ADXL345 + slepp
It is driving me crazy for a week now.... :frowning:
I am trying to read ADXL345 only when activated interrupt is sent. All the remaining time my arduino needs to spend sleeping.
But.. it's working only for a few moments and only after complete power down prior to test - i need to literally unplug it to reset everything. Like ADXL stops dead. After a few moments of working.
I do not know how to solve that. It's working ok if i remove the sleep command.
   LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
#include <LowPower.h>
#include <SparkFun_ADXL345.h>         // SparkFun ADXL345 Library
/*********** COMMUNICATION SELECTION ***********/
/*    Comment Out The One You Are Not Using    */
//ADXL345 adxl = ADXL345(10);           // USE FOR SPI COMMUNICATION, ADXL345(CS_PIN);
ADXL345 adxl = ADXL345();             // USE FOR I2C COMMUNICATION
boolean volatile intADXL = false;
double roll;
double pitch;
double xyz[3];
/****************** INTERRUPT ******************/
/*      Uncomment If Attaching Interrupt       */
int interruptPin = 3;                 // Setup pin 2 to be the interrupt pin (for most Arduino Boards)
/******************** SETUP ********************/
/*          Configure ADXL345 Settings         */
void setupADXL() {
  pinMode(interruptPin, INPUT);
  attachInterrupt(digitalPinToInterrupt(interruptPin), ADXL_ISR, RISING);   // Attach Interrupt
  adxl.powerOn();                     // Power on the ADXL345
  adxl.setRangeSetting(4);           // Give the range settings
  adxl.setRate(100);
  adxl.setInterruptLevelBit(0);
  adxl.setNoFifo(); //custom  - disable FIFO - bypass mode
  adxl.setActivityXYZ(1, 1, 1);       // Set to activate movement detection in the axes "adxl.setActivityXYZ(X, Y, Z);" (1 == ON, 0 == OFF)
  adxl.setActivityThreshold(17);      // 62.5mg per increment   // Set activity   // Inactivity thresholds (0-255)
  adxl.setImportantInterruptMapping(2, 2, 2, 1, 2);     // Sets "adxl.setEveryInterruptMapping(single tap, double tap, free fall, activity, inactivity);"
  adxl.InactivityINT(0);
  adxl.ActivityINT(1);
  adxl.FreeFallINT(0);
  adxl.doubleTapINT(0);
  adxl.singleTapINT(0);
  Serial.begin(9600);                 // Start the serial terminal
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, LOW);
  bb();
  setupADXL();
  roll  = (atan2(-xyz[1], xyz[2]) * 180.0) / M_PI;
  pitch = (atan2(xyz[0], sqrt(xyz[1] * xyz[1] + xyz[2] * xyz[2])) * 180.0) / M_PI;
  Serial.print ("Roll = " + (String)roll); Serial.println ("     |Pitch = " + (String)pitch);
  if (!intADXL) {
    Serial.println ("powering down");
    delay (500);
  if (intADXL)
    intADXL = false;
    byte interrupts = 0;
    interrupts = adxl.getInterruptSource();
    //Activity
    if (adxl.triggered(interrupts, ADXL345_ACTIVITY)) {
      Serial.println("*** ACTIVITY ***");
      bb();
      adxl.get_Gxyz(xyz);
void bb() {
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(10);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
void ADXL_ISR() {
  intADXL = true;
  1. adxl does not send "interrupt" it it sending HIGH signal forever.
  2. I can read data in a loop when digitalRead(interruptPin) == HIGH but it does not help.
    I think because there can be an effect that int will be rised in the middle of arduino going to sleep, so the interrupt will be missed = there will be no reaction to rising signal on a pin.
  3. It is working in this version - so clearly I am facing some kind of raceing condition
    //edit: no it's not - it just worked longer....
double roll;
double pitch;
double xyz[3];
int interruptPin = 2;
void setupADXL() {
  //pinMode(interruptPin, INPUT);
  attachInterrupt(digitalPinToInterrupt(interruptPin), ADXL_ISR, HIGH);   // Attach Interrupt
  adxl.setRate(100);
  Serial.begin(115200);                 // Start the serial terminal
  bb();
  setupADXL();
  if (digitalRead(interruptPin) == HIGH) intADXL = true;
  if (digitalRead(interruptPin) == LOW) {
    LowPower.powerDown(SLEEP_FOREVER, ADC_ON, BOD_OFF);
  else {
    while (  digitalRead(interruptPin) == HIGH) {
      adxl.get_Gxyz(xyz);
void bb() {
void ADXL_ISR() {
  //intADXL = true;
detachInterrupt in the ISR function. You're level-triggering the interrupt, meaning it will be called repeatedly as long as the pin is HIGH and nothing else will be done. Reattach the interrupt before going to sleep.
In fact, ONLY attach the interrupt immediately before going to sleep. You don't need it active when you're awake.
And then you have to sleep in the very next instruction. You can't call a function to do it. Otherwise you may get the interrupt before going to sleep and then it never wakes up because the interrupt isn't 'new'.
but you understood that adxl provides unit step signal as interrupt? Not a dirac delta signal that I was expecting?
Anyway I will give it a try :slight_smile: Thank you
EDIT:
Still not ok - it's working for a short time and freezes
double roll;
double pitch;
double xyz[3];
void setupADXL() {
  adxl.setRate(100);
  setupADXL();
  //delay(1000);
    adxl.ActivityINT(0);
    Serial.println ("SLEEP NOW");
  else {
      //Serial.println (">>>>>>HIGH");
      adxl.get_Gxyz(xyz);
      //adxl.getInterruptSource();
    intADXL = false;
void ADXL_ISR() {
  detachInterrupt(digitalPinToInterrupt(interruptPin));
  intADXL = true;
I think I have a solution. It's not elegant but works.
So I .... borrowed the library code and fixed one part: I added attachInt before going to sleep, and detached when Int is received.
#include <avr/sleep.h>
#include <avr/wdt.h>
#include <avr/power.h>
#include <avr/interrupt.h>
double roll;
double pitch;
double xyz[3];
enum period_t
  SLEEP_15MS,
  SLEEP_30MS,
  SLEEP_60MS,
  SLEEP_120MS,
  SLEEP_250MS,
  SLEEP_500MS,
  SLEEP_1S,
  SLEEP_2S,
  SLEEP_4S,
  SLEEP_8S,
  SLEEP_FOREVER
enum bod_t
  BOD_OFF,
  BOD_ON
enum adc_t
  ADC_OFF,
  ADC_ON
enum timer5_t
  TIMER5_OFF,
  TIMER5_ON
enum timer4_t
  TIMER4_OFF,
  TIMER4_ON
enum timer3_t
  TIMER3_OFF,
  TIMER3_ON
enum timer2_t
  TIMER2_OFF,
  TIMER2_ON
enum timer1_t
  TIMER1_OFF,
  TIMER1_ON
enum timer0_t
  TIMER0_OFF,
  TIMER0_ON
enum spi_t
  SPI_OFF,
  SPI_ON
enum usart0_t
  USART0_OFF,
  USART0_ON
enum usart1_t
  USART1_OFF,
  USART1_ON
enum usart2_t
  USART2_OFF,
  USART2_ON
enum usart3_t
  USART3_OFF,
  USART3_ON
enum twi_t
  TWI_OFF,
  TWI_ON
enum usb_t
  USB_OFF,
  USB_ON
enum idle_t
  IDLE_0,
  IDLE_1,
  IDLE_2
#define  lowPowerBodOn(mode) \
  do {            \
    set_sleep_mode(mode); \
    cli();        \
    sleep_enable();   \
    sei();        \
    sleep_cpu();      \
    sleep_disable();    \
    sei();        \
  } while (0);
#define  lowPowerBodOff(mode)\
  do {            \
    cli();        \
    attachInterrupt(digitalPinToInterrupt(interruptPin), ADXL_ISR, RISING);   \
    sleep_enable();   \
    sleep_bod_disable(); \
    sei();        \
    sleep_cpu();      \
    sleep_disable();    \
    sei();        \
  } while (0);
#ifndef sleep_bod_disable
#define sleep_bod_disable()                     \
  do {                                \
    unsigned char tempreg;                          \
    __asm__ __volatile__("in %[tempreg], %[mcucr]" "\n\t"       \
                         "ori %[tempreg], %[bods_bodse]" "\n\t"     \
                         "out %[mcucr], %[tempreg]" "\n\t"      \
                         "andi %[tempreg], %[not_bodse]" "\n\t"     \
                         "out %[mcucr], %[tempreg]"           \
                         : [tempreg] "=&d" (tempreg)          \
                         : [mcucr] "I" _SFR_IO_ADDR(MCUCR),       \
                         [bods_bodse] "i" (_BV(BODS) | _BV(BODSE)), \
                         [not_bodse] "i" (~_BV(BODSE)));      \
  } while (0)
#endif
void  pDown(period_t period, adc_t adc, bod_t bod)
  if (adc == ADC_OFF) ADCSRA &= ~(1 << ADEN);
  if (period != SLEEP_FOREVER)
    wdt_enable(period);
    WDTCSR |= (1 << WDIE);
  if (bod == BOD_OFF)
    lowPowerBodOff(SLEEP_MODE_PWR_DOWN);
    lowPowerBodOn(SLEEP_MODE_PWR_DOWN);
  if (adc == ADC_OFF) ADCSRA |= (1 << ADEN);
void setupADXL() {
  adxl.setRate(100);
  setupADXL();
  //delay(1000);
    delay(200);
    pDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
  else {
      adxl.get_Gxyz(xyz);
    intADXL = false;
void ADXL_ISR() {
  cli();
  intADXL = true;
Do not cli() in the ISR. That'll mess millis() timing and Serial right up.
Yes, thanks - removed that - still works ok :slight_smile:
So I have been trying to clean up a bit my code. In this part below I commented out the disable/enable part of interrupt definition on adxl.
I added this part by intuition, it's not supported by any datasheet facts - I was just trying to make it work by doing everything I could find.
And guess what - it stops working.
    //adxl.ActivityINT(0);
    //adxl.ActivityINT(1);
Do you have any idea what would be the better approach?
