I need to read four analog voltage for a project and am using arduino mega 2560 R3.
Requirement is to have a reference voltage as close to 5v as possible. As I found that the default to be considerably less than 5v and also inconsistent and decided to use an external voltage on AREF pin.
So, connected AREF pin to a 4.98v source and made the ground reference common for arduino and the source.
In code, made a call to analogReference(EXTERNAL) in setup() and am reading values one after the other in loop(). Please see attachment
However, I find that the analog readings for all channels shows some random value like "111" or "176" continuously.
Have tried giving a delay after reading, reading the analog pin multiple times and averaging the readings, all with the same error.
Unable to understand, where I am going wrong. Any suggestions would help a great deal.
ideonics:
Why does the reference has to be exact if you use a pot as input (sketch comment).
A pot set e.g. to 50% always gives a value of 512, independent of the voltage on Aref.
Make sure the supply is always higher than external Aref.
Voltages on the analog pins are got from a signal converter having 4-20mA input and providing 0-5v output. So, I need AREF to be as close to 5v as possible.
Use a 10k:10k voltage divider on the converter to half the output, and use 2.56volt Aref.
Or get rid of the signal converter, and replace it with a resistor.
4-20mA current produces a voltage across the resistor that can be measured with the analogue input.
Use 51ohm for 1.1volt Aref, or 125ohm for 2.56volt Aref.
Leo..
