Hello,
I've found this brilliant code to control an air core gauge. The thing is that this code runs over and over. Is there any way that someone can show me how to add code to control it manually with a potentiometer?
//the mathematical constant pi, because we are using radians instead of degrees.
// 360 degrees = 2*pi, 180 = pi, 90 = pi/2, etc.
const float pi = 3.14159;
const float stepSize = 0.01; //This is the step size for incrementing the angle (in radians)
//this is the maximum resolution of the PWM output.
const int maxAnalogRes = 255;
/* Define the pins the meter is connected to. We need 1 PWM to vary the voltage in
* each coil, and two more pins to reverse the polarity in that coil. So a total
* of 6 pins (3 per coil).
const int aircore1SinPin = 9; //this controls the voltage to the "sine" coil
const int aircore1CosPin = 10; //this controls the voltage to the "cosine" coil
const int aircore1SinDirPin1 = 2; //these two control the polarity to the "sine" coil
const int aircore1SinDirPin2 = 4;
const int aircore1CosDirPin1 = 7; //these two control the polarity to the "cosine" coil
const int aircore1CosDirPin2 = 8;
// milliseconds between each angular step.
int delayTime = 40;
//Set the pins to OUTPUT
pinMode(aircore1SinPin, OUTPUT);
pinMode(aircore1CosPin, OUTPUT);
pinMode(aircore1SinDirPin1, OUTPUT);
pinMode(aircore1SinDirPin2, OUTPUT);
pinMode(aircore1CosDirPin1, OUTPUT);
pinMode(aircore1CosDirPin2, OUTPUT);
// Set the initial direction as "forward". Of course it could be "reverse" depending on which lead you connected :-).
digitalWrite(aircore1SinDirPin1, HIGH);
digitalWrite(aircore1SinDirPin2, LOW);
digitalWrite(aircore1CosDirPin1, HIGH);
digitalWrite(aircore1CosDirPin2, LOW);
void loop() // run over and over again
//Rotate 0 through 360 degrees (OK, really 2*pi radians, but who cares?)
for(float i = 0; i < (2*pi); i = i + stepSize){
setMeterPosition(aircore1SinPin, aircore1SinDirPin1, aircore1SinDirPin2, aircore1CosPin, aircore1CosDirPin1, aircore1CosDirPin2, i);
delay(delayTime); // waits for delayTime milliseconds
//Rotate 360 through 0 degrees
for(float i = (2*pi); i > 0; i = i - stepSize){
// setMeterPosition() - put it at the angle in radians
void setMeterPosition(int sinPin, int sinDirPin1, int sinDirPin2, int cosPin, int cosDirPin1, int cosDirPin2, float pos){
// Calculate the voltage on the PWM pins based on the angle we want
float sinCoilValue = maxAnalogRes*sin(pos);
float cosCoilValue = maxAnalogRes*cos(pos);
// change the polarity of the coil depending on the sign of the voltage level
if (sinCoilValue<=0) {
digitalWrite(sinDirPin1, LOW); //Change to LOW if using relays
digitalWrite(sinDirPin2, HIGH); //comment this line out if using relays
digitalWrite(sinDirPin1, HIGH); //Change to HIGH if using relays
digitalWrite(sinDirPin2, LOW); //comment this line out if using relays
if (cosCoilValue<=0) {
digitalWrite(cosDirPin1, LOW); //Change to LOW if using relays
digitalWrite(cosDirPin2, HIGH); //comment this line out if using relays
digitalWrite(cosDirPin1, HIGH); //Change to HIGH if using relays
digitalWrite(cosDirPin2, LOW); //comment this line out if using relays
// take the absolute value because analogWrite doesn't take negatives
sinCoilValue = abs(sinCoilValue);
cosCoilValue = abs(cosCoilValue);
analogWrite(sinPin, sinCoilValue);
analogWrite(cosPin, cosCoilValue);
