Arduino: 2.2.1 (Mac book pro), Board: "Arduino/Genuino Uno"
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Failed uploading: uploading error: exit status 1
Hi @abdullah123456. I would like to start by determining exactly which board you have.
I see that you have selected the "Arduino/Genuino Uno" board in Arduino IDE. Something that can be confusing is there are multiple boards with "UNO" in their name. We need to be certain of exactly which one you have. The reason is that the problem might be caused by the IDE not being correctly configured for your specific board.
Please tell us which of the following boards you are attempting to upload to:
If you aren't sure which one you have, you can provide a picture of the board or a link to the place you bought it from and we'll see if we can identify it.
I'm going to ask you to provide the full verbose output from an upload attempt.
This procedure is not intended to solve the problem. The purpose is to gather more information.
Please do this:
Select File > Preferences... (or Arduino IDE > Settings... for macOS users) from the Arduino IDE menus.
The "Preferences" dialog will open.
Uncheck the box next to Show verbose output during: ☑ compile in the "Preferences" dialog.
Check the box next to Show verbose output during: ☐ upload.
Click the "OK" button.
The "Preferences" dialog will close.
Attempt an upload, as you did before.
Wait for the upload to fail.
You will see an "Upload error: ..." notification at the bottom right corner of the Arduino IDE window. Click the "COPY ERROR MESSAGES" button on that notification.
Open a forum reply here by clicking the "Reply" button.
Click the <CODE/> icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
Press the Ctrl+V keyboard shortcut (Command+V for macOS users).
This will paste the error output from the upload into the code block.
Move the cursor outside of the code block markup before you add any additional text to your reply.
Sketch uses 7708 bytes (23%) of program storage space. Maximum is 32256 bytes.
Global variables use 496 bytes (24%) of dynamic memory, leaving 1552 bytes for local variables. Maximum is 2048 bytes.
"/Users/muhammedazad/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude" "-C/Users/muhammedazad/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf" -v -V -patmega328p -carduino "-P/dev/cu.usbserial-14240" -b115200 -D "-Uflash:w:/private/var/folders/0h/_tpqq9js76qc1d9sfcf70jmw0000gn/T/arduino/sketches/07DC096282F632B972E0D473D9F9828C/RFID_Door_Lock.ino.hex:i"
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Users/muhammedazad/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
User configuration file is "/Users/muhammedazad/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.usbserial-14240
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude done. Thank you.
There should be a couple of quick flashes (I think three) after releasing the reset button and before the LED switches permanently on.
If that does not happen, the 328P processor or the bootloader running on it is malfunctioning. You can try to solve the problem by burning the bootloader if you have a programmer or a second Arduino that you can use as the programmer. If the burning of the bootloader fails or the result does not solve your problem, the 328P processor is damaged and you need to replace it (not that easy with your board as it's an SMD version of the 328P).
And now the question are:
Was it working in the past? If not, ship it back to the seller.
What was connected to the board when it started failing?
