adam_g:
Hi Daniel,
I'm familiar with the RTClib library, which is also a good choice.
Please include your code that resulted in the 18 hour issue if you'd like me to take a look at what went wrong. I was setting the alarm to a value of 172800 seconds using this very same method just the other day. Was your ALARM_INTERVAL variable declared as an time_t or unsigned long? Also, did you input 72000 as a value or the actual calculation (206060)? If the latter, you may need to add the U & L formatters to force the values to the correct data type i.e. (20UL60UL*60UL) .
Hi Adam,
Yes, i declared the ALARM_INTERVAL variable as time_t. So i tested your advice with UL, it works!
(At least the alarm time is calculated correctly);
Now I have to choose between two variants that work both ; )
Here my code with the time_t variant:
#include <DS3232RTC.h> // https://github.com/JChristensen/DS3232RTC
#include <LowPower.h>
//const time_t ALARM_INTERVAL(20 * 60 * 60); // 20 Hour - DOESN'T WORK-> use UL
unsigned long ALARM_INTERVAL=28UL*24UL*60UL*60UL; //28 Days - Works
tmElements_t tm;
const byte rtcAlarmPin = 3; // External interrupt on pin D3
pinMode(13, OUTPUT);
digitalWrite(13, LOW);
pinMode(rtcAlarmPin, INPUT_PULLUP); // Set interrupt pin
// initialize the alarms to known values, clear the alarm flags, clear the alarm interrupt flags
RTC.setAlarm(ALM1_MATCH_DATE, 0, 0, 0, 1);
RTC.setAlarm(ALM2_MATCH_DATE, 0, 0, 0, 1);
RTC.alarm(ALARM_1);
RTC.alarm(ALARM_2);
RTC.alarmInterrupt(ALARM_1, false);
RTC.alarmInterrupt(ALARM_2, false);
RTC.squareWave(SQWAVE_NONE);
RTC.read(tm);
time_t t = makeTime(tm); // change the tm structure into time_t (seconds since epoch)
Serial.println(F("Aktuelle Zeit t: "));
printDateTime(t);
time_t alarmTime = t + ALARM_INTERVAL; // calculate the alarm time
Serial.println(F("Alarm wird gesetzt auf: "));
printDateTime(alarmTime);
// set the current time
// RTC.set(t);
// set the alarm
RTC.setAlarm(ALM1_MATCH_HOURS, second(alarmTime), minute(alarmTime), hour(alarmTime), 0);
// clear the alarm flag
RTC.alarm(ALARM_1);
RTC.alarmInterrupt(ALARM_1, true); // Enable alarm 1 interrupt A1IE
// check to see if the alarm flag is set (also resets the flag if set)
Serial.println("Entering sleep");
delay(100);
sleepNow(); // Enter slee
setRTCagain();
// Interrupt Service Routine (ISR) function
void wake ()
detachInterrupt (digitalPinToInterrupt (3)); // Disable interrupts on D3
void sleepNow ()
noInterrupts (); // Disable interrupts before entering sleep
attachInterrupt (digitalPinToInterrupt(3), wake, FALLING); // Wake on falling edge of D3
interrupts (); // Enable interrupts to ensure next instruction is executed
LowPower.powerDown(SLEEP_FOREVER, ADC_OFF, BOD_OFF);
void setRTCagain() {
Serial.println("Awake...");
if ( RTC.alarm(ALARM_1) )
Serial.println("Alarm1 now..: ");
RTC.read(tm);
printDateTime(t);
Serial.println(F("Alarm is set to: "));
// set the alarm
// Print current time and date
void printDateTime(time_t t)
Serial.print((day(t) < 10) ? "0" : ""); Serial.print(day(t), DEC); Serial.print('/');
Serial.print((month(t) < 10) ? "0" : ""); Serial.print(month(t), DEC); Serial.print('/');
Serial.print(year(t), DEC); Serial.print(' ');
Serial.print((hour(t) < 10) ? "0" : ""); Serial.print(hour(t), DEC); Serial.print(':');
Serial.print((minute(t) < 10) ? "0" : ""); Serial.print(minute(t), DEC); Serial.print(':');
Serial.print((second(t) < 10) ? "0" : ""); Serial.println(second(t), DEC);
And here with the RTClib variant:
(Requires an additional function to use the alarm interval as a global variable - here not included)..
#include "RTClib.h"
RTC_DS3231 rtc;
RTC.alarm(ALARM_1);
RTC.alarm(ALARM_2);
// set the alarm
DateTime now = rtc.now();
Serial.println(F("Current Time: "));
printDateTime(now);
DateTime future (now + TimeSpan(28, 0, 0, 0)); //Days, Hours, Minutes, Seconds
printDateTime(future);
RTC.setAlarm(ALM1_MATCH_DATE, future.second(), future.minute(), future.hour(), future.day());
RTC.alarm(ALARM_1);
delay(100);
setRTCagain();
void wake ()
void sleepNow ()
Serial.println("Now Alarm!");
// set the alarm
void printDateTime(DateTime t)
Serial.print((t.day() < 10) ? "0" : ""); Serial.print(t.day(), DEC); Serial.print('/');
Serial.print((t.month() < 10) ? "0" : ""); Serial.print(t.month(), DEC); Serial.print('/');
Serial.print(t.year(), DEC); Serial.print(' ');
Serial.print((t.hour() < 10) ? "0" : ""); Serial.print(t.hour(), DEC); Serial.print(':');
Serial.print((t.minute() < 10) ? "0" : ""); Serial.print(t.minute(), DEC); Serial.print(':');
Serial.print((t.second() < 10) ? "0" : ""); Serial.println(t.second(), DEC);
