ADS1220_WE_two_devices_one_spi_interface
Hi
I am running this code on esp32
* Example sketch for the ADS1220_WE library
* This sketch shows how to use two ADS1220 modules attached to the same SPI
* interface. This sketch was tested on an Arduino UNO R3 and Arduino UNO R4.
* For an Arduino UNO R4 (WIFI or Minima) pay attention to lines 29-32!
#include <ADS1220_WE.h>
#include <SPI.h>
// Pin definitions
#define ADS1220_1_CS_PIN    7   // Chip Select
#define ADS1220_1_DRDY_PIN  6   // Data Ready
#define ADS1220_2_CS_PIN    5   // Chip Select
#define ADS1220_2_DRDY_PIN  4   // Data Ready
#define SPI_INITIALIZED true
#define SPI_NOT_INITIALIZED false
/* Create ADS1220 objects */
ADS1220_WE ads1 = ADS1220_WE(ADS1220_1_CS_PIN, ADS1220_1_DRDY_PIN);
ADS1220_WE ads2 = ADS1220_WE(ADS1220_2_CS_PIN, ADS1220_2_DRDY_PIN);
/* For reasons I don't know, the Arduino UNO R4 WIFI and Minima (and maybe other boards?) don't like
 * it if SPI.begin() is called a second time, which happens by default if using the above constructors.
 * To avoid this use these alternative constructors: */
// ADS1220_WE ads1 = ADS1220_WE(ADS1220_1_CS_PIN, ADS1220_1_DRDY_PIN, SPI_NOT_INITIALIZED);
// ADS1220_WE ads2 = ADS1220_WE(ADS1220_2_CS_PIN, ADS1220_2_DRDY_PIN, SPI_INITIALIZED);
  while (!Serial);
  /* Choose SPI clock speed here. */
  // ads1.setSPIClockSpeed(4000000); // set SPI clock speed, default is 4 MHz
  // ads2.setSPIClockSpeed(4000000);
  digitalWrite(ADS1220_1_CS_PIN, HIGH);
  pinMode(ADS1220_1_CS_PIN, OUTPUT);
  digitalWrite(ADS1220_2_CS_PIN, HIGH);
  pinMode(ADS1220_2_CS_PIN, OUTPUT);
  Serial.println("CS of ADS1220 #1 and ADS1220 #2 forced to HIGH (inactive).");
  Serial.println("Initializing ADS1220 #1...");
  if (ads1.init()) {
    Serial.println("ADS1220 #1 connected and functioning!");
    Serial.println("ERROR: ADS1220 #1 not responding.");
    //while (1);
  delay(100);
  Serial.println("Initializing ADS1220 #2...");
  if (ads2.init()) {
    Serial.println("ADS1220 #2 connected and functioning!");
    Serial.println("ERROR: ADS1220 #2 not responding.");
    //while (1);
  delay(100);
  ads1.setGain(ADS1220_GAIN_1);
  ads1.setDataRate(ADS1220_DR_LVL_0);
  ads1.setConversionMode(ADS1220_CONTINUOUS);
  ads2.setGain(ADS1220_GAIN_1);
  ads2.setDataRate(ADS1220_DR_LVL_0);
  ads2.setConversionMode(ADS1220_CONTINUOUS);
  float vRef1 = ads1.getVRef_V();
  Serial.print("VRef (ADS1220 #1): ");
  Serial.print(vRef1, 3);
  Serial.println(" V");
  float vRef2 = ads2.getVRef_V();
  Serial.print("VRef (ADS1220 #2): ");
  Serial.print(vRef2, 3);
  delay(3000);
  ads1.setCompareChannels(ADS1220_MUX_0_1);
  float result1 = ads1.getVoltage_mV();
  Serial.print("1. AIN0 vs. AIN1  [mV]: ");
  Serial.println(result1);
  ads2.setCompareChannels(ADS1220_MUX_0_1);
  float result2 = ads2.getVoltage_mV();
  Serial.print("2. AIN0 vs. AIN1  [mV]: ");
  Serial.println(result2);
and have this error on serial monitor
rst:0x8 (TG1WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:4980
load:0x40078000,len:16612
load:0x40080400,len:3480
entry 0x400805b4
ets Jul 29 2019 12:21:46
I did this
and got this
focus on that statement
@tom321
You can't use pins 6 and 7.
Try 16 and 17.
See this for which ESP pins you can use.
Thanks for support, this one is working.
#include <SPI.h>
// Pin definitions
#define SPI_MISO_PIN 19
#define ADS1220_1_CS_PIN    25   // Chip Select
#define ADS1220_1_DRDY_PIN  34   // Data Ready
#define ADS1220_2_CS_PIN    26   // Chip Select
#define ADS1220_2_DRDY_PIN  35   // Data Ready
  while (!Serial);
  if (ads1.init()) {
  if (ads2.init()) {
  float Ux = ads1.getVoltage_mV();
  //float  Ux = ads1.getVoltage_muV();
  float Uy = ads2.getVoltage_mV();
 // float   Uy = ads2.getVoltage_muV();
  Serial.print("  Ux  [uV]=  "); Serial.print(Ux);
  Serial.print("  Uy  [uV]=  "); Serial.print(Uy);
  delay(10);
  Ux  [uV]=  1649.31  Uy  [uV]=  -1649.59
  Ux  [uV]=  1649.35  Uy  [uV]=  -1649.29
  Ux  [uV]=  1649.39  Uy  [uV]=  -1649.32
  Ux  [uV]=  1649.30  Uy  [uV]=  -1649.24
  Ux  [uV]=  1649.32  Uy  [uV]=  -1649.22
  Ux  [uV]=  1649.30  Uy  [uV]=  -1649.31
  Ux  [uV]=  1649.37  Uy  [uV]=  -1649.19
You are welcome.
Have a nice day!
