Hello all,
plz help me!!!
I have to get input from 4 AI at the same time, store it somewhere and compare with previous reading. Code compliles, but don't give me anything. to check if the program working I wrote some serial communication functions, but unsuccessfully. It's now working. plz help me =)
#include
int SV[40]; // every 4 entries are for 4 sensors
int pin[4]={A0, A1, A2, A3};
int i=0;
int k;
int TOA[4]={0,0,0,0};
int sig;
int sumElements ( int arr[], int a) {
int summ=0;
if (arr[36+a]==0){return 0;}
for (int m=0; m<10; m++){
summ+=sqrt(arr[4*m+a]^2);
return summ;
// initialize serial communication at 9600 bits per second:
SV[36]=SV[37]=SV[38]=SV[39]=0;
// read the input on analog pin 0..3:
for (k; k<4; k++){
//read data
sig = analogRead(pin[k]);
//save it to array
SV[4*i+k]=sig;
//print. use it just to check if it's working
Serial.println(sig);
if (sig> sumElements(SV,k)/10) { TOA[k]=millis(); Serial.println("Signal detected");}
sketch_jul15b.cpp.o: In function __static_initialization_and_destruction_0': /home/gina/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/arm-none-eabi/include/c++/4.8.3/iostream:74: warning: undefined reference to std::ios_base::Init::Init()'
/home/gina/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/arm-none-eabi/include/c++/4.8.3/iostream:74: warning: undefined reference to `std::ios_base::Init::~Init()'
First, please read Nick Gammon's two posts at the top of this Forum for the proper way to post code on this Forum using code tags. Second:
Do you mean to perform an XOR on arr[] (some people think the ^ operator does exponentiation)? Also, because sqrt() returns a float, you need to cast the result to an int for assignment into summ.
There is only one analog to digital converter. So, you can not read 4 analog values at the same time. You can read them in order, with small delays between each reading.
Whether that is sufficient, or not, is not clear.
The ^ may be the mathematical symbol for squaring, but it is not the C symbol. Taking the square root of n squared hardly makes sense.
for (k; k<4; k++){
Only a fool fails to initialize variables in for loops. Surely this does not include you.
I see no reason to include iostream in the sketch. Why are you?
Assuming you meant to type "It's not working" all I can say is I'm not surprised.
But since you have not told us what it does do and what it should do I can't say much more.
I can't image that the sqrt() function makes much sense with integers
And in C++ the ^ does not mean exponetiation - you need to use the pow() function or simply x * x
Why do you need IOSTREAM ?
Strip your code of all the complications and make sure it can read the analog inputs correctly and display the values. Then add the othe stuff piece by piece.
@AWOL: You're right: Anytime you assign a smaller (i.e., in memory requirements) data type into a larger data type, the compiler is perfectly capable of silently making the cast for you. My own personal opinion is that silent casts often lead to forgetting to use a cast where it is needed. Using a cast even though the compiler can do it behind your back helps document that you know what you're doing and I think is a better way of doing it. I think not using a cast is sloppy coding.
