Im putting together an ammeter using the bidirectional 150A version.
http://www.dfrobot.com/image/data/SEN0098/ACS758%20datasheet.pdf
Using the sample code.
50A Current Sensor(AC/DC)(SKU:SEN0098) Sample Code
This code shows you how to get raw datas from the sensor through Arduino and convert the raw datas to the value of the current according to the datasheet;
Smoothing algorithm (http://www.arduino.cc/en/Tutorial/Smoothing) is used to make the outputting current value more reliable;
Created 27 December 2011
By Barry Machine
www.dfrobot.com
Version:0.2
const int numReadings = 30;
float readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
float total = 0; // the running total
float average = 0; // the average
float currentValue = 0;
Serial.begin(57600);
for (int thisReading = 0; thisReading < numReadings; thisReading++)
readings[thisReading] = 0;
total= total - readings[index];
readings[index] = analogRead(0); //Raw data reading
readings[index] = (readings[index]-510)*5/1024/0.04-0.04;//Data processing:510-raw data from analogRead when the input is 0; 5-5v; the first 0.04-0.04V/A(sensitivity); the second 0.04-offset val;
total= total + readings[index];
index = index + 1;
if (index >= numReadings)
index = 0;
average = total/numReadings; //Smoothing algorithm (http://www.arduino.cc/en/Tutorial/Smoothing)
currentValue= average;
Serial.println(currentValue);
delay(30);
In the math I understand that the sensitivity for my sensor is 13.3mv/amp or 0.0133/amp. What I dont understand is the last bit of comment , the second 0.04-offset val;.. Im lost here..Any idea's
There's also a problem because what ever value is inputted in the 0.04-0.04 equation ,that same number is what shows up in the serial monitor ,when the unit is at rest ,no current flowing. Im guessing Im missing something obvious.
