Aduino RF communication
I work with Arduino Uno Atmega 328P.Comunicate over RF between two aduinos but one i put on breakboard with the 16Mhz crystal.The other is on the arduino uno socket to view serial port.
I use this RF Transmitter and receiver:
http://inmotion.pt/documentation/sparkfun/WRL-08946/MO-SAWR.pdf
http://inmotion.pt/documentation/sparkfun/WRL-08950/MO-RX3400.pdf
I use this code:
http://www.seeedstudio.com/wiki/Grove_-_433MHz_Simple_RF_Link_Kit
I only chance the receive code,like this:
if(vw_get_message(buf, &buflen)) // non-blocking I/O
    int i;
    // Message with a good checksum received, dump HEX
    Serial.print("Got: ");
    for(i = 0; i < buflen; ++i)
      Serial.print(buf[i]);
    Serial.println("");
I make this change because i want to receive a char.
The problem is i dont receive a char but numbers.If i put the code with any chance i have de Hex i convert manualy it to char and a have the char what is supose to receive.
I see many codes and no one have to convert manualy because VirtualWire.h send chars or arrays.
I dont have any schematics.
Any hepl for this?
If you want to send in hex then try Serial.write() or Serial.print(buf*,HEX);*
Mark
Thank you for the reply.
I want to receive the char "Hello" that transmmitter send but i just receive numbers.
Grrr - its up to you to decide if there numbers or not!
41 42 43 44 is ABCD if 41 etc are in hex.
65 66 67 68 is ABCD if 65 etc are in dec.
Mark
Change your output code to this:
      Serial.print((char) buf[i]);
The transmitter have this code:
#include <VirtualWire.h>
int RF_TX_PIN = 2;
  vw_set_tx_pin(RF_TX_PIN); // Setup transmit pin
  vw_setup(2000); // Transmission speed in bits per second.
  const char *msg = "hello";
  vw_send((uint8_t *)msg, strlen(msg));  // Send 'hello' every 400ms.
  delay(400);
The receive this:
int RF_RX_PIN = 2;
  Serial.println("setup");
  vw_set_rx_pin(RF_RX_PIN);  // Setup receive pin.
  vw_rx_start(); // Start the PLL receiver.
  uint8_t buf[VW_MAX_MESSAGE_LEN];
  uint8_t buflen = VW_MAX_MESSAGE_LEN;
    int i;
    Serial.println("");
Put like this:
Like this is supose receive a array.I want to receive de "Hello" that the transmitter send. I receive like ones and zeros.I think wrong?
Thank you aarondc solve my problem. :slight_smile:
