I’ve just bought an Alvik.
The out-of-box experience wasn’t great - the battery had discharged well below the minimum, and was dead. Luckily, I have spares.
Using Ubuntu 24.04.2 LTS, “lsusb” shows “Bus 005 Device 015: ID 2341:056b Arduino SA Nano ESP32” when the board is plugged into my laptop. My username is a member of “dialout”.
I’ve jumpered pin B1 to GND, and in the IDE selected “esptool” as the programmer, and set the board to “Arduino Nano ESP32” and the port to “/dev/ttyACM0”, but when I click “upload using programmer” for the “drive” example, the IDE runs through the compilation process, then
Sketch uses 335861 bytes (10%) of program storage space. Maximum is 3145728 bytes.
Global variables use 31912 bytes (9%) of dynamic memory, leaving 295768 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port /dev/ttyACM0
Connecting......................................
A fatal error occurred: Failed to connect to ESP32-S3: No serial data received.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
Failed programming: uploading error: exit status 2
Yes, the board is powered, yes, I’ve hit reset. Yes, the jumper is pressed in.
Anyone familiar with this sort of thing?
Did you turn the Alvik off?
Yes, the Alvik is turned OFF, the correct port is selected, but the board is not an AVR board, it’s an ESP32 (hence “esptool” programmer) - is that wrong?
Also, firmware updated - using microPython, get_version() shows 1.1.1
I got to try this on a Windows 11 PC, and got pretty much the same result.
The device manager showed a serial device on COM3.
I tried to compile and upload (using Esptool - “esptool.py v4.5.1”) the “drive” example, and got
A fatal error occurred: failed to connect to ESP32-S3: No serial data received
Given that I’ve managed to talk to the board using the microPython environment, I don’t think there’s anything wrong with the board itself, just something I’m missing (or undocumented) with the IDE / C++ setup.
Has anyone successfully used this device with the IDE, or is there somewhere I can raise a ticket?
Decided to come back to this, and tried a different approach; held down the reset switch until the compilation was complete, and then got the following message
Sketch uses 336093 bytes (10%) of program storage space. Maximum is 3145728 bytes.
Global variables use 31936 bytes (9%) of dynamic memory, leaving 295744 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Connecting...
Traceback (most recent call last):
File "/home/*****/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool.py", line 34, in <module>
esptool._main()
File "/home/*****/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/__init__.py", line 1032, in _main
main()
File "/home/*****/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/__init__.py", line 674, in main
esp = esp or get_default_connected_device(
File "/home/*****/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/__init__.py", line 921, in get_default_connected_device
_esp.connect(before, connect_attempts)
File "/home/*****/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/loader.py", line 640, in connect
last_error = self._connect_attempt(reset_strategy, mode)
File "/home/*****/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/loader.py", line 525, in _connect_attempt
reset_strategy() # Reset the chip to bootloader (download mode)
File "/home/*****/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/reset.py", line 106, in __call__
self._setRTS(True) # Reset. Calls inverted to go through (1,1) instead of (0,0)
File "/home/*****/.arduino15/packages/esp32/tools/esptool_py/4.5.1/esptool/reset.py", line 40, in _setRTS
self.port.setRTS(state)
File "/usr/lib/python3/dist-packages/serial/serialutil.py", line 600, in setRTS
self.rts = value
File "/usr/lib/python3/dist-packages/serial/serialutil.py", line 463, in rts
self._update_rts_state()
File "/usr/lib/python3/dist-packages/serial/serialposix.py", line 706, in _update_rts_state
fcntl.ioctl(self.fd, TIOCMBIS, TIOCM_RTS_str)
OSError: [Errno 19] No such device
Failed programming: uploading error: exit status 1
Any ideas anyone?
