I would like to receive an advice about choosing ESP32 module that has camera and 1x analog read input, 3x GPIO input, 3x GPIO output and I2C available.
I found ESP32-S3 WROOM N16R8
and I don't need SD card. It's either something out there (maybe this one or you suggest) or I'll need to use MCP23017 expander with ESP32-Cam board, but would like to have it in one package.
Looking for your suggestions!
horace
July 10, 2024, 5:50am
2
have a look at ESP32-CAM
I2C works on GPIO0 and GPIO16, e.g.
#define I2C_SDA 16
#define I2C_SCL 0
Wire.begin(I2C_SDA, I2C_SCL);
and if not using SD card you have 6 GPIO pins available
srnet
July 10, 2024, 6:59am
3
There are several ESP32S3 boards that come with cameras, the ESP32S3 does have more IO pins avaialble versus the ESP32.
You might just get away with a standard ESP32CAM, but then sometime later you might find you need just one more IO pin.
That analog read probably going to be the issue..
If you're using WiFi and cam, then you might want to look into an i2c adc..
Cam uses adc1 and wifi ties up adc2..
good luck.. ~q
I need exactly 6 (input/output together).
The one that broke the back of my plans with ESP32Cam was GPIO16 on this device.
When you declare it as OUTPUT the mqtt connect breaks it (yes mqtt, wifi connects):
18:19:36.203 ->
18:19:36.203 -> Core 1 register dump:
18:19:36.203 -> PC : 0x40092ad1 PS : 0x00060530 A0 : 0x80092e24 A1 : 0x3ffb1fa0
18:19:36.203 -> A2 : 0xffffffff A3 : 0x00060523 A4 : 0x00060520 A5 : 0x3f40d8d8
18:19:36.203 -> A6 : 0x000000fd A7 : 0xb33fffff A8 : 0x00000001 A9 : 0x00000004
18:19:36.235 -> A10 : 0x00060523 A11 : 0x000000a6 A12 : 0x00000bb8 A13 : 0x3f40d9d4
18:19:36.235 -> A14 : 0x00000077 A15 : 0x6b00a8c0 SAR : 0x0000001d EXCCAUSE: 0x0000001c
18:19:36.235 -> EXCVADDR: 0x0000000f LBEG : 0x4008b624 LEND : 0x4008b63a LCOUNT : 0xffffffff
18:19:36.235 ->
18:19:36.235 ->
18:19:36.235 -> Backtrace: 0x40092ace:0x3ffb1fa0 0x40092e21:0x3ffb1fc0 0x40092805:0x3ffb1fe0 0x4009297c:0x3ffb2000 0x40084232:0x3ffb2020 0x40084462:0x3ffb2050 0x400fd6c7:0x3ffb2070 0x400d5db6:0x3ffb20e0 0x400d5433:0x3ffb2140 0x400d92dd:0x3ffb2180 0x400d946e:0x3ffb21f0 0x400d3330:0x3ffb2220 0x400d3173:0x3ffb2240 0x400ed55b:0x3ffb2270 0x4009076a:0x3ffb2290
18:19:36.268 ->
18:19:36.268 ->
18:19:36.268 ->
18:19:36.268 ->
18:19:36.268 -> ELF file SHA256: f5b76daf6ab294ff
18:19:36.299 ->
18:19:36.331 -> Rebooting...
18:19:36.331 -> ets Jul 29 2019 12:21:46
18:19:36.331 ->
and then one analog read that is not available when connected on wifi -> but I solved that by temporarily disconnecting - reading - reconnecting, but also there are 2 more inputs that I didn't even tried since this one failed..
srnet
July 10, 2024, 4:24pm
7
GPIO16 is the PSRAM select.
yeah, unfortunately for me now
system
Closed
January 6, 2025, 4:26pm
10
