to use unsuitable types; The map function has nothing to do with it.
if I run
  Serial.println(map(rawToBeMapped, 123, 255, 0, 1023));
  Serial.println(mappedValue);
void loop() {}
I get 7749046 and 15798 which seems right to me.
and if you print the hex values
  Serial.begin(115200);Serial.println();
  Serial.println(map(rawToBeMapped, 123, 255, 0, 1023), HEX);
  Serial.println(mappedValue, HEX);
void loop() {}
you get 763DB6 and 3DB6 which shows what the compiler did, truncating the unsigned long's 4 bytes into the 2 LSB as per the C++ standard.
did I miss something?
the reason suggesting this is this thread
user jim81 gets negative values as the result of the map-function
best regards Stefan
The thread is long.
A negative value is a possible mapped value, there is nothing wrong with that.
Can you qualify if the negative value was
1/ a consequence of storing the result in a wrongly typed variable?
2/ a consequence of not understanding that map does not constrain its result?
3/ something else?
I'm unclear about the issue you are trying to nail
1 is a programming mistake. Often the compiler will issue a warning.
2. is already documented in the arduino doc
3 ?
see post in this thread
