So my plan is to add onto the work of Samy Kamkar. He created a device called the MagSpoof that would emulate a mag-stripe card at point of sale system. I would like to have more than one card stored on the device I have added more input pins and set their pin mode and set new char values but I'm not that familiar with C. In the void loop section I am trying to make a pin set low to change the char value of tracks[] . Any help or ideas help .
* MagSpoof - "wireless" magnetic stripe/credit card emulator
* by Samy Kamkar
* http://samy.pl/magspoof/
* - Allows you to store all of your credit cards and magstripes in one device
* - Works on traditional magstripe readers wirelessly (no NFC/RFID required)
* - Can disable Chip-and-PIN (code not included)
* - Correctly predicts Amex credit card numbers + expirations from previous card number (code not included)
* - Supports all three magnetic stripe tracks, and even supports Track 1+2 simultaneously
* - Easy to build using Arduino or ATtiny
#include <avr/sleep.h>
#include <avr/interrupt.h>
#define PIN_A 0
#define PIN_B 1
#define ENABLE_PIN 3 // also green LED
#define SWAP_PIN 4 // unused
#define BUTTON_PIN 2 // Send Tracks
#define CLOCK_US 200
#define BETWEEN_ZERO 53 // 53 zeros between track1 & 2
#define TRACKS 2
/*New Varables*/
#define PINCARD1 8
#define PINCARD2 9
#define PINCARD3 10
// consts get stored in flash as we don't adjust them
const char* CARD1[] =
"%Card1^LASTNAME/FIRST^YYMMSSSDDDDDDDDDDDDDDDDDDDDDDDDD?\0", // Track 1
";123456781234567=YYMMSSSDDDDDDDDDDDDDD?\0" // Track 2
const char* CARD2[] =
"%Card2^LASTNAME/FIRST^YYMMSSSDDDDDDDDDDDDDDDDDDDDDDDDD?\0", // Track 1
const char* CARD3[] =
"%Card3^LASTNAME/FIRST^YYMMSSSDDDDDDDDDDDDDDDDDDDDDDDDD?\0", // Track 1
const char* tracks[] =
"%B123456781234567^LASTNAME/FIRST^YYMMSSSDDDDDDDDDDDDDDDDDDDDDDDDD?\0", // Track 1
char revTrack[41];
const int sublen[] = {
32, 48, 48 };
const int bitlen[] = {
7, 5, 5 };
unsigned int curTrack = 0;
int dir;
pinMode(PIN_A, OUTPUT);
pinMode(PIN_B, OUTPUT);
pinMode(ENABLE_PIN, OUTPUT);
pinMode(BUTTON_PIN, INPUT_PULLUP);
pinMode(PINCARD1, INPUT_PULLUP);
pinMode(PINCARD2, INPUT_PULLUP);
pinMode(PINCARD3, INPUT_PULLUP);
// blink to show we started up
blink(ENABLE_PIN, 200, 3);
// store reverse track 2 to play later
storeRevTrack(2);
void blink(int pin, int msdelay, int times)
for (int i = 0; i < times; i++)
digitalWrite(pin, HIGH);
delay(msdelay);
digitalWrite(pin, LOW);
delay(msdelay);
// send a single bit out
void playBit(int sendBit)
dir ^= 1;
digitalWrite(PIN_A, dir);
digitalWrite(PIN_B, !dir);
delayMicroseconds(CLOCK_US);
if (sendBit)
dir ^= 1;
// when reversing
void reverseTrack(int track)
int i = 0;
track--; // index 0
dir = 0;
while (revTrack[i++] != '\0');
i--;
while (i--)
for (int j = bitlen[track]-1; j >= 0; j--)
playBit((revTrack[i] >> j) & 1);
// plays out a full track, calculating CRCs and LRC
void playTrack(int track)
int tmp, crc, lrc = 0;
track--; // index 0
dir = 0;
// enable H-bridge and LED
digitalWrite(ENABLE_PIN, HIGH);
// First put out a bunch of leading zeros.
for (int i = 0; i < 25; i++)
playBit(0);
for (int i = 0; tracks[track][i] != '\0'; i++)
crc = 1;
tmp = tracks[track][i] - sublen[track];
for (int j = 0; j < bitlen[track]-1; j++)
crc ^= tmp & 1;
lrc ^= (tmp & 1) << j;
playBit(tmp & 1);
tmp >>= 1;
playBit(crc);
// finish calculating and send last "byte" (LRC)
tmp = lrc;
crc = 1;
crc ^= tmp & 1;
playBit(tmp & 1);
tmp >>= 1;
playBit(crc);
// if track 1, play 2nd track in reverse (like swiping back?)
if (track == 0)
// if track 1, also play track 2 in reverse
// zeros in between
for (int i = 0; i < BETWEEN_ZERO; i++)
playBit(0);
// send second track in reverse
reverseTrack(2);
// finish with 0's
for (int i = 0; i < 5 * 5; i++)
playBit(0);
digitalWrite(PIN_A, LOW);
digitalWrite(PIN_B, LOW);
digitalWrite(ENABLE_PIN, LOW);
// stores track for reverse usage later
void storeRevTrack(int track)
int i, tmp, crc, lrc = 0;
track--; // index 0
dir = 0;
for (i = 0; tracks[track][i] != '\0'; i++)
crc = 1;
crc ^= tmp & 1;
tmp & 1 ?
(revTrack[i] |= 1 << j) :
(revTrack[i] &= ~(1 << j));
tmp >>= 1;
crc ?
(revTrack[i] |= 1 << 4) :
(revTrack[i] &= ~(1 << 4));
tmp = lrc;
crc = 1;
crc ^= tmp & 1;
tmp & 1 ?
tmp >>= 1;
crc ?
i++;
revTrack[i] = '\0';
void sleep()
GIMSK |= _BV(PCIE); // Enable Pin Change Interrupts
PCMSK |= _BV(PCINT2); // Use PB3 as interrupt pin
ADCSRA &= ~_BV(ADEN); // ADC off
set_sleep_mode(SLEEP_MODE_PWR_DOWN); // replaces above statement
MCUCR &= ~_BV(ISC01);
MCUCR &= ~_BV(ISC00); // Interrupt on rising edge
sleep_enable(); // Sets the Sleep Enable bit in the MCUCR Register (SE BIT)
sei(); // Enable interrupts
sleep_cpu(); // sleep
cli(); // Disable interrupts
PCMSK &= ~_BV(PCINT2); // Turn off PB3 as interrupt pin
sleep_disable(); // Clear SE bit
ADCSRA |= _BV(ADEN); // ADC on
// XXX move playtrack in here?
ISR(PCINT0_vect) {
/* noInterrupts();
while (digitalRead(BUTTON_PIN) == LOW);
delay(50);
playTrack(1 + (curTrack++ % 2));
delay(400);
interrupts();*/
#define tracks[]
if (PINCARD1, LOW)
tracks[] = CARD1;
if (PINCARD2, LOW)
tracks [] = CARD2;
if (PINCARD3, LOW)
tracks[] = CARD3;
//for(int i=0;i<10;i++){playTrack(1+(curTrack++%2));delay(3000);}
sleep();
noInterrupts();
delay(50);
delay(400);
interrupts();
//playTrack(1 + (curTrack++ % 2));
The original code is at:
