I'm creating my first Arduino project, a PID Controller. It will be in a small plastic enclosure, and has two sensors and a relay output that I'd like to have plugs and panel-mount sockets so i can attach and detach them with ease.
I used a 2-pin DIN Loudspeaker connector (see DIN connector - Wikipedia) for the relay output, and a 5-pin DIN to combine the DS18B20 and Thermistor, but I found the 5-pin DIN in particular to be very difficult to solder.
Any advice for better connectors to use?
Goals:
Reduce chance of someone mistakenly making the wrong connections (including for the 2.1mm power socket in the Arduino)
Ideally solderless connections (2-pin DIN had screws, which was great), or easy enough to solder
Visually associate Thermistor and Temperature Sensor plugs and sockets with a similar look
One end should be panel-mount, the other inline
Any advice? I'm based in London, so would prefer products easily available in the UK.
In particular, the V4 has buckled ports for all 6 input pins (you can use an input pin as output), and it has a separate 3 wire (ground, vcc, pin value) for all pins.
V5 drops the buckled ports, but it has more specialized ports that you might need.
Here is one source for making the 3 wire connectors:
I'm sure there are many places that have them. Somebody had just mentioned this site, and I had book marked it.
Another alternative is using RJ-11 (4 wire phone connectors, at least in the USA) and RJ-45 (8 wire ethernet). I can find kits for making both RJ-11 and RJ-45 in any home improvement stores (in the USA, Lowes and Home Depot). I suspect the RJ-11 may be harder to find in the UK if you don't use that for your phones.
In terms of labelling ports, you can always get some different colours of paint, and paint both the male and female parts of the connector a given colour.
