currently I am trying to connect several ADXL345 to an Arduino Nano. I followed the Sparkfun Tutorial on how to do this (https://www.sparkfun.com/tutorials/240). Long story short, I connected two ADXL345 to the Arduino and can read the measures from it, but the values seem to be completely wrong.
So when I lay bot flat on the table, I'd expect the measures to be approx 0,0,1g (x,y,z).
When I lay both of them flat on the table I get:
SelectedChip: 9- -0.5460000038,-0.4679999828,-0.0077999997
SelectedChip: 10- -0.2262000083,-0.5460000038,-0.0077999997
When I turn around both Chips 180°, I'd expect the measures to be approx 0,0,-1. But I get:
SelectedChip: 9- -0.6006000041,-0.3977999877,-0.0077999997 <-- Z-Axis does not change at all with this one
SelectedChip: 10- -0.2574000120,-0.4368000030,2.9873998641
When I tilt both to 90° I' expect the measures to be approx 0,1,0. But I get:
SelectedChip: 9- -0.5460000038,-1.6223999023,-0.0077999997
SelectedChip: 10- -0.1949999904,-1.7081999778,-0.0546000003
When I shake them I get the following:
SelectedChip: 9- -3.3539998531,-3.9935998916,-0.4835999965
SelectedChip: 10- 0.1715999984,-0.0077999997,-0.0077999997
SelectedChip: 9- -0.0311999988,-0.4368000030,-0.0077999997
SelectedChip: 10- -1.8017998695,2.4570000171,-0.0077999997
SelectedChip: 9- -0.2417999982,-0.6083999633,-0.0077999997
SelectedChip: 10- -0.9671999931,-3.4085998535,-0.2963999748
SelectedChip: 9- 0.7409999847,-0.6941999912,-0.0077999997
SelectedChip: 10- -0.7487999916,-3.9935998916,-0.1559999942
Am I doing something wrong? Or am I thinking wrong? I mean even if my code would be wrong, it should be wrong for both sensors, shouldn't it.
I'll also add the code here, but it's mostly the Sparkfun sample code:
//Add the SPI library so we can communicate with the ADXL345 sensor
#include <SPI.h>
//Assign the Chip Select signal to pin 10.
//int CS=10;
int CS_1=10;
int CS_2=9;
//ADXL345 Register Addresses
#define DEVID 0x00 //Device ID Register
#define THRESH_TAP 0x1D //Tap Threshold
#define OFSX 0x1E //X-axis offset
#define OFSY 0x1F //Y-axis offset
#define OFSZ 0x20 //Z-axis offset
#define DURATION 0x21 //Tap Duration
#define LATENT 0x22 //Tap latency
#define WINDOW 0x23 //Tap window
#define THRESH_ACT 0x24 //Activity Threshold
#define THRESH_INACT 0x25 //Inactivity Threshold
#define TIME_INACT 0x26 //Inactivity Time
#define ACT_INACT_CTL 0x27 //Axis enable control for activity and inactivity detection
#define THRESH_FF 0x28 //free-fall threshold
#define TIME_FF 0x29 //Free-Fall Time
#define TAP_AXES 0x2A //Axis control for tap/double tap
#define ACT_TAP_STATUS 0x2B //Source of tap/double tap
#define BW_RATE 0x2C //Data rate and power mode control
#define POWER_CTL 0x2D //Power Control Register
#define INT_ENABLE 0x2E //Interrupt Enable Control
#define INT_MAP 0x2F //Interrupt Mapping Control
#define INT_SOURCE 0x30 //Source of interrupts
#define DATA_FORMAT 0x31 //Data format control
#define DATAX0 0x32 //X-Axis Data 0
#define DATAX1 0x33 //X-Axis Data 1
#define DATAY0 0x34 //Y-Axis Data 0
#define DATAY1 0x35 //Y-Axis Data 1
#define DATAZ0 0x36 //Z-Axis Data 0
#define DATAZ1 0x37 //Z-Axis Data 1
#define FIFO_CTL 0x38 //FIFO control
#define FIFO_STATUS 0x39 //FIFO status
//This buffer will hold values read from the ADXL345 registers.
char values[10];
//These variables will be used to hold the x,y and z axis accelerometer values.
int x,y,z;
double xg, yg, zg;
//Convert the accelerometer value to G's.
//With 10 bits measuring over a +/-4g range we can find how to convert by using the equation:
// Gs = Measurement Value * (G-range/(2^10)) or Gs = Measurement Value * (8/1024)
float gMultiplyer = (8/(2^10));
void setup(){
//Initiate an SPI communication instance.
SPI.begin();
//Configure the SPI connection for the ADXL345.
SPI.setDataMode(SPI_MODE3);
//Create a serial connection to display the data on the terminal.
//Set up the Chip Select pin to be an output from the Arduino.
pinMode(CS_1, OUTPUT);
pinMode(CS_2, OUTPUT);
//Before communication starts, the Chip Select pin needs to be set high.
digitalWrite(CS_1, HIGH);
digitalWrite(CS_2, HIGH);
//Put the ADXL345 into +/- 4G range by writing the value 0x01 to the DATA_FORMAT register.
writeRegister(DATA_FORMAT, 0x01, CS_1);
writeRegister(DATA_FORMAT, 0x01, CS_2);
//Put the ADXL345 into Measurement Mode by writing 0x08 to the POWER_CTL register.
writeRegister(POWER_CTL, 0x08, CS_1); //Measurement mode
writeRegister(POWER_CTL, 0x08, CS_2); //Measurement mode
void loop(){
printValuesFor(CS_1, HIGH);
printValuesFor(CS_2, HIGH);
delay(10);
void printValuesFor(int selectedChip, boolean printG){
//Reading 6 bytes of data starting at register DATAX0 will retrieve the x,y and z acceleration values from the ADXL345.
//The results of the read operation will get stored to the values[] buffer.
readRegister(DATAX0, 6, values, selectedChip);
//The ADXL345 gives 10-bit acceleration values, but they are stored as bytes (8-bits). To get the full value, two bytes must be combined for each axis.
//The X value is stored in values[0] and values[1].
x = ((int)values[1]<<8)|(int)values[0];
//The Y value is stored in values[2] and values[3].
y = ((int)values[3]<<8)|(int)values[2];
//The Z value is stored in values[4] and values[5].
z = ((int)values[5]<<8)|(int)values[4];
xg = x * 0.0078;
yg = y * 0.0078;
zg = z * 0.0078;
//Print the results to the terminal.
Serial.print("SelectedChip: ");
Serial.print(selectedChip, DEC);
Serial.print("- ");
if(printG){
Serial.print(xg, DEC);
Serial.print(',');
Serial.print(yg, DEC);
Serial.print(',');
Serial.println(zg, DEC);
}else{
Serial.print(x, DEC);
Serial.print(',');
Serial.print(y, DEC);
Serial.print(',');
Serial.println(z, DEC);
//This function will write a value to a register on the ADXL345.
//Parameters:
// char registerAddress - The register to write a value to
// char value - The value to be written to the specified register.
void writeRegister(char registerAddress, char value, int selectedChip){
//Set Chip Select pin low to signal the beginning of an SPI packet.
digitalWrite(selectedChip, LOW);
//Transfer the register address over SPI.
SPI.transfer(registerAddress);
//Transfer the desired register value over SPI.
SPI.transfer(value);
//Set the Chip Select pin high to signal the end of an SPI packet.
digitalWrite(selectedChip, HIGH);
//This function will read a certain number of registers starting from a specified address and store their values in a buffer.
//Parameters:
// char registerAddress - The register addresse to start the read sequence from.
// int numBytes - The number of registers that should be read.
// char * values - A pointer to a buffer where the results of the operation should be stored.
void readRegister(char registerAddress, int numBytes, char * values, int selectedChip){
//Since we're performing a read operation, the most significant bit of the register address should be set.
char address = 0x80 | registerAddress;
//If we're doing a multi-byte read, bit 6 needs to be set as well.
if(numBytes > 1)address = address | 0x40;
//Set the Chip select pin low to start an SPI packet.
//Transfer the starting register address that needs to be read.
SPI.transfer(address);
//Continue to read registers until we've read the number specified, storing the results to the input buffer.
for(int i=0; i<numBytes; i++){
values[i] = SPI.transfer(0x00);
//Set the Chips Select pin high to end the SPI packet.
