Hello, this is my first post ever,
I'm using Borland C++ Builder6 to communicate with Arduino UNO/MEGA
The program is used to control/collect data for various interactive lab experiments.
I applied 2 different codes.
The first code works. However data streaming is controlled by arduino.
I measured the time intervals on the PC and it takes approximately 600 miliseconds/16 channels.
Therefore setting the PC program timer to 1 second works. However I may record either the first or second input.
The second code which I prefer does not work.
Here I send a message "RA" which makes the Arduino go to the multi-channel read function.
However, after the first successful send the repeated sends do not go through.
Here are the arduino codes :
FIRST CODE (this works)
- Author: Demir Bayka
- Analog data logging over SerialPort
#define BAUD 9600
#define DELAY_TIME 100
#define led3 13
String receivedString;
String AnyString,sintRead;
bool OK = false;
int ChanNo = 16;
int DataNo = 0;
int iRead[16];
Serial.begin(BAUD);
pinMode(led3, OUTPUT);
void ReadAnalogChannels(int &n)
int i,j;
String s;
DataNo++;
for (i=0;i<n-1;i++)
j = analogRead(i);
delay(10);
j = analogRead(i);
delay(10);
iRead = j;
- i = n-1;*
- j = analogRead(i);*
- delay(10);*
_ iRead = j;_
* s = "E";*
* s = s + String(DataNo) + ",";*
* for (i=0;i<n-1;i++)*
_ s = s + String(iRead*) + ",";
s += String(iRead[n-1]);
Serial.println(s);
Serial.flush();
digitalWrite(led3, LOW);
if (Serial.available() > 0)
receivedString = Serial.readStringUntil('\n');
if (receivedString.length()>2)
AnyString = receivedString.substring(0,2);
if (AnyString.equals("XX"))
sintRead = receivedString.substring(2);
ChanNo = sintRead.toInt();
Serial.println(ChanNo);
Serial.flush();
delay(50);
if (receivedString.equals("OFF"))
OK = false;
Serial.println("TEST HAS ENDED");
if (OK)
ReadAnalogChannels(ChanNo);
if (receivedString.equals("RA"))
digitalWrite(led3, HIGH);
receivedString = "";
DataNo = 0;
OK = true;
delay(200);
SECOND CODE (does not work)
* Author: Demir Bayka_
* Analog data logging over SerialPort
#define BAUD 9600
#define led3 13
int ChanNo = 16;
int DataNo = 0;
int iRead[16];
* Serial.begin(BAUD);*
* pinMode(led3, OUTPUT);*
* int i,j;*
* String s;*
* DataNo++;*
* j = analogRead(i);*
* delay(10);*
* delay(10);*
_ iRead = j;
i = n-1;
j = analogRead(i);
delay(10);
j = analogRead(i);
iRead = j;
s = "E";
for (i=0;i<n-1;i++)
s = s + String(iRead) + ",";
Serial.println(s);
Serial.flush();
Serial.flush();
delay(50);
delay(200);
}*_
