Advice on Automotive Data Logger Project
Hi all,
I am interested in building a data logger for my race car. I hope to run 1-2 hall effect sensors and an accelerometer, as well as potentially several weather inputs (temp, pressure) and gps (if possible) for speed. I would like to log using an SD shield and also add a small LCD screen to toggle through various readings.
I am a total beginner, however I am eager to learn. I would like your advice on hardware selection and feasibility of the project. If anyone can suggest sensors that will be suitable for a racing environment I would appreciate it. I also plan on using an uno. Will this be suitable? Should I be worried about RFI/EMI? Anything else to consider at this time? Open to all suggestions, thank you.
If it was me, I would do this in two parts.
I would use a controller to do data gathering then use Jack Christensen's serial data logger to store the data.
http://forum.arduino.cc/index.php?topic=252905.0
What would be your reasoning for the two part approach? Would this still be within the scope of a beginner?
Jack's serial data logger is self contained and the software is proven.
If you make a new project that needs data logging, all you have to do is plug the serial logger into it.
With the data logger software on a separate ATMEGA386 gives all the memory on your acquisition controller to be used for that job.
