After getting DS18B20 temp sensor working, I lose button functionality
I'm trying to include code to PWM control the fans on an LED heatsink according to the temperature. I had this working a decade ago but lost all my files while trying to build a new controller. I've grabbed the original script and temperature read code that was shared with me posted in a reef tank forum, and although I was able to get the code worked in, the sensor works as expected, but all of a sudden the buttons don't work. I'm wondering if it's something to do with OneWire messing with the Button library and the way the script is written. Or... if maybe I placed some code in the wrong sections(?).
Here's the code I'm trying to insert:
#include "OneWire.h"
#include "DallasTemperature.h"
#define ONE_WIRE_BUS 0 //Define the pin of the DS18B20
int fanPWMpin = 0;    //Define the pin of the Fan
const int HtempMin = 97.0;    //Define temp when heatsink fan starts
const int HtempMax = 100.0;   //Define temp when heatsink fan is 100%
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
void checkTemp()
sensors.requestTemperatures(); // Send the command to get temperatures
delay(250);
float temp1=0, temp2=0;
  //lcd.setCursor(2, 1);
  //lcd.print("Tank Temp: ");
  temp1= sensors.getTempFByIndex(0);
  //lcd.print(sensors.getTempFByIndex(0));
  //lcd.print((char)223);
  //lcd.print("F");
  //lcd.setCursor(13, 1);
  //lcd.print("Led Temp:");
  temp2= sensors.getTempFByIndex(1);
  //lcd.print(sensors.getTempFByIndex(1));
  //lcd.print("F");
 if (temp1<0) temp1=0;                      //if sensor not connected reading is -127 deg
  else if (temp1>99) temp1=99;
 if (temp2<0) temp2=0;
  else if (temp2>99) temp2=99;
  int tempval = int(temp2*10);
  int fanSpeed = map(tempval, (HtempMin*10), (HtempMax*10), 0, 255);       //---------heatsink fan control
  if (fanSpeed<=0)
     fanSpeed = 0;
  if (fanSpeed>255)
     fanSpeed=255;
  analogWrite(fanPWMpin, fanSpeed);
 // Serial.println(fanSpeed);
  sensors.begin();              // Start up the DS18B20 Temp library
  pinMode(fanPWMpin, OUTPUT);
    checkTemp();
And here's the script after my edits. I've highlighted the sections I inserted the best I could.
// Typhon firmware
// v0.3 alpha 2011-16-11
// N. Enders, R. Ensminger
// This sketch provides firmware for the Typhon LED controller.
// It provides a structure to fade 4 independent channels of LED lighting
// on and off each day, to simulate sunrise and sunset.
// Current work in progress:
// - store all LED variables in EEPROM so they are not reset by a loss of power
// - allow for signals to be inverted for buckpucks or other drivers that consider 0 to be "on"
// Future developments may include:
// - moon phase simulation
// - storm simulation
// - support for plugin hardware modules for temperature, pH, relay control, etc.
// Sketch developed in Arduino-22
// Requires LiquidCrystal, Wire, EEPROM, EEPROMVar, and Button libraries.
// Button is available here: http://www.arduino.cc/playground/Code/Button
// EEPROMVar is available here: http://www.arduino.cc/playground/uploads/Profiles/EEPROMVar_01.zip
// include the libraries:
#include <LiquidCrystal.h>
#include <Wire.h>
#include <Button.h>
#include <EEPROM.h>
#include <EEPROMVar.h>
//////////////////////////////////////// <------------------------------ Setup DS18B20 Sensor
#define ONE_WIRE_BUS 11 //Define the pin of the DS18B20
int fanPWMpin = 12;    //Define the pin of the Fan
/**** Define Variables & Constants ****/
// set the RTC's I2C address
#define DS1307_I2C_ADDRESS 0x68
// create the LCD
LiquidCrystal lcd(8, 7, 5, 4, 3, 2);
// set up backlight
int bkl         = 6;        // backlight pin
byte bklIdle    = 10;       // PWM value for backlight at idle
byte bklOn      = 70;       // PWM value for backlight when on
int bklDelay    = 10000;    // ms for the backlight to idle before turning off
unsigned long bklTime = 0;  // counter since backlight turned on
// create the menu counter
int menuCount   = 1;
int menuSelect = 0;
//create the plus and minus navigation delay counter with its initial maximum of 250.
byte btnMaxDelay = 200;
byte btnMinDelay = 25;
byte btnMaxIteration = 5;
byte btnCurrIteration;
//create manual override variables
boolean override = false;
byte overmenu = 0;
int overpercent = 0;
// create the buttons
Button menu     = Button(14);
Button select   = Button(15);
Button plus     = Button(16);
Button minus    = Button(17);
// LED variables. These control the behavior of lighting. Change these to customize behavoir
int minCounter = 0;         // counter that resets at midnight.
int oldMinCounter = 0;      // counter that resets at midnight.
int oneLed = 7;             // pin for channel 1
int twoLed = 8;            // pin for channel 2
int threeLed = 9;          // pin for channel 3
int fourLed = 10;            // pin for channel 4
int oneVal = 0;             // current value for channel 1
int twoVal = 0;             // current value for channel 2
int threeVal = 0;           // current value for channel 3
int fourVal = 0;            // current value for channel 4
// Variables making use of EEPROM memory:
EEPROMVar<int> oneStartMins = 750;      // minute to start this channel.
EEPROMVar<int> onePhotoPeriod = 720;   // photoperiod in minutes for this channel.
EEPROMVar<int> oneMax = 100;           // max intensity for this channel, as a percentage
EEPROMVar<int> oneFadeDuration = 60;   // duration of the fade on and off for sunrise and sunset for
                                       //    this channel.
EEPROMVar<int> twoStartMins = 810;
EEPROMVar<int> twoPhotoPeriod = 600;
EEPROMVar<int> twoMax = 100;
EEPROMVar<int> twoFadeDuration = 60;
EEPROMVar<int> threeStartMins = 810;
EEPROMVar<int> threePhotoPeriod = 600;
EEPROMVar<int> threeMax = 100;
EEPROMVar<int> threeFadeDuration = 60;
EEPROMVar<int> fourStartMins = 480;
EEPROMVar<int> fourPhotoPeriod = 510;
EEPROMVar<int> fourMax = 100;
EEPROMVar<int> fourFadeDuration = 60;
// variables to invert the output PWM signal,
// for use with drivers that consider 0 to be "on"
// i.e. buckpucks. If you need to provide an inverted
// signal on any channel, set the appropriate variable to true.
boolean oneInverted = false;
boolean twoInverted = false;
boolean threeInverted = false;
boolean fourInverted = false;
/****** RTC Functions ******/
// Convert decimal numbers to binary coded decimal
byte decToBcd(byte val)
  return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to decimal numbers
byte bcdToDec(byte val)
  return ( (val/16*10) + (val%16) );
// Sets date and time, starts the clock
void setDate(byte second,        // 0-59
             byte minute,        // 0-59
             byte hour,          // 1-23
             byte dayOfWeek,     // 1-7
             byte dayOfMonth,    // 1-31
             byte month,         // 1-12
             byte year)          // 0-99
   Wire.beginTransmission(DS1307_I2C_ADDRESS);
   Wire.write(0);
   Wire.write(decToBcd(second));
   Wire.write(decToBcd(minute));
   Wire.write(decToBcd(hour));
   Wire.write(decToBcd(dayOfWeek));
   Wire.write(decToBcd(dayOfMonth));
   Wire.write(decToBcd(month));
   Wire.write(decToBcd(year));
   Wire.endTransmission();
// Gets the date and time
void getDate(byte *second,
             byte *minute,
             byte *hour,
             byte *dayOfWeek,
             byte *dayOfMonth,
             byte *month,
             byte *year)
  Wire.write(0);
  Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
  *second     = bcdToDec(Wire.read() & 0x7f);
  *minute     = bcdToDec(Wire.read());
  *hour       = bcdToDec(Wire.read() & 0x3f);
  *dayOfWeek  = bcdToDec(Wire.read());
  *dayOfMonth = bcdToDec(Wire.read());
  *month      = bcdToDec(Wire.read());
  *year       = bcdToDec(Wire.read());
/****** LED Functions ******/
//function to set LED brightness according to time of day
//function has three equal phases - ramp up, hold, and ramp down
int   setLed(int mins,         // current time in minutes
            int ledPin,        // pin for this channel of LEDs
            int start,         // start time for this channel of LEDs
            int period,        // photoperiod for this channel of LEDs
            int fade,          // fade duration for this channel of LEDs
            int ledMax,        // max value for this channel
            boolean inverted   // true if the channel is inverted
  int val = 0;
      //fade up
      if (mins > start || mins <= start + fade)  {
        val = map(mins - start, 0, fade, 0, ledMax);
      //fade down
      if (mins > start + period - fade && mins <= start + period)  {
        val = map(mins - (start + period - fade), 0, fade, ledMax, 0);
      //off or post-midnight run.
      if (mins <= start || mins > start + period)  {
        if((start+period)%1440 < start && (start + period)%1440 > mins )
            val=map((start+period-mins)%1440,0,fade,0,ledMax);
        val = 0;
    if (val > ledMax)  {val = ledMax;}
    if (val < 0) {val = 0; }
  if (inverted) {analogWrite(ledPin, map(val, 0, 100, 255, 0));}
  else {analogWrite(ledPin, map(val, 0, 100, 0, 255));}
  if(override){val=overpercent;}
  return val;
/**** Display Functions ****/
//button hold function
int btnCurrDelay(byte curr)
  if(curr==btnMaxIteration)
    btnCurrIteration = btnMaxIteration;
    return btnMaxDelay;
  else if(btnCurrIteration ==0)
    return btnMinDelay;
    btnCurrIteration--;
    return btnMaxDelay;
// format a number of minutes into a readable time (24 hr format)
void printMins(int mins,       //time in minutes to print
               boolean ampm    //print am/pm?
  int hr = (mins%1440)/60;
  int mn = mins%60;
    if(hr<10){
      lcd.print(" ");
    lcd.print(hr);
    lcd.print(":");
    if(mn<10){
      lcd.print("0");
    lcd.print(mn);
// format hours, mins, secs into a readable time (24 hr format)
void printHMS (byte hr,
               byte mn,
               byte sec      //time to print
    if(hr<10){
      lcd.print(" ");
    lcd.print(hr, DEC);
    lcd.print(":");
    if(mn<10){
      lcd.print("0");
    lcd.print(mn, DEC);
    lcd.print(":");
    if(sec<10){
      lcd.print("0");
    lcd.print(sec, DEC);
void ovrSetAll(int pct){
    analogWrite(oneLed,map(pct,0,100,0,255));
    analogWrite(twoLed,map(pct,0,100,0,255));
    analogWrite(threeLed,map(pct,0,100,0,255));
    analogWrite(fourLed,map(pct,0,100,0,255));
void checkTemp() //////////////////////<------------------------------------------- Check Temperature
delay(250);
  //lcd.print("F");
  //lcd.print("F");
  if (fanSpeed<=0)
     fanSpeed = 0;
  if (fanSpeed>255)
     fanSpeed=255;
/**** Setup ****/
  Wire.begin();
  pinMode(bkl, OUTPUT);
  lcd.begin(20, 4);
  digitalWrite(bkl, HIGH);
  lcd.print("Typhon-Reef");
  lcd.setCursor(0,1);
  lcd.print("");
  delay(5000);
  lcd.clear();
  analogWrite(bkl,bklIdle);
/***** Loop *****/
  byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
  getDate(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year);
  oldMinCounter = minCounter;
  minCounter = hour * 60 + minute;
    checkTemp();  ////////////// <----------------------- Check Temp
  //reset plus & minus acceleration counters if the button's state has changed
  if(plus.stateChanged())
   btnCurrDelay(btnMaxIteration);
  if(minus.stateChanged())
  //check & set fade durations
  if(oneFadeDuration > onePhotoPeriod/2 && onePhotoPeriod >0){oneFadeDuration = onePhotoPeriod/2;}
  if(oneFadeDuration<1){oneFadeDuration=1;}
  if(twoFadeDuration > twoPhotoPeriod/2 && twoPhotoPeriod >0){twoFadeDuration = twoPhotoPeriod/2;}
  if(twoFadeDuration<1){twoFadeDuration=1;}
  if(threeFadeDuration > threePhotoPeriod/2 && threePhotoPeriod >0){threeFadeDuration = threePhotoPeriod/2;}
  if(threeFadeDuration<1){threeFadeDuration=1;}
  if(fourFadeDuration > fourPhotoPeriod/2 && fourPhotoPeriod > 0){fourFadeDuration = fourPhotoPeriod/2;}
  if(fourFadeDuration<1){fourFadeDuration=1;}
  //check & set any time functions
  //set outputs
  if(!override){
  oneVal = setLed(minCounter, oneLed, oneStartMins, onePhotoPeriod, oneFadeDuration, oneMax, oneInverted);
  twoVal = setLed(minCounter, twoLed, twoStartMins, twoPhotoPeriod, twoFadeDuration, twoMax, twoInverted);
  threeVal = setLed(minCounter, threeLed, threeStartMins, threePhotoPeriod, threeFadeDuration, threeMax, threeInverted);
  fourVal = setLed(minCounter, fourLed, fourStartMins, fourPhotoPeriod, fourFadeDuration, fourMax, fourInverted);
  else{
    ovrSetAll(overpercent);
  //turn the backlight off and reset the menu if the idle time has elapsed
  if(bklTime + bklDelay < millis() && bklTime > 0 ){
    menuCount = 1;
    lcd.clear();
    bklTime = 0;
  //iterate through the menus
  if(menu.uniquePress()){
    analogWrite(bkl,bklOn);
    bklTime = millis();
    if(menuCount < 20){
      menuCount++;
    }else {
      menuCount = 1;
  lcd.clear();
  if(menuCount == 1){
    //main screen turn on!!!
    if (minCounter > oldMinCounter){
      lcd.clear();
    lcd.setCursor(0,0);
    printHMS(hour, minute, second);
    lcd.setCursor(0, 1);
    lcd.print("LED: ");
    lcd.print(sensors.getTempFByIndex(0)); //////////////////// Display Temp ///////////////////////
    lcd.print("F");
    lcd.setCursor(0,3);
    lcd.print(oneVal);
    lcd.setCursor(4,3);
    lcd.print(twoVal);
    lcd.setCursor(8,3);
    lcd.print(threeVal);
    lcd.setCursor(12,3);
    lcd.print(fourVal);
    //debugging function to use the select button to advance the timer by 1 minute
    //if(select.uniquePress()){setDate(second, minute+1, hour, dayOfWeek, dayOfMonth, month, year);}
  if(menuCount == 2){
    //Manual Override Menu
    lcd.setCursor(0,0);
    lcd.print("Manual Overrides");
    lcd.setCursor(0,1);
    lcd.print("All: ");
      if(menuSelect < 3){menuSelect++;}
      else{menuSelect = 0;}
      bklTime = millis();
    if(menuSelect == 0){
      lcd.print("Timer");
      override = false;}
    if(menuSelect == 1){
      lcd.print("ON   ");
      overpercent = 100;
      override = true;}
    if(menuSelect == 2){
      lcd.print("OFF  ");
      overpercent = 0;
      override = true;}
    if(menuSelect == 3){
      override = true;
      lcd.print(overpercent,DEC);
      lcd.print("%  ");
      if(plus.isPressed() && overpercent <100)
          overpercent++;
          delay(btnCurrDelay(btnCurrIteration-1));
          bklTime = millis();
        if(minus.isPressed() && overpercent > 0)
          overpercent--;
          bklTime = millis();
  if(menuCount == 3){
    //set start time for channel one
    lcd.setCursor(0,0);
    lcd.print("Channel 1 Start");
    lcd.setCursor(0,1);
    printMins(oneStartMins, true);
    if(plus.isPressed() && oneStartMins < 1440){
        oneStartMins++;
        if(onePhotoPeriod >0){onePhotoPeriod--;}
        else{onePhotoPeriod=1439;}
      bklTime = millis();
    if(minus.isPressed() && oneStartMins > 0){
        oneStartMins--;
        if(onePhotoPeriod<1439){onePhotoPeriod++;}
        else{onePhotoPeriod=0;}
      bklTime = millis();
  if(menuCount == 4){
    //set end time for channel one
    lcd.setCursor(0,0);
    lcd.print("Channel 1 End");
    lcd.setCursor(0,1);
    printMins(oneStartMins+onePhotoPeriod, true);
    if(plus.isPressed()){
      if(onePhotoPeriod < 1439){
      onePhotoPeriod++;}
      else{
        onePhotoPeriod=0;
      bklTime = millis();
    if(minus.isPressed()){
        onePhotoPeriod--;}
      else{
      bklTime = millis();
  if(menuCount == 5){
    //set fade duration for channel one
    lcd.setCursor(0,0);
    lcd.print("Channel 1 Fade");
    lcd.setCursor(0,1);
    printMins(oneFadeDuration, false);
    if(plus.isPressed() && (oneFadeDuration < onePhotoPeriod/2 || oneFadeDuration == 0)){
      oneFadeDuration++;
      bklTime = millis();
    if(minus.isPressed() && oneFadeDuration > 1){
      oneFadeDuration--;
      bklTime = millis();
  if(menuCount == 6){
    //set intensity for channel one
    lcd.setCursor(0,0);
    lcd.print("Channel 1 Max");
    lcd.setCursor(1,1);
    lcd.print(oneMax);
    lcd.print("  ");
    if(plus.isPressed() && oneMax < 100){
      oneMax++;
      bklTime = millis();
    if(minus.isPressed() && oneMax > 0){
      oneMax--;
      bklTime = millis();
  if(menuCount == 7){
    //set start time for channel two
    lcd.setCursor(0,0);
    lcd.print("Channel 2 Start");
    lcd.setCursor(0,1);
    printMins(twoStartMins, true);
    if(plus.isPressed() && twoStartMins < 1440){
        twoStartMins++;
        if(twoPhotoPeriod >0){twoPhotoPeriod--;}
        else{twoPhotoPeriod=1439;}
      bklTime = millis();
    if(minus.isPressed() && twoStartMins > 0){
        twoStartMins--;
        if(twoPhotoPeriod<1439){twoPhotoPeriod++;}
        else{twoPhotoPeriod=0;}
      bklTime = millis();
  if(menuCount == 8){
    //set end time for channel two
    lcd.setCursor(0,0);
    lcd.print("Channel 2 End");
    lcd.setCursor(0,1);
    printMins(twoStartMins+twoPhotoPeriod, true);
      if(twoPhotoPeriod < 1439){
      twoPhotoPeriod++;}
      else{
        twoPhotoPeriod=0;
      bklTime = millis();
        twoPhotoPeriod--;}
      else{
      bklTime = millis();
  if(menuCount == 9){
    //set fade duration for channel two
    lcd.setCursor(0,0);
    lcd.print("Channel 2 Fade");
    lcd.setCursor(0,1);
    printMins(twoFadeDuration, false);
    if(plus.isPressed() && (twoFadeDuration < twoPhotoPeriod/2 || twoFadeDuration == 0)){
      twoFadeDuration++;
      bklTime = millis();
    if(minus.isPressed() && twoFadeDuration > 1){
      twoFadeDuration--;
      bklTime = millis();
  if(menuCount == 10){
    //set intensity for channel two
    lcd.setCursor(0,0);
    lcd.print("Channel 2 Max");
    lcd.setCursor(1,1);
    lcd.print(twoMax);
    lcd.print("  ");
    if(plus.isPressed() && twoMax < 100){
      twoMax++;
      bklTime = millis();
    if(minus.isPressed() && twoMax > 0){
      twoMax--;
      bklTime = millis();
  if(menuCount == 11){
    //set start time for channel three
    lcd.setCursor(0,0);
    lcd.print("Channel 3 Start");
    lcd.setCursor(0,1);
    printMins(threeStartMins, true);
    if(plus.isPressed() && threeStartMins < 1440){
        threeStartMins++;
        if(threePhotoPeriod >0){threePhotoPeriod--;}
        else{threePhotoPeriod=1439;}
      bklTime = millis();
    if(minus.isPressed() && threeStartMins > 0){
        threeStartMins--;
        if(threePhotoPeriod<1439){threePhotoPeriod++;}
        else{threePhotoPeriod=0;}
      bklTime = millis();
  if(menuCount == 12){
    //set end time for channel three
    lcd.setCursor(0,0);
    lcd.print("Channel 3 End");
    lcd.setCursor(0,1);
    printMins(threeStartMins+threePhotoPeriod, true);
      if(threePhotoPeriod < 1439){
      else{
        threePhotoPeriod=0;
      bklTime = millis();
      else{
      bklTime = millis();
  if(menuCount == 13){
    //set fade duration for channel three
    lcd.setCursor(0,0);
    lcd.print("Channel 3 Fade");
    lcd.setCursor(0,1);
    printMins(threeFadeDuration, false);
    if(plus.isPressed() && (threeFadeDuration < threePhotoPeriod/2 || threeFadeDuration == 0)){
      threeFadeDuration++;
      bklTime = millis();
    if(minus.isPressed() && threeFadeDuration > 1){
      threeFadeDuration--;
      bklTime = millis();
  if(menuCount == 14){
    //set intensity for channel three
    lcd.setCursor(0,0);
    lcd.print("Channel 3 Max");
    lcd.setCursor(1,1);
    lcd.print(threeMax);
    lcd.print("  ");
    if(plus.isPressed() && threeMax < 100){
      threeMax++;
      bklTime = millis();
    if(minus.isPressed() && threeMax > 0){
      threeMax--;
      bklTime = millis();
  if(menuCount == 15){
    //set start time for channel four
    lcd.setCursor(0,0);
    lcd.print("Channel 4 Start");
    lcd.setCursor(0,1);
    printMins(fourStartMins, true);
    if(plus.isPressed() && fourStartMins < 1440){
        fourStartMins++;
        if(fourPhotoPeriod >0){fourPhotoPeriod--;}
        else{fourPhotoPeriod=1439;}
      bklTime = millis();
    if(minus.isPressed() && fourStartMins > 0){
        fourStartMins--;
        if(fourPhotoPeriod<1439){fourPhotoPeriod++;}
        else{fourPhotoPeriod=0;}
      bklTime = millis();
  if(menuCount == 16){
    //set end time for channel four
    lcd.setCursor(0,0);
    lcd.print("Channel 4 End");
    lcd.setCursor(0,1);
    printMins(fourStartMins+fourPhotoPeriod, true);
      if(fourPhotoPeriod < 1439){
      fourPhotoPeriod++;}
      else{
        fourPhotoPeriod=0;
      bklTime = millis();
        fourPhotoPeriod--;}
      else{
      bklTime = millis();
  if(menuCount == 17){
    //set fade duration for channel four
    lcd.setCursor(0,0);
    lcd.print("Channel 4 Fade");
    lcd.setCursor(0,1);
    printMins(fourFadeDuration, false);
    if(plus.isPressed() && (fourFadeDuration < fourPhotoPeriod/2 || fourFadeDuration == 0)){
      fourFadeDuration++;
      bklTime = millis();
    if(minus.isPressed() && fourFadeDuration > 1){
      fourFadeDuration--;
      bklTime = millis();
  if(menuCount == 18){
    //set intensity for channel four
    lcd.setCursor(0,0);
    lcd.print("Channel 4 Max");
    lcd.setCursor(1,1);
    lcd.print(fourMax);
    lcd.print("   ");
    if(plus.isPressed() && fourMax < 100){
      fourMax++;
      bklTime = millis();
    if(minus.isPressed() && fourMax > 0){
      fourMax--;
      bklTime = millis();
  if(menuCount == 19){
    //set hours
    lcd.setCursor(0,0);
    lcd.print("Set Time: Hrs");
    lcd.setCursor(0,1);
    if(plus.isPressed() && hour < 23){
      hour++;
      bklTime = millis();
    if(minus.isPressed() && hour > 0){
      hour--;
      bklTime = millis();
  setDate(second, minute, hour, dayOfWeek, dayOfMonth, month, year);
  if(menuCount == 20){
    //set minutes
    lcd.setCursor(0,0);
    lcd.print("Set Time: Mins");
    lcd.setCursor(0,1);
    if(plus.isPressed() && minute < 59){
      minute++;
      bklTime = millis();
    if(minus.isPressed() && minute > 0){
      minute--;
      bklTime = millis();
Any help appreciated. Thanks.
1. Which Arduino (UNO/NANO/MEGA) are you using?
2. At which DPin you have connected the Button?
3. What does the Button do?
4. How do you want your fan behaving in response to temperature change?
This delay may be killing you. I have not read your code, but there is a way to use the temperature sensor so it does its work in the background.
void checkTemp()
delay(250);
The idea is you say you want a new reading, then go about your business and come back and check to see if the new reading is ready. Something like that.
I googled
dht18b20 non-blocking arduino
this was amongst the hits, poke around
a7
Thanks alto777.
Digging around the original thread for that script, I found one of my older posts with my own temp read code, but it's just to display temp, not PWM the fans. But... it works, and so do the buttons. Now I just need to figure out how to insert the fan section.
Code I added:
#define ONE_WIRE_BUS 2                  //data wire for temperature probes.
#define TEMPERATURE_PRECISION 9
DeviceAddress TempSense_1, TempSense_2, TempSense_3;
//////////////   TEMPERATURE   //////////////
void printAddress(DeviceAddress deviceAddress)
	for (uint8_t i = 0; i < 8; i++)
		// zero pad the address if necessary
		if (deviceAddress[i] < 16) Serial.print("0");
		Serial.print(deviceAddress[i], HEX);
void printTemperature(DeviceAddress deviceAddress)
	float tempC = sensors.getTempC(deviceAddress);
	lcd.print(DallasTemperature::toFahrenheit(tempC), 1);
void printData(DeviceAddress deviceAddress)
	Serial.print(" ");
	printTemperature(deviceAddress);
//////////////    Get temp data from DS18B20   //////////////
	sensors.begin();
	if (!sensors.getAddress(TempSense_1, 0));
	if (!sensors.getAddress(TempSense_2, 1));
	if (!sensors.getAddress(TempSense_3, 2));
	sensors.setResolution(TempSense_1, 9);
	sensors.setResolution(TempSense_2, 9);
	sensors.setResolution(TempSense_3, 9);
//////////////    Display HeatSink Temperature   //////////////
		lcd.setCursor(0,2);
		lcd.print("Temp1");
		lcd.setCursor(0,3);
		printData(TempSense_1);
		lcd.print((char)223); //print degree symbol °
		lcd.print("F ");
		lcd.setCursor(7,2);
		lcd.print("Temp2");
		lcd.setCursor(7,3);
		printData(TempSense_2);
		lcd.print((char)223); // print degree symbol °
		lcd.print("F ");
		lcd.setCursor(14,2);
		lcd.print("Temp3");
		lcd.setCursor(14,3);
		printData(TempSense_3);
		lcd.print("F");
               if((StartMins < minCounter && StopMins >= minCounter)) {
                  lcd.setCursor(16,0);
                  lcd.print("ON ");
	          else{
                  lcd.print("OFF");
And the moified script:
// Typhon firmware
#include <Wire.h>
#include <Button.h>
#include <EEPROM.h>
#include <DallasTemperature.h>
#include <OneWire.h>
#define ONE_WIRE_BUS 11                  //data wire for temperature probes.
// create the LCD
// set up backlight
int menuCount   = 1;
int menuSelect = 0;
byte overmenu = 0;
int oneLed = 9;             // pin for channel 1
int twoLed = 10;            // pin for channel 2
int threeLed = 11;          // pin for channel 3
int fourLed = 3;            // pin for channel 4
                                       //    this channel.
             byte hour,          // 1-23
             byte month,         // 1-12
             byte year)          // 0-99
   Wire.write(0);
             byte *minute,
             byte *hour,
             byte *dayOfWeek,
             byte *dayOfMonth,
             byte *month,
             byte *year)
  Wire.write(0);
  int val = 0;
      //fade up
      //fade down
        val = 0;
  return val;
    return btnMaxDelay;
    return btnMinDelay;
    btnCurrIteration--;
    return btnMaxDelay;
  int mn = mins%60;
    if(hr<10){
      lcd.print(" ");
    lcd.print(hr);
    lcd.print(":");
    if(mn<10){
      lcd.print("0");
    lcd.print(mn);
               byte mn,
    if(hr<10){
      lcd.print(" ");
    lcd.print(hr, DEC);
    lcd.print(":");
    if(mn<10){
      lcd.print("0");
    lcd.print(mn, DEC);
    lcd.print(":");
    if(sec<10){
      lcd.print("0");
  Serial.print(" ");
/**** Setup ****/
  Wire.begin();
  lcd.begin(20, 4);
  lcd.setCursor(0,1);
  lcd.print("");
  delay(5000);
  lcd.clear();
  sensors.begin();
/***** Loop *****/
  //set outputs
  if(!override){
  else{
    menuCount = 1;
    lcd.clear();
    bklTime = 0;
    bklTime = millis();
    if(menuCount < 20){
      menuCount++;
    }else {
      menuCount = 1;
  lcd.clear();
  if(menuCount == 1){
      lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,3);
    lcd.print(oneVal);
    lcd.setCursor(4,3);
    lcd.print(twoVal);
    lcd.setCursor(8,3);
    lcd.print(fourVal);
lcd.setCursor(0,1);
    lcd.print("LED: ");
    lcd.setCursor(10,1);
    lcd.print("F ");
  if(menuCount == 2){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("All: ");
      bklTime = millis();
      lcd.print("Timer");
      override = false;}
      lcd.print("ON   ");
      overpercent = 100;
      override = true;}
      lcd.print("OFF  ");
      overpercent = 0;
      override = true;}
      override = true;
      lcd.print("%  ");
          overpercent++;
          bklTime = millis();
          overpercent--;
          bklTime = millis();
  if(menuCount == 3){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
        oneStartMins++;
      bklTime = millis();
        oneStartMins--;
      bklTime = millis();
  if(menuCount == 4){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      onePhotoPeriod++;}
      else{
        onePhotoPeriod=0;
      bklTime = millis();
        onePhotoPeriod--;}
      else{
      bklTime = millis();
  if(menuCount == 5){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      oneFadeDuration++;
      bklTime = millis();
      oneFadeDuration--;
      bklTime = millis();
  if(menuCount == 6){
    lcd.setCursor(0,0);
    lcd.setCursor(1,1);
    lcd.print(oneMax);
    lcd.print("  ");
      oneMax++;
      bklTime = millis();
      oneMax--;
      bklTime = millis();
  if(menuCount == 7){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
        twoStartMins++;
      bklTime = millis();
        twoStartMins--;
      bklTime = millis();
  if(menuCount == 8){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      twoPhotoPeriod++;}
      else{
        twoPhotoPeriod=0;
      bklTime = millis();
        twoPhotoPeriod--;}
      else{
      bklTime = millis();
  if(menuCount == 9){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      twoFadeDuration++;
      bklTime = millis();
      twoFadeDuration--;
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(1,1);
    lcd.print(twoMax);
    lcd.print("  ");
      twoMax++;
      bklTime = millis();
      twoMax--;
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
        threeStartMins++;
      bklTime = millis();
        threeStartMins--;
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      else{
        threePhotoPeriod=0;
      bklTime = millis();
      else{
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      bklTime = millis();
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(1,1);
    lcd.print("  ");
      threeMax++;
      bklTime = millis();
      threeMax--;
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
        fourStartMins++;
      bklTime = millis();
        fourStartMins--;
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      fourPhotoPeriod++;}
      else{
        fourPhotoPeriod=0;
      bklTime = millis();
        fourPhotoPeriod--;}
      else{
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      fourFadeDuration++;
      bklTime = millis();
      fourFadeDuration--;
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(1,1);
    lcd.print(fourMax);
    lcd.print("   ");
      fourMax++;
      bklTime = millis();
      fourMax--;
      bklTime = millis();
    //set hours
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      hour++;
      bklTime = millis();
      hour--;
      bklTime = millis();
    //set minutes
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      minute++;
      bklTime = millis();
      minute--;
      bklTime = millis();
I keep calling it a script, but I guess the proper term is sketch. :-p
I do not see where you are doing the sensing in a non-blocking manner. I am in transit and have a poor view of the code. Tiny window. Everyone missed my hints about the Christmas present I wanted.
But never mind that. Please say what means the buttons don't work: they do nothing? Or they operate in an unsatisfactory manner?
a7
The menu button doesn't do anything unless held down for a few seconds, then stops after a few clicks... then the screen to set the start time for the first LED channel slowly increases even though no buttons are being pressed. They work fine without the sensor.
The code I just posted works, but just to read and display the temp, not PWM the fans on the heatsink. I just worked the PWM section into the script, but I need to set up an LED to see if fan pin's doing anything yet.
I'm using a Nano, and in the script it shows Buttons on 14, 15, 16, and 17, and One_Wire_BUS on 11, with fan pin set for 12. I want fan to speed up at a certain temp. The temps aren't set in stone yet, the code shared with me was just an example.
Well... connected resistor and LED to Pin12 as set in the sketch, then dropped the temp in the script from 97.0 to 60.0... LED doesn't turn on. Blah.
// Typhon firmware
#include <Wire.h>
#include <Button.h>
#include <EEPROM.h>
const int HtempMin = 60.0;    //Define temp when heatsink fan starts
// create the LCD
// set up backlight
int menuCount   = 1;
int menuSelect = 0;
byte overmenu = 0;
                                       //    this channel.
             byte hour,          // 1-23
             byte month,         // 1-12
             byte year)          // 0-99
   Wire.write(0);
             byte *minute,
             byte *hour,
             byte *dayOfWeek,
             byte *dayOfMonth,
             byte *month,
             byte *year)
  Wire.write(0);
  int val = 0;
      //fade up
      //fade down
        val = 0;
  return val;
    return btnMaxDelay;
    return btnMinDelay;
    btnCurrIteration--;
    return btnMaxDelay;
  int mn = mins%60;
    if(hr<10){
      lcd.print(" ");
    lcd.print(hr);
    lcd.print(":");
    if(mn<10){
      lcd.print("0");
    lcd.print(mn);
               byte mn,
    if(hr<10){
      lcd.print(" ");
    lcd.print(hr, DEC);
    lcd.print(":");
    if(mn<10){
      lcd.print("0");
    lcd.print(mn, DEC);
    lcd.print(":");
    if(sec<10){
      lcd.print("0");
  Serial.print(" ");
/**** Setup ****/
  Wire.begin();
  lcd.begin(20, 4);
  lcd.setCursor(0,1);
  lcd.print("");
  delay(5000);
  lcd.clear();
  sensors.begin();
  if (fanSpeed<=0)
     fanSpeed = 0;
  if (fanSpeed>255)
     fanSpeed=255;
/***** Loop *****/
  //set outputs
  if(!override){
  else{
    menuCount = 1;
    lcd.clear();
    bklTime = 0;
    bklTime = millis();
    if(menuCount < 20){
      menuCount++;
    }else {
      menuCount = 1;
  lcd.clear();
  if(menuCount == 1){
      lcd.clear();
    lcd.setCursor(0,0);
    lcd.setCursor(0,3);
    lcd.print(oneVal);
    lcd.setCursor(4,3);
    lcd.print(twoVal);
    lcd.setCursor(8,3);
    lcd.print(fourVal);
lcd.setCursor(0,1);
    lcd.print("LED: ");
    lcd.print("F ");
  if(menuCount == 2){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
    lcd.print("All: ");
      bklTime = millis();
      lcd.print("Timer");
      override = false;}
      lcd.print("ON   ");
      overpercent = 100;
      override = true;}
      lcd.print("OFF  ");
      overpercent = 0;
      override = true;}
      override = true;
      lcd.print("%  ");
          overpercent++;
          bklTime = millis();
          overpercent--;
          bklTime = millis();
  if(menuCount == 3){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
        oneStartMins++;
      bklTime = millis();
        oneStartMins--;
      bklTime = millis();
  if(menuCount == 4){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      onePhotoPeriod++;}
      else{
        onePhotoPeriod=0;
      bklTime = millis();
        onePhotoPeriod--;}
      else{
      bklTime = millis();
  if(menuCount == 5){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      oneFadeDuration++;
      bklTime = millis();
      oneFadeDuration--;
      bklTime = millis();
  if(menuCount == 6){
    lcd.setCursor(0,0);
    lcd.setCursor(1,1);
    lcd.print(oneMax);
    lcd.print("  ");
      oneMax++;
      bklTime = millis();
      oneMax--;
      bklTime = millis();
  if(menuCount == 7){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
        twoStartMins++;
      bklTime = millis();
        twoStartMins--;
      bklTime = millis();
  if(menuCount == 8){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      twoPhotoPeriod++;}
      else{
        twoPhotoPeriod=0;
      bklTime = millis();
        twoPhotoPeriod--;}
      else{
      bklTime = millis();
  if(menuCount == 9){
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      twoFadeDuration++;
      bklTime = millis();
      twoFadeDuration--;
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(1,1);
    lcd.print(twoMax);
    lcd.print("  ");
      twoMax++;
      bklTime = millis();
      twoMax--;
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
        threeStartMins++;
      bklTime = millis();
        threeStartMins--;
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      else{
        threePhotoPeriod=0;
      bklTime = millis();
      else{
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      bklTime = millis();
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(1,1);
    lcd.print("  ");
      threeMax++;
      bklTime = millis();
      threeMax--;
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
        fourStartMins++;
      bklTime = millis();
        fourStartMins--;
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      fourPhotoPeriod++;}
      else{
        fourPhotoPeriod=0;
      bklTime = millis();
        fourPhotoPeriod--;}
      else{
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      fourFadeDuration++;
      bklTime = millis();
      fourFadeDuration--;
      bklTime = millis();
    lcd.setCursor(0,0);
    lcd.setCursor(1,1);
    lcd.print(fourMax);
    lcd.print("   ");
      fourMax++;
      bklTime = millis();
      fourMax--;
      bklTime = millis();
    //set hours
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      hour++;
      bklTime = millis();
      hour--;
      bklTime = millis();
    //set minutes
    lcd.setCursor(0,0);
    lcd.setCursor(0,1);
      minute++;
      bklTime = millis();
      minute--;
      bklTime = millis();
Holy crap... that was it! I started with 100, still sluggish. Then 50... but it would still pause after a few seconds, then start up again. Then I tried 10... it's working just fine. Thank you very much. :slight_smile:
Edit... well, temp sense works fine, but the LED on the fan pin still doesn't kick in.
If you are not using the non-blocking method of reading the temperature sensors, the call to requestTemperatures() will take 94mS with the resolution set to 9 bits, hardly seems necessary to have an additional delay.
I have absolutely no idea what a non-blocking method is. I'm not a coder... the best I can do are basic batch files and shell scripts, and possibly modify someone else's script if it's not too difficult. I did not write the original script or the temp sense and fan PWM sections, so I have no idea what to change. But trying a delay of 94, and it still hangs. Even at 50 it hangs. 10 seems to be working just fine.
Have you tried removing the delay entirely?
I didn't know that was even an option. Tried just now... temp display flickers as it's constantly changing.
I'll probably just read and display the temp as a way to monitor it. I'm using Noctua fans, so they're pretty quiet as it is.
When I say I'm not a coder, but can sometimes edit someone else's script to do what I want... I'm not smart enough to hook in a relay on a timed schedule to power a pump for 15 minutes every 4 hours, but I can manipulate this script by adding extra LED channels in the script, but tie them to the same pin, then stagger the start end end times so they don't overlap. I already figured out how to disable the actual fade portion, without breaking the rest of the script.
analogWrite(oneLed, map(pct, 0, 100, 0, 255));
Becomes...
analogWrite(oneLed, map(pct, 0, 1, 0, 1));
And it kicks in at 100%. That's all I need to work with.
Again I am unable to look closely at the code, but if you are clearing the entire display and then writing, and doing that frequently, it will look bad. It will be half-done all the time.
So… arrange to do that on a schedule, like once a second. The big flash will be less unpleasant.
Or, just position the cursor and write only the few characters that are the temperature. You can write blanks sufficient to cover the entire width of the area reserved for the temperature.
a7
Thanks alto777, I'll keep playing with it. At 10 it seems to be fine, unless you know of a reason not to(?).
Edit: actually, I'm using the 2nd version of code that only reads and displays the temp, no fan PWM control. It doesn't have a delay.
Writing non-blocking code is an essential skill to acquire if you're going to do anything useful in Arduino-land.
Normally when you call the getSensorTemperature() function, the library waits (i.e. blocks all your other code from running) for up to 750 ms (depending on the conversion resolution you have set) while the DS18B20 device performs the A2D conversion on the sensed temperature. Your code can do absolutely nothing (sense buttons, update displays, etc) during this time.
However, the library has a non-blocking mode that allows your code to do useful stuff while the A2D conversion is taking place. Here's an example I wrote a while ago. I demonstrates reading two temp sensors once per second. Your code can do other work during the conversion period.
#include <Arduino.h>
const uint8_t oneWireBus {2};
const uint8_t tempPrecision {9};
const uint8_t numSensors {2};
struct TempSensorInfo {
	DeviceAddress address;
	int16_t lastReadingRaw;
	float lastReadingC;
void getSensorTemperature(TempSensorInfo &tempSensor);
void printAddress(DeviceAddress &addr);
void printTemperatures();
TempSensorInfo sensorArray[numSensors];
OneWire oneWire(oneWireBus);
	delay(2000);
	sensors.begin();
	Serial.println("Gathering device addresses:");
	for (auto &sensor : sensorArray) {
		static uint8_t index {0};
		if (!sensors.getAddress(sensor.address, index)) {
			Serial.print("Failed to get address for sensor # ");
			Serial.print(index);
			Serial.println(".  -- Aborting");
			while (1) {
		Serial.print("Sensor # ");
		Serial.print(index++);
		Serial.print(" Address = ");
		printAddress(sensor.address);
		sensors.setResolution(sensor.address, tempPrecision);
		sensor.lastReadingRaw = DEVICE_DISCONNECTED_RAW;
		sensor.lastReadingC = DEVICE_DISCONNECTED_C;
	sensors.setWaitForConversion(true); // Use blocking call for 1st set of readings in setup()
	Serial.println("Starting Temp Reading in Blocking Mode");
	sensors.requestTemperatures();  // Blocking mode, functin returns when conversion is complete
		getSensorTemperature(sensor);
	// Kick off non-blocking sensor readings
	sensors.setWaitForConversion(false);
enum machineStates {
	IDLE, WAITING_FOR_CONVERSION, READING
	static const uint32_t waitTime {sensors.millisToWaitForConversion(tempPrecision)};  // Time we must wait for conversion (based on chosen precision)
	static const uint32_t tempReadingPeriod {1000}; // Read the sensors once per second
	static uint32_t startTime {millis()};
	static machineStates currentState {WAITING_FOR_CONVERSION};
	static uint8_t currentSensor;
	uint32_t currentMillis {millis()};
	switch (currentState) {
		case WAITING_FOR_CONVERSION:
			if ((currentMillis - startTime) < waitTime) {
			currentSensor = 0;
			currentState = READING;
		case READING:
			// Only read one sensor at a time so loop() function cycles faster
			getSensorTemperature(sensorArray[currentSensor++]);
			if (currentSensor >= numSensors) {
				currentState = IDLE;
				startTime = currentMillis;
		case IDLE:
			if ((currentMillis - startTime) > tempReadingPeriod) {
				currentState = WAITING_FOR_CONVERSION;
		default:
	// This is where you code can do useful stuff because the temperature code is non-blocking
void printAddress(DeviceAddress &addr) {
	for (uint8_t addrByte : addr) {
		if (addrByte < 0x10) {
			Serial.print("0");
		Serial.print(addrByte, HEX);
void getSensorTemperature(TempSensorInfo &tempSensor) {
	tempSensor.lastReadingRaw = sensors.getTemp(tempSensor.address);
	tempSensor.lastReadingC = DallasTemperature::rawToCelsius(tempSensor.lastReadingRaw);
void printTemperatures() {
	uint8_t index {0};
		Serial.print("Sensor ");
		Serial.print(": ");
		Serial.print(sensor.lastReadingRaw);
		Serial.print(" (Raw), ");
		Serial.print(sensor.lastReadingC, 1);
		Serial.println(" (C), ");
That makes a lot of sense. I thought maybe it was just a lack of memory while the sensor was doing it's thing. With the 2nd section of code I posted, without the fan pwm and with no delay stated, it's working fine... just no fan pwm. I'm not going to fight with it. As long as I can monitor the temperature, that'll be enough. If I need to, I'll add a trimpot and adjust as needed if it's too loud.
I tried getting a DHT11 temp and humidity sensor working, but no luck. That's my next battle.
Pin 0 is the serial TX pin, use another besides 0 and 1.
Thanks. That was just an example someone shared with me. I'm actually using pin 11 ((14) ~D11/MOSI) on the Nano pinout image. I didn't even know there was a Pin 0... my Nano starts at Pin (1) D1/TX.
Edit: Actually, I thought Pin 0 referred to A0/D14 (19).
