Hi there,
I'm trying to figure out how to add polyphony i.e. eight voices to the following code for a monophonic MIDI-to-CV Converter:
#include <MIDI.h>
#include <SPI.h>
// Note priority is set by pins A0 and A2
// Highest note priority: A0 and A2 high (open)
// Lowest note priority: A0 low (ground), A2 high (open)
// Last note priority: A2 low (ground)
#define NP_SEL1 A0 // Note priority is set by pins A0 and A2
#define NP_SEL2 A2
#define GATE 2
#define TRIG 3
#define CLOCK 4
#define DAC1 8
#define DAC2 9
MIDI_CREATE_DEFAULT_INSTANCE();
pinMode(NP_SEL1, INPUT_PULLUP);
pinMode(NP_SEL2, INPUT_PULLUP);
pinMode(GATE, OUTPUT);
pinMode(TRIG, OUTPUT);
pinMode(CLOCK, OUTPUT);
pinMode(DAC1, OUTPUT);
pinMode(DAC2, OUTPUT);
digitalWrite(GATE,LOW);
digitalWrite(TRIG,LOW);
digitalWrite(CLOCK,LOW);
digitalWrite(DAC1,HIGH);
digitalWrite(DAC2,HIGH);
SPI.begin();
MIDI.begin(MIDI_CHANNEL_OMNI);
// Set initial pitch bend voltage to 0.5V (mid point). With Gain = 1X, this is 1023
// Other DAC outputs will come up as 0V, so don't need to be initialized
setVoltage(DAC2, 0, 0, 1023);
bool notes[88] = {0};
int8_t noteOrder[20] = {0}, orderIndx = {0};
unsigned long trigTimer = 0;
int type, noteMsg, velocity, channel, d1, d2;
static unsigned long clock_timer=0, clock_timeout=0;
static unsigned int clock_count=0;
bool S1, S2;
if ((trigTimer > 0) && (millis() - trigTimer > 20)) {
digitalWrite(TRIG,LOW); // Set trigger low after 20 msec
trigTimer = 0;
if ((clock_timer > 0) && (millis() - clock_timer > 20)) {
digitalWrite(CLOCK,LOW); // Set clock pulse low after 20 msec
clock_timer = 0;
if (MIDI.read()) {
byte type = MIDI.getType();
switch (type) {
case midi::NoteOn:
case midi::NoteOff:
noteMsg = MIDI.getData1() - 21; // A0 = 21, Top Note = 108
channel = MIDI.getChannel();
if ((noteMsg < 0) || (noteMsg > 87)) break; // Only 88 notes of keyboard are supported
if (type == midi::NoteOn) velocity = MIDI.getData2();
else velocity = 0;
if (velocity == 0) {
notes[noteMsg] = false;
else {
notes[noteMsg] = true;
// velocity range from 0 to 4095 mV Left shift d2 by 5 to scale from 0 to 4095,
// and choose gain = 2X
setVoltage(DAC1, 1, 1, velocity<<5); // DAC1, channel 1, gain = 2X
// Pins NP_SEL1 and NP_SEL2 indictate note priority
S1 = digitalRead(NP_SEL1);
S2 = digitalRead(NP_SEL2);
if (S1 && S2) { // Highest note priority
commandTopNote();
else if (!S1 && S2) { // Lowest note priority
commandBottomNote();
else { // Last note priority
if (notes[noteMsg]) { // If note is on and using last note priority, add to ordered list
orderIndx = (orderIndx+1) % 20;
noteOrder[orderIndx] = noteMsg;
commandLastNote();
case midi::PitchBend:
d1 = MIDI.getData1();
d2 = MIDI.getData2(); // d2 from 0 to 127, mid point = 64
// Pitch bend output from 0 to 1023 mV. Left shift d2 by 4 to scale from 0 to 2047.
// With DAC gain = 1X, this will yield a range from 0 to 1023 mV.
setVoltage(DAC2, 0, 0, d2<<4); // DAC2, channel 0, gain = 1X
case midi::ControlChange:
d2 = MIDI.getData2(); // From 0 to 127
// CC range from 0 to 4095 mV Left shift d2 by 5 to scale from 0 to 4095,
setVoltage(DAC2, 1, 1, d2<<5); // DAC2, channel 1, gain = 2X
case midi::Clock:
if (millis() > clock_timeout + 300) clock_count = 0; // Prevents Clock from starting in between quarter notes after clock is restarted!
clock_timeout = millis();
if (clock_count == 0) {
digitalWrite(CLOCK,HIGH); // Start clock pulse
clock_timer=millis();
clock_count++;
if (clock_count == 24) { // MIDI timing clock sends 24 pulses per quarter note. Sent pulse only once every 24 pulses
clock_count = 0;
case midi::ActiveSensing:
default:
void commandTopNote()
int topNote = 0;
bool noteActive = false;
for (int i=0; i<88; i++)
if (notes[i]) {
topNote = i;
noteActive = true;
if (noteActive)
commandNote(topNote);
else // All notes are off, turn off gate
void commandBottomNote()
int bottomNote = 0;
for (int i=87; i>=0; i--)
if (notes[i]) {
bottomNote = i;
noteActive = true;
if (noteActive)
commandNote(bottomNote);
void commandLastNote()
int8_t noteIndx;
for (int i=0; i<20; i++) {
noteIndx = noteOrder[ mod(orderIndx-i, 20) ];
if (notes[noteIndx]) {
commandNote(noteIndx);
return;
digitalWrite(GATE,LOW); // All notes are off
// Rescale 88 notes to 4096 mV:
// noteMsg = 0 -> 0 mV
// noteMsg = 87 -> 4096 mV
// DAC output will be (4095/87) = 47.069 mV per note, and 564.9655 mV per octive
// Note that DAC output will need to be amplified by 1.77X for the standard 1V/octave
#define NOTE_SF 47.069f // This value can be tuned if CV output isn't exactly 1V/octave
void commandNote(int noteMsg) {
digitalWrite(GATE,HIGH);
digitalWrite(TRIG,HIGH);
trigTimer = millis();
unsigned int mV = (unsigned int) ((float) noteMsg * NOTE_SF + 0.5);
setVoltage(DAC1, 0, 1, mV); // DAC1, channel 0, gain = 2X
// setVoltage -- Set DAC voltage output
// dacpin: chip select pin for DAC. Note and velocity on DAC1, pitch bend and CC on DAC2
// channel: 0 (A) or 1 (B). Note and pitch bend on 0, velocity and CC on 2.
// gain: 0 = 1X, 1 = 2X.
// mV: integer 0 to 4095. If gain is 1X, mV is in units of half mV (i.e., 0 to 2048 mV).
// If gain is 2X, mV is in units of mV
void setVoltage(int dacpin, bool channel, bool gain, unsigned int mV)
unsigned int command = channel ? 0x9000 : 0x1000;
command |= gain ? 0x0000 : 0x2000;
command |= (mV & 0x0FFF);
SPI.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
digitalWrite(dacpin,LOW);
SPI.transfer(command>>8);
SPI.transfer(command&0xFF);
digitalWrite(dacpin,HIGH);
SPI.endTransaction();
int mod(int a, int b)
int r = a % b;
return r < 0 ? r + b : r;
Would anyone be able to kindly advise on how to go about doing so in the simplest way possible?
Many thanks,
Chris
