I am trying to move a series of motors using my web browsers and I am using void * pointers in doing this.
But I find it hard to manage in my code.
I have a series of sequences to execute like the distance of motor movements.
#include <Arduino.h>
struct StepData
char command;
int value;
struct MoveMotorSequence
const char *sequenceName = "Move Motor";
int currentStep = 0;
int stepSize = 5;
StepData steps[5] = {StepData{'1', 700}, StepData{'3', 6000}, StepData{'2', 160000}, StepData{'3', 17000}, StepData{'2', 0}};
struct MoveFeederSequence
const char *sequenceName = "Move Feeder";
int stepSize = 3;
StepData steps[3] = {StepData{'3', 800}, StepData{'2', 10000}, StepData{'1', 200}};
// More sequence
void *currentSequence;
const char *getSequence()
// Input from user through web browser
const char *userCommand = "Move Motor";
return userCommand;
// Get the command
const char *command = getSequence();
if (strcmp("Move Motor", command) == 0)
// Initialize the Move Motor sequence
MoveMotorSequence moveMotorSequence;
currentSequence = &moveMotorSequence;
// Do the Motor Movement
else if (strcmp("Move Feeder", command) == 0)
// Initialize the Move Feeder sequence
MoveFeederSequence moveFeederSequence;
currentSequence = &moveFeederSequence;
As you can see I am using a void * pointer to do this but I find it cumbersome like what if I add additional sequences with different steps.
Is there a better alternative to using void * pointers?
I am no C++ expert and have just learned it on my own.
The two structs MoveMotorSequence and MoveFeederSequence should both be instances of the same type. Or should at least derive from the same type. Then currentSequence can be a pointer to that type. In order for them to have different numbers of steps then you will need to make that struct a template. This is fairly advanced.
Thanks for the reply, do you mean about Classes? Where I could have a Base Class (e.g Sequence) and a Derive Class (e.g MoveMotorSequence, MoveFeederSequence ) and then use the Sequence field instead of the void * pointers?
I have been reading about this but have not used this in an actual Arduino program though.
return userCommand;
Oh, I have just typed this on top of my head. What should be the proper way of doing this?
Both sequence structs could have a sequence pointer. Then they would be equal and you could use a sequence struct pointer instead of a void pointer
Much safer...
Hint: an array name is a pointer...
