AESlib, decryption in non arduino devices
Hi everyone,
I want to encrypt a text in ESP32 via AESlib and send it to another device, flutter, or a website. But when I was decrypting this code, it would successfully be done but with the wrong value; I have tried to use online decryption websites like
The result was the same; moreover, I had the correct decryption in Arduino, and I am using one of the examples of the AESlib, which name is ESPserial.
Thanks
real text = "test"
website :
LImmD60OFOYo78VtMNrVKg==
key : 0000000000000000
export : dGVzdA==
serial monitor export :
INPUT:test
encrypted = LImmD60OFOYo78VtMNrVKg==
Ciphertext: LImmD60OFOYo78VtMNrVKg==
Cleartext: test
SUCCES
/* Medium example for ESP8266 (not for Arduino, uses additional Base64 layer) */
#include "AESLib.h"
AESLib aesLib;
String plaintext = "Test";
char cleartext[256];
char ciphertext[512];
// AES Encryption Key
byte aes_key[] = { 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30 };
// General initialization vector (you must use your own IV's in production for full security!!!)
byte aes_iv[N_BLOCK] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 };
String encrypt(char * msg, uint16_t msgLen, byte iv[]) {
  int cipherlength = aesLib.get_cipher64_length(msgLen);
  char encrypted[cipherlength]; // AHA! needs to be large, 2x is not enough
  aesLib.encrypt64(msg, msgLen, encrypted, aes_key, sizeof(aes_key), iv);
  Serial.print("encrypted = "); Serial.println(encrypted);
  return String(encrypted);
String decrypt(char * msg, uint16_t msgLen, byte iv[]) {
  char decrypted[msgLen];
  aesLib.decrypt64(msg, msgLen, decrypted, aes_key, sizeof(aes_key), iv);
  return String(decrypted);
// Generate IV (once)
void aes_init() {
  Serial.println("gen_iv()");
  aesLib.gen_iv(aes_iv);
  Serial.println("encrypt()");
  Serial.println(encrypt(strdup(plaintext.c_str()), plaintext.length(), aes_iv));
  while (!Serial); // wait for serial port
  delay(2000);
  aes_init();
  aesLib.set_paddingmode(paddingMode::CMS);
  // verify with https://cryptii.com
  // previously: verify with https://gchq.github.io/CyberChef/#recipe=To_Base64('A-Za-z0-9%2B/%3D')
  char b64in[16] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
  char b64out[base64_enc_len(sizeof(aes_iv))];
  base64_encode(b64out, b64in, 16);
  char b64enc[base64_enc_len(10)];
  base64_encode(b64enc, (char*) "0000000000", 10);
  char b64dec[ base64_dec_len(b64enc, sizeof(b64enc))];
  base64_decode(b64dec, b64enc, sizeof(b64enc));
  Serial.println("Enter text to be encrypted into console (no feedback) and press ENTER (newline):");
/* non-blocking wait function */
void wait(unsigned long milliseconds) {
  unsigned long timeout = millis() + milliseconds;
  while (millis() < timeout) {
    yield();
unsigned long loopcount = 0;
byte enc_iv[N_BLOCK] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 }; // iv_block gets written to, provide own fresh copy...
byte dec_iv[N_BLOCK] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
  if (Serial.available()) {
    loopcount++; Serial.println(loopcount); // entry counter
    String readBuffer = Serial.readStringUntil('\n');
    Serial.println("INPUT:" + readBuffer);
    sprintf(cleartext, "%s", readBuffer.c_str()); // must not exceed 255 bytes; may contain a newline
    // Encrypt
    uint16_t clen = String(cleartext).length();
    String encrypted = encrypt(cleartext, clen, enc_iv);
    sprintf(ciphertext, "%s", encrypted.c_str());
    Serial.print("Ciphertext: ");
    // Decrypt
    uint16_t dlen = encrypted.length();
    String decrypted = decrypt( ciphertext, dlen, dec_iv);
    Serial.print("Cleartext: ");
    Serial.println(decrypted);
    if (decrypted.equals(cleartext)) {
      Serial.println("SUCCES");
      Serial.println("FAILURE");
    for (int i = 0; i < 16; i++) {
      enc_iv[i] = 0;
      dec_iv[i] = 0;
Hello wilson1366,
Did you manage to find the answer?
Can you please share any updates?
