AnalogReadSerial 1023 only //// help please////
I have tried the AnalogReadSerial tutorial and when I try to read the serial it remains 1023. :sob:
I dont know much about arduino it is my second time using it. :grinning:
I am not so specialized in this.
THE CODE IS
int sensePin =0;
void setup(){
analogReference(DEFAULT);
void loop(){
Serial.println(analogRead(sensePin));
Sounds like the connection to Ground is broken.
NOT REALY . i tried to light a led ind it worked
AnalogReadSerial
Reads an analog input on pin 0, prints the result to the serial monitor.
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
Did you connect the potentiometer as described? Double-check the connection to ground.
something is strange here same problem
I think something is wrong with the analog inputs
can it be a broken atmega? i read something like this on another topic
Of course it can be a broken ATmega... but more likely it is a bad connection. When you connect a multimeter between A0 and Gnd what voltage do you read?
I have conected a0 to gound and it says 0
Something is wrong with the analog inputs
how can i repare this problem?
Post a schematic of your circuit: not the ideal circuit from the example, your actual circuit.
Post code, post a schematic
I have atached the code and a blueprint
it is like this guy did
Nothing attached....
Oh wait I see you attached them at the top.
Well it works for me: I get from ~500 with photoresistor uncovered down to ~80.
When I pull the gnd wire out it goes to 1023 as johnwasser said it would.
It is at the topic description (up)
I realy need help
It works for me... try a different analog pin? Try a different ground point? Try a different piece of wire?
Post a photo....
can i use the gnd from the digital pins?
something is strange here same problem. thanks.
Moderator: Commercial URL removed
its not working doesnt matter what analog imput i use
I also bought another atmega and its the same
The ground is working perfect but something is wrong with analog
i realy need help
I am hapy so hear that i am not the only one with this problem
picatel:
Yep ground is ground
Post a photo
