Here is something you can try using a slight modification of your code.
analogReference(EXTERNAL); // use AREF for reference voltage
int sensorValue = analogRead(A0);
Serial.print("AnalogRead: ");
Serial.println(sensorValue);
float voltage = sensorValue * (3.3 / 1023.0);
Serial.print("V: ");
Serial.println(voltage);
Serial.println("\n");
delay(5000);
I am guessing Arduino Uno or similar. Since your Analog Input will likely only see a max of 3.3 volts as was mentioned in your setup code we added this line:
Now connect the 3.3 volt out on your board to the AREF pin. This way your new analog reference becomes 3.3 volts so we also change:
Eventually you may want to think about averaging maybe ten samples and using a map function to get the readout in PH. That assumes a linear input as I have no experience with your sensor.
Whatever you end up getting , its worth having some means of calibrating within your software to get things spot.
I always try to stick with integer maths if you are dealing with an analog input , it’s easier to think you are getting more resolution/accuracy than you think by converting to a float .
zoomkat:
People have reported in the past that reading the analog input has a more stable reading on a second read like below.
That is only if you are using more than one analog input, and the ADC has to switch inputs. High impedance outputs (such as from a voltage divider) may cause the ADC take too long to settle, hence the second reading.
Your code example will give a "redefined" error from the compiler...
herbschwarz:
Yes, aarg. But the float variable uses very much more
memory than an int would use.
The program has to print the value as a decimal scaled to 5.0V. So, you have to create a float somewhere anyway. Unless you want to write custom output routines. Also I would not call 2 bytes "very much more".
