sdy1
April 2, 2015, 11:36pm
1
Hi all,
I'm using a NEXT CC1101RF module to send sensor values from AnalogRead(A0). This causes the receiver to receiver a packet the is empty, then not receiver any more packets. If I comment out the AnalogRead(), every thing works normal.
It's using the SPI interface on an UNO.
I have it connected according to: Arduino : use a Texas CC1101 – Erwan's Blog Those example do work ok.
I've looked thru the CC1101.cpp & h files, but don't see anything that would affect the analogRead().
The NEXT receiver is this:
http://www.amazon.com/gp/product/B00NPZ3YUA/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
CC1101 uses the spi library, but that shouldn't screw up AnalogRead().
I just thought, maybe I need to add PinMode(A0,INPUT), though by default they're inputs, yes?
Any Ideas to get AnalogRead() to transmitt it's value?
system
April 3, 2015, 12:27am
2
Fix your code. If you don't know how, perhaps you might give some fleeting thought to posting it.
sdy1
April 3, 2015, 1:53am
3
I would fix it if I new where. I've been working this problem for about three days, so I turned here.
Transmitter code:
CODE TAGS PLEASE!
#include "EEPROM.h"
#include "cc1101.h"
CC1101 cc1101;
// The LED is wired to the Arduino Output 4 (physical panStamp pin 19)
#define LEDOUTPUT 4
// counter to get increment in each loop
byte counter;
byte b;
byte syncWord = 199;
int sensorPin = A0; // select the input pin for the potentiometer
byte sensorValue;
int x;
void blinker()
digitalWrite(LEDOUTPUT, HIGH);
delay(100);
digitalWrite(LEDOUTPUT, LOW);
delay(100);
Serial.println("start");
// setup the blinker output
pinMode(LEDOUTPUT, OUTPUT);
// blink once to signal the setup
blinker();
// reset the counter
counter=0;
Serial.println("initializing...");
// initialize the RF Chip
cc1101.init();
cc1101.setSyncWord(&syncWord, false);
cc1101.setCarrierFreq(CFREQ_915);
cc1101.disableAddressCheck();
//cc1101.setTxPowerAmp(PA_LowPower);
Serial.print("CC1101_PARTNUM "); //cc1101=0
Serial.println(cc1101.readReg(CC1101_PARTNUM, CC1101_STATUS_REGISTER));
Serial.print("CC1101_VERSION "); //cc1101=4
Serial.println(cc1101.readReg(CC1101_VERSION, CC1101_STATUS_REGISTER));
Serial.print("CC1101_MARCSTATE ");
Serial.println(cc1101.readReg(CC1101_MARCSTATE, CC1101_STATUS_REGISTER) & 0x1f);
Serial.println("device initialized");
//Serial.println("done");
void send_data()
CCPACKET data;
data.length=3;
byte blinkCount=counter++;
data.data[0]=5;
data.data[1]=sensorValue;
// data.data[1]=blinkCount;
data.data[2]=2;
Serial.print("data.data[1] :");
Serial.println(data.data[1]);
//cc1101.flushTxFifo ();
if(cc1101.sendData(data))
Serial.print(blinkCount,HEX);
Serial.println(" sent ok :)");
blinker();
Serial.println("sent failed :(");
blinker();
blinker();
sensorValue =analogRead(A0)/1000;
send_data();
delay(2000);
Receiver code:
#include "EEPROM.h"
#include "cc1101.h"
#define LEDOUTPUT 4
#define DESTINATION_ADDR 5 // Receiver address
// The connection to the hardware chip CC1101 the RF Chip
CC1101 cc1101;
byte b;
byte i;
long counter=0;
byte chan=0;
// a flag that a wireless packet has been received
boolean packetAvailable = false;
void blinker()
delay(100);
/* Handle interrupt from CC1101 (INT0) gdo0 on pin2 */
void cc1101signalsInterrupt(void)
// set the flag that a package is available
packetAvailable = true;
// blinker();
cc1101.init();
cc1101.disableAddressCheck(); //if not specified, will only display "packet received"
attachInterrupt(0, cc1101signalsInterrupt, FALLING);
void ReadLQI()
byte lqi=0;
byte value=0;
lqi=(cc1101.readReg(CC1101_LQI, CC1101_STATUS_REGISTER));
value = 0x3F - (lqi & 0x3F);
Serial.print("CC1101_LQI ");
Serial.println(value);
void ReadRSSI()
byte rssi=0;
byte value=0;
rssi=(cc1101.readReg(CC1101_RSSI, CC1101_STATUS_REGISTER));
if (rssi >= 128)
value = 255 - rssi;
value /= 2;
value += 74;
value = rssi/2;
value += 74;
Serial.print("CC1101_RSSI ");
if(packetAvailable)
Serial.println("packet received");
// Disable wireless reception interrupt
detachInterrupt(0);
ReadRSSI();
ReadLQI();
// clear the flag
CCPACKET packet;
if(cc1101.receiveData(&packet) > 0)
if(!packet.crc_ok)
Serial.println("crc not ok");
if(packet.length > 0)
Serial.print("packet: len ");
Serial.print(packet.length);
Serial.print(" data: ");
for(int j=0; j<packet.length; j++){
Serial.print(packet.data[j],DEC);
Serial.print(" ");
Serial.println(".");
// Enable wireless reception interrupt
system
April 3, 2015, 11:51am
4
What values will be stored in sensorValue? Does sending 0 or 1 really make sense?
Does it matter if you use a different analog pin?
Does it matter if you post a link to the hardware and libraries you are using? (Hint: Absolutely)
sdy1
April 3, 2015, 2:36pm
5
Hi, it doesn't really matter, 0 or 1 or any number, the problem is AnalogRead() hangs up.
Any Analog pin causes the same problem.
I did post a link to the hardware:
And the libraries are #include "EEPROM.h" and #include "cc1101.h".
(CC1101 is from the PanStamp library: GitHub - panStamp/panstamp: panStamp wireless ecosystem - Project files )
Thanks for helping
