Update:
Habe den Code zum Kalibrieren angepasst, um darzustellen wieso ich nicht in die if-Bedingungen unten komme:
// Function: To calibrate the parameters and it will recommend parameter
// setting and print to the serial monitor.So the values of the
// marco definitions in the ADXL335.h should be modified.
// Hardware: Grove - 3-Axis Analog Accelerometer
// Arduino IDE: Arduino-1.0
// Author: Frankie.Chu
// Date: Jan 11,2013
// Version: v1.0
// by www.seeedstudio.com
// This library is free software; you can redistribute it and/or
// modify it under the terms of the GNU Lesser General Public
// License as published by the Free Software Foundation; either
// version 2.1 of the License, or (at your option) any later version.
// This library is distributed in the hope that it will be useful,
// but WITHOUT ANY WARRANTY; without even the implied warranty of
// MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
// Lesser General Public License for more details.
// You should have received a copy of the GNU Lesser General Public
// License along with this library; if not, write to the Free Software
// Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
#include "ADXL335.h"
int zero_x;
int zero_y;
int zero_z;
int max_x,max_y,max_z;//when 1g
float sensitivity;
ADXL335 accelerometer;
accelerometer.begin();
int x,y,z;
for(int i = 0;i < 20;i ++)accelerometer.getXYZ(&x,&y,&z);
Serial.println("The calibration starts: ");
Serial.println("First, make sure that Z-axis direction is straight up");
Serial.println("please type any charactor if you are ready");
while(Serial.available() == 0);
delay(100);
while(Serial.available() > 0)Serial.read();
calibrate(&x,&y,&z);
zero_x = x;
zero_y = y;
max_z = z;
Serial.println("Second, make sure that X-axis direction is straight up");
Serial.println("please type any charactor again if you are ready");
delay(100);
zero_z = z;
float zero_xv,zero_yv,zero_zv;
zero_xv = (float)zero_x*ADC_REF/ADC_AMPLITUDE;
zero_yv = (float)zero_y*ADC_REF/ADC_AMPLITUDE;
zero_zv = (float)zero_z*ADC_REF/ADC_AMPLITUDE;
sensitivity =(float)(max_z - zero_z)*ADC_REF/ADC_AMPLITUDE;
Serial.print("ZERO_X = ");
Serial.println(zero_xv);
Serial.print("ZERO_Y = ");
Serial.println(zero_yv);
Serial.print("ZERO_Z = ");
Serial.println(zero_zv);
Serial.print("SENSITIVITY = ");
Serial.println(sensitivity,2);
Serial.println("please modified the macro definitions with these results in ADXL335.h");
void calibrate(int* _x,int* _y,int* _z)
int x,y,z;
int sum_x,sum_y,sum_z;
float ax,ay,az;
accelerometer.getAcceleration(&ax,&ay,&az);
Serial.println ("wert für ax (muss kleiner sein wie 0,06)");
Serial.println (ax);
Serial.println ("wert für ay (muss kleiner sein wie 0,06)");
Serial.println (ay);
Serial.println ("wert für az (muss kleiner sein wie 0,06)");
Serial.println (az);
if((abs(ax) < 0.06)&&(abs(ay) < 0.06))
*_x = x;
*_y = y;
*_z = z;
else if((abs(ax) < 0.06)&&(abs(az) < 0.06))
*_x = x;
*_y = y;
*_z = z;
else if((abs(az) < 0.06)&&(abs(ay) < 0.06))
*_x = x;
*_y = y;
*_z = z;
else Serial.println("calibrate error");
Fazit:
voltage:
1.32
1.27
1.25
0.39
0.20
-0.02
calibrate error
voltage:
1.52
1.27
1.47
1.19
wert fr ay (muss kleiner sein wie 0,06)
0.20
0.90
calibrate error
ZERO_X = 1.23
ZERO_Y = 1.27
ZERO_Z = 1.25
SENSITIVITY = 0.00
Wieso bekomme ich solche Werte?
