Hello,
I am totally new to this world and I am doing my first experiments with Arduino DUE.
I am using Ubuntu and I need to use <Scheduler.h>.
I found a library but It did not work:
In file included from sketch_jan22a.ino:1:0:
/usr/share/arduino/libraries/Scheduler/Scheduler.h: In static member function ‘static void SchedulerClass::yield()’:
/usr/share/arduino/libraries/Scheduler/Scheduler.h:34:24: error: ‘::yield’ has not been declared
static void yield() { ::yield(); };
sketch_jan22a.ino: In function ‘void loop2()’:
sketch_jan22a.ino:30:8: error: ‘yield’ was not declared in this scope
I don't know if I am using the right lib ... I had also to copy it manually to proper folder because adding library from IDE is hanging my Ubuntu Linux and I have to Kill process.
Where are the right libraries to use with Arduino DUE? I can easy find the reference page, but I am not sure if I am downloading the right ZIP file.
I am a lot confused. At first I had to replace "Wprogram.h" to "Arduino.h", but then I found another library (this one I am using now) but I am having errors referred to yield!
Sorry! ![]()
Thanks for your help!
