Hi currently im working on project for making Hot Wheels Start and Finish gate with timer,
i'm use MAX7219 seven segment 8 Digit for my project.
this is my setup for my project :
- 4 IR Sensor for start and finish 2 Lane
- Time display MAX7219 seven segment 8 digit (first 4 digit for Lane 1,and the other for Lane2)
this is my goal for my project :
- timer trigger when cars cross the start sensor
- timer stop when cars cross finish sensor
- after race is finish the timer reset to zero
what i already accomplish :
- timer triggered when cars cross the start sensor
- timer stopped when cars cross finish sensor
my question is :
- when the first cars cross the start sensor,then the other cars on the other lane cross the start sensor,the timer "copy" the sensor on who cross the sensor first, is it possible to make individually millis timing?
-i read on some topic here that is impossible to reset millis back to zero at loop, how to manipulate millis back to zero?, currently im just use reset button so after race is finish i press the reset button, is there any side effect doing this on and on?
i heard about RTC is it necessary for my project?,i.e 555 timer.
im really sorry im learning by doing with no coding background before.
here it is my code i copy from multiple example and try to understand line by lines
any help would be appreciated many thanks!
#include <LedControl.h>
#include <Bounce2.h>
LedControl lc = LedControl(10, 12, 11, 1);
long tn, deltaT;
int a, b, c, d;
int a1, b1, c1, d1;
int starttimer = 6; // Start Timer Pin
int starttimer1 = 9;
int finishtimer = 7; // Finish Timer Pin
int finishtimer1 = 8;
bool statusSwitch1 = false;
bool statusSwitch2 = false;
bool statusSwitch3 = false;
bool statusSwitch4 = false;
Bounce SW1 = Bounce(); // Define Bounce to read StartStop switch
Bounce SW2 = Bounce(); // Define Bounce to read Lapse switch
Bounce SW3 = Bounce();
Bounce SW4 = Bounce();
pinMode (starttimer, INPUT_PULLUP);
pinMode (starttimer1, INPUT_PULLUP);
pinMode (finishtimer, INPUT_PULLUP);
pinMode (finishtimer1, INPUT_PULLUP);
// After setting up the button, setup the Bounce instance
SW1.attach(starttimer); // Sets the pin (Internal Pull-Up)and matches the internal state to that of the pin
SW1.interval(4); // Sets the debounce time in milliseconds
SW2.attach(finishtimer);
SW2.interval(4);
SW3.attach(starttimer1);
SW3.interval(4);
SW4.attach(finishtimer1);
SW.interval(4);
lc.shutdown(0, false); // The MAX72XX is in power-saving mode on startup, we have to do a wakeup call
lc.setIntensity(0, 7); // Set the brightness of display between 0 and 15
lc.clearDisplay(0); // Clear the display
lc.setDigit(0, 7, 0, true);
lc.setDigit(0, 6, 0, false);
lc.setDigit(0, 5, 0, true);
lc.setDigit(0, 4, 0, false);
lc.setDigit(0, 3, 0, true);
lc.setDigit(0, 2, 0, false);
lc.setDigit(0, 1, 0, true);
lc.setDigit(0, 0, 0, false);
SW1.update(); // Start-Stop
SW2.update();
SW3.update();
SW4.update();
if (SW1.rose()) {
statusSwitch1 = !statusSwitch1;
if (SW2.rose()) {
statusSwitch2 = !statusSwitch2;
if (SW3.rose()) {
statusSwitch3 = !statusSwitch3;
if (SW4.rose()) {
statusSwitch4 = !statusSwitch4;
if (statusSwitch1 == true) { //trigger the timer lane1 to start running
tn = millis() - deltaT;
a = tn / 10000;
b = (tn / 1000) % 10;
c = (tn / 100 ) % 10;
d = (tn / 10) % 10;
lc.setDigit(0, 7, a, false);
lc.setDigit(0, 6, b, true);
lc.setDigit(0, 5, c, false);
lc.setDigit(0, 4, d, false);
else {
deltaT = millis() - tn; // freeze timer lane1
a = tn / 10000;
d = (tn / 10) % 10;
if (statusSwitch3 == true) { //trigger the timer lane2 to start running
a1 = tn / 10000;
b1 = (tn / 1000) % 10;
c1 = (tn / 100 ) % 10;
d1 = (tn / 10) % 10;
lc.setDigit(0, 3, a1, false);
lc.setDigit(0, 2, b1, true);
lc.setDigit(0, 1, c1, false);
lc.setDigit(0, 0, d1, false);
else {
deltaT = millis() - tn; //freeze timer lane2
if (statusSwitch1 == true && statusSwitch2 == false) { //trigger the 4LED 7 Segment "Lane1" to stop timer
a = tn / 10000;
d = (tn / 10) % 10;
lc.setDigit(0, 3, a, false);
lc.setDigit(0, 2, b, true);
lc.setDigit(0, 1, c, false);
lc.setDigit(0, 0, d, false);
if (statusSwitch3 == true && statusSwitch4 == false) { //trigger the 4 LED 7 Segment "Lane2" to stop timer
a1 = tn / 10000;
lc.setDigit(0, 7, a1, false);
lc.setDigit(0, 6, b1, true);
lc.setDigit(0, 5, c1, false);
lc.setDigit(0, 4, d1, false);
TRIX_TRAX_2_LANE_TIMER.ino (3.98 KB)
