Hello guys,
I recently developed my own board with an ATMEGA2560 it runs at 22.1184MHz nice and stable.
I get everything to work except the RGBW pixel(s) I use. Now I found a solution which works for 20MHz but it most definitely doesn't work for 22.11184 MHz. Now I want to put a piece of coding in the library which is for the specific CPU speed. In the next post will be the code from the library which are for the cpu speeds.
Unfortunately my C programming and assembly is not so good that i know how to adjust this for a new speed as 22.1184MHz. Can somebody help me to make either adjustments or add this new speed?
#elif (F_CPU >= 15400000UL) && (F_CPU <= 19000000L)
#ifdef NEO_KHZ400 // 800 KHz check needed only if 400 KHz support enabled
if(is800KHz) {
#endif
// WS2811 and WS2812 have different hi/lo duty cycles; this is
// similar but NOT an exact copy of the prior 400-on-8 code.
// 20 inst. clocks per bit: HHHHHxxxxxxxxLLLLLLL
// ST instructions: ^ ^ ^ (T=0,5,13)
volatile uint8_t next, bit;
hi = *port | pinMask;
lo = *port & ~pinMask;
next = lo;
bit = 8;
asm volatile(
"head20:" "\n\t" // Clk Pseudocode (T = 0)
"st %a[port], %[hi]" "\n\t" // 2 PORT = hi (T = 2)
"sbrc %[byte], 7" "\n\t" // 1-2 if(b & 128)
"mov %[next], %[hi]" "\n\t" // 0-1 next = hi (T = 4)
"dec %[bit]" "\n\t" // 1 bit-- (T = 5)
"st %a[port], %[next]" "\n\t" // 2 PORT = next (T = 7)
"mov %[next] , %[lo]" "\n\t" // 1 next = lo (T = 8)
"breq nextbyte20" "\n\t" // 1-2 if(bit == 0) (from dec above)
"rol %[byte]" "\n\t" // 1 b <<= 1 (T = 10)
"rjmp .+0" "\n\t" // 2 nop nop (T = 12)
"nop" "\n\t" // 1 nop (T = 13)
"st %a[port], %[lo]" "\n\t" // 2 PORT = lo (T = 15)
"nop" "\n\t" // 1 nop (T = 16)
"rjmp .+0" "\n\t" // 2 nop nop (T = 18)
"rjmp head20" "\n\t" // 2 -> head20 (next bit out)
"nextbyte20:" "\n\t" // (T = 10)
"ldi %[bit] , 8" "\n\t" // 1 bit = 8 (T = 11)
"ld %[byte] , %a[ptr]+" "\n\t" // 2 b = *ptr++ (T = 13)
"sbiw %[count], 1" "\n\t" // 2 i-- (T = 18)
"brne head20" "\n" // 2 if(i != 0) -> (next byte)
: [port] "+e" (port),
[byte] "+r" (b),
[bit] "+r" (bit),
[next] "+r" (next),
[count] "+w" (i)
: [ptr] "e" (ptr),
[hi] "r" (hi),
[lo] "r" (lo));
#ifdef NEO_KHZ400
} else { // 400 KHz
// The 400 KHz clock on 16 MHz MCU is the most 'relaxed' version.
// 40 inst. clocks per bit: HHHHHHHHxxxxxxxxxxxxLLLLLLLLLLLLLLLLLLLL
// ST instructions: ^ ^ ^ (T=0,8,20)
next = lo;
bit = 8;
asm volatile(
"head40:" "\n\t" // Clk Pseudocode (T = 0)
"sbrc %[byte] , 7" "\n\t" // 1-2 if(b & 128)
"mov %[next] , %[hi]" "\n\t" // 0-1 next = hi (T = 4)
"rjmp .+0" "\n\t" // 2 nop nop (T = 6)
"rjmp .+0" "\n\t" // 2 nop nop (T = 8)
"st %a[port], %[next]" "\n\t" // 2 PORT = next (T = 10)
"rjmp .+0" "\n\t" // 2 nop nop (T = 14)
"rjmp .+0" "\n\t" // 2 nop nop (T = 16)
"rjmp .+0" "\n\t" // 2 nop nop (T = 20)
"st %a[port], %[lo]" "\n\t" // 2 PORT = lo (T = 22)
"nop" "\n\t" // 1 nop (T = 23)
"mov %[next] , %[lo]" "\n\t" // 1 next = lo (T = 24)
"dec %[bit]" "\n\t" // 1 bit-- (T = 25)
"breq nextbyte40" "\n\t" // 1-2 if(bit == 0)
"rol %[byte]" "\n\t" // 1 b <<= 1 (T = 27)
"nop" "\n\t" // 1 nop (T = 28)
"rjmp .+0" "\n\t" // 2 nop nop (T = 30)
"rjmp .+0" "\n\t" // 2 nop nop (T = 32)
"rjmp .+0" "\n\t" // 2 nop nop (T = 34)
"rjmp .+0" "\n\t" // 2 nop nop (T = 36)
"rjmp .+0" "\n\t" // 2 nop nop (T = 38)
"rjmp head40" "\n\t" // 2 -> head40 (next bit out)
"nextbyte40:" "\n\t" // (T = 27)
"ldi %[bit] , 8" "\n\t" // 1 bit = 8 (T = 28)
"ld %[byte] , %a[ptr]+" "\n\t" // 2 b = *ptr++ (T = 30)
"st %a[port], %[lo]" "\n\t" // 2 PORT = lo (T = 34)
"sbiw %[count], 1" "\n\t" // 2 i-- (T = 38)
"brne head40" "\n" // 1-2 if(i != 0) -> (next byte)
[byte] "+r" (b),
[bit] "+r" (bit),
[next] "+r" (next),
[count] "+w" (i)
: [ptr] "e" (ptr),
[hi] "r" (hi),
[lo] "r" (lo));
#endif // NEO_KHZ400
#else
#error "CPU SPEED NOT SUPPORTED"
#endif // end F_CPU ifdefs on __AVR__
