Base on your responses, problem is the BT card to Arduino board serial connection
Is your BT card HC-05 or HC-06 ??
let me have a link to your specific model
You may reverse TX and RX cables just to make sure, this will not harm anything
Did you actuallly check you BT card baud rate ?? they usually default to 9600bps
Have succesfully used this card for other projects ??
Can you see the scrolling Joystick values in the Serial Monitor ??
My model is HC-05 and it work @9600bps. I use your older version and it works, even on version 4.0 it works Arduino receive joystick data as button data no problem. But datafields doesnt change there are always showing XXXX.
Hi, thanks for your rapid response. Your assistance in helping is excellent. Hope I have answered your questions so I can get a response from Arduino UNO back to Android
Your sketch headed:
// Iteaduino BT board configurator - BASIC version
Returned the following error message:
Searching ...
ERROR: Bluetooth Module not responding!
Make sure there are no active bluetooth connection and try again
I couldn’t find anything paired with the HC-05
The red BT LED flashed on/off about every half second
Your sketch headed:
AndroTest V1.3 - @kas2014\ndemo for V4.X (6 button version)
Only Connections:
.Arduino pin#2 to TX BlueTooth module
. Arduino pin#3 to RX BlueTooth module
..Arduino 3.3v to 3.3 BlueTooth module
..Arduino GND to GND
NOTE: Key and 5v not connected
Paired and connected with Android (v4.0.4) OK.
Still only xxx showing bottom left.
Interesting point is that button B5 stays locked the same as other buttons until pressed again to release. (I did notice at one time it did act like a push button – maybe that was when data got fed back). Just a thought
I think the connection problems may be down to me as that problem appears to have gone away.
My only problem now (apart from error in BT board configurator mentioned above) is the failure to get a signal from Arduino to Adoid.
Answers to 9 question in reply #197
1..Version v4.0.4
2. Yes
3. Yes
4. Yes
5. Yes
6. Yes
7. NO – Initially Red LED flashes continuously but when connected it flashes twice every couple of seconds (not solid red as in question)
8. Yes
9. Yes
Observations:
I am not experienced with serial coms., but understand there are parity and stop bits. When I changed the BT module to 57600 baud I sent AT+UART=57600,0,0 and the AT command AT+UART? returned: 57600,0,0
Is that OK?
BT Red LED flashes rapldly before pairing. Then when paired changes to on/off flash every 2 seconds then but when connected it flashes twice every couple of seconds.
UNO TX LED flashes about every 2 seconds and whenever a button is pressed. When the joystick is moved it constantly flickers, then after about 10 seconds of continuous joystick movement the TX LED locks on. Opening the serial monitor window seems to return it back to normal.
UNO RX LED only ever flashes when uploading code
Hope some of this makes sense – thanks again for your help
Bob
Are you referring to the joystick position field at bottom left of android device screen ??
This should indicate joystick position at App start up, even before any connection
It should read (-100,-100) for South West position and (100,100) for North East position
This is normal behavior when not connected
My only problem now (apart from error in BT board configurator mentioned above) is the failure to get a signal from Arduino to Android.
You can follow joystick position and buttons state on you Serial Monitor
Datafields don't update, B5 is not in "push" mode
Correct ??
1..Version v4.0.4
I was talking about App version, should be V4.0 OK ??
the AT command AT+UART? returned: 57600,0,0 Is that OK?
Yes
According to documentation
Param2 = stop bit: 0->1 bit 1->2 bits
Param3 = parity bit: 0->None 1->Odd parity 2->Even parity
Arduino serial is 8N1 (1 stop bit, no parity)
This reflects the data flowing from Arduino to Serial Monitor
Strange
Did you change any setting in Advanced options ??
Try "reset Option" to restore initial parameters
EDIT: also set Refresh interval @100ms, Timeout count @every 10 intervals
Finally let me have a link to your specific BT board
I am using Joystick BT Commander on an Android Tablet. This allows Apps to be closed by swiping the minimised app icon off the screen. This was the problem.
When I closed the App by using back button (hairpin arrow) and confirm “Total RC Commander - close this controller” and then re-open the App it works OK.
Data received back from Arduino and Button 5 is in push mode.
Apologies for inconvenience and thanks for your time.
It is great to see the care and level of attention that you provide to the users of your App.
Again many thanks - Brilliant App
Bob
Data flow from Arduino to Android problem SOLVED
Bob
Thanks Bob for the good new and the kind words 8)
I am investing time because this App should bring a lot to the Arduino community
It is a universal remote for most projects, using wide spread (Android) technologies.
I told my friend to download the App and within a minute he took control of my RC tank
He was rather impressed
During my support session, I did some interesting stress tests yesterday.
I tried various data refresh interval at different baud rates and found some minor glitches.
Please use AndroTest_V14.ino
#define VERSION "\n\nAndroTest V1.4 - @kas2014\ndemo for V4.X (6 button version)"
// V1.4 improved communication errors handling
// V1.3 renamed for publishing, posted on 09/05/2014
// V1.2 Text display ** not backward compatible **
// V1.1 Integer display
// V1.0 6 buttons + 4 data char implemented
** The message exceeds the maximum allowed length (9500 characters) **
See next message
This updated sketch features optimized timing and better transmission error management
Again, make sure your BT board is set @57600bps
Avoid using 25ms refresh interval and continuous timeout count, that's too much data
I am also preparing V5.0, with a pure ASCII communication protocol
Where is AndroTest_V14.ino – only some lines showing?
In the Android app can you recognise when the app has been closed ‘illegally’ and act upon that action next time the app is opened. Might make it idiot proof.
When you first touch the yellow joystick dot, it immediately moves to the centre of the touch point. This changes the xy numbers – most noticeable when you touch the edge. (I want to control two servos but don’t want them to move until the joystick is moved intentionally).
Can the touch point be recognised without moving the yellow dot?
What do I need to change to alter the data fields fed back to the Android and can it be coded in “Your code here” areas in the Arduino sketch.
I am doing number crunching on Arduino from Joystick positions and would like to send three values back to android.
#define VERSION "\n\nAndroTest V1.41 - @kas2014\ndemo for V4.X (6 button version)"
// V1.41 minor modifications
// Demo setup:
// Button #1 controls pin13 LED
// Button #2 starts DEBUG
// Button #3 displays demo message
// Button #4 toggle datafield display rate
// Button #5 configured as "push" button (momentary)
// Arduino pin#2 to TX BlueTooth module
// Arduino pin#3 to RX BlueTooth module
// make sure your BT board is set @57600 bps
// better remove SoftSerial for PWM based projects
// For Mega 2560:
// remove #include "SoftwareSerial.h", SoftwareSerial mySerial(2,3);
// search/replace mySerial >> Serial1
// pin#18 to RX bluetooth module, pin#19 to TX bluetooth module
#define STX 0x01
#define ETX 0x00
#define ledPin 13
#define SLOW 1000 // Datafields refresh rate (ms)
#define FAST 250 // Datafields refresh rate (ms)
SoftwareSerial mySerial(2,3); // BlueTooth module: pin#2=TX pin#3=RX
int i=0;
byte cmd[6] = {0, 0, 0, 0, 0, 0}; // bytes received
byte buttonStatus = 0; // first Byte sent to Android device
long previousMillis = 0; // will store last time Buttons status was updated
boolean setButtonFeedback = false; // momentary buttons feedback to Android device
long sendInterval = SLOW; // interval between Buttons status transmission (milliseconds)
String displayStatus = "xxxx"; // message to Android device
Serial.begin(57600);
mySerial.begin(57600); // 57600 = max value for softserial
pinMode(ledPin, OUTPUT);
Serial.println(VERSION);
while(mySerial.available()) mySerial.read(); // empty RX buffer // <<mod XXXXXXXX
if(mySerial.available()) { // data received from smartphone
delay(2); // <<mod XXXXXXXX
cmd[0] = mySerial.read();
if(cmd[0] == STX) {
i=1;
while(mySerial.available()) {
delay(1); // <<mod XXXXXXXX
cmd[i] = mySerial.read();
if(cmd[i]>127 || i>5) break; // Communication error << XXX Mod
if((cmd[i]==ETX) && ((i==2 && cmd[1]>2) || i==5)) break; // Button or Joystick data
i++;
if (i==2 && cmd[1]>48 && cmd[1]<68) getButtonState(cmd[1]); // 3 Bytes
else if(i==5 && cmd[1]<3 && cmd[3]<3 ) getJoystickState(cmd); // 6 Bytes
sendBlueToothData(); // <<mod XXXXXXXX
// delay(5); // <<mod XXXXXXXX
// your code here
void sendBlueToothData() {
static long previousMillis = 0;
long currentMillis = millis();
if(setButtonFeedback == true) { // allow momentary button visual effect
previousMillis = currentMillis + 250;
if(currentMillis - previousMillis > sendInterval) { // send data to smartphone
// Data frame transmitted back from Arduino to Android device:
// < 0X02 Buttons state 0X01 DataField#1 0x04 DataField#2 0x05 DataField#3 0x03 >
// < 0X02 01011 0X01 120.00 0x04 -4500 0x05 Motor enabled 0x03 > // example
mySerial.print((char)0x2); // Start of Transmission
mySerial.print(getButtonStatusString()); mySerial.print((char)0x1); // buttons status feedback
mySerial.print(GetDataField_1_int()); mySerial.print((char)0x4); // datafield #1
mySerial.print(GetDataField_2_float()); mySerial.print((char)0x5); // datafield #2
mySerial.print(displayStatus); // datafield #3
mySerial.print((char)0x3); // End of Transmission
String getButtonStatusString() {
String bStatus = "";
for(int i=0; i<6; i++) {
if(buttonStatus & (B100000 >>i)) bStatus += "1";
else bStatus += "0";
return bStatus;
int GetDataField_1_int() { // Data dummy values sent to Android device for demo purpose
static int i= -30; // Replace with your own code
i ++;
if(i >0) i = -3000;
return i;
float GetDataField_2_float() { // Data dummy values sent to Android device for demo purpose
static float i=50; // Replace with your own code
i-=.5;
if(i <-50) i = 50;
return i;
void getJoystickState(byte data[6]) { // <<mod XXXXXXXX nasty bug, was byte data[5]
int joyX = (data[1]<<7) + data[2];
int joyY = (data[3]<<7) + data[4];
joyX = joyX - 200; // Offset to avoid
joyY = joyY - 200; // transmitting negative numbers
if(joyX<-100 || joyX>100 || joyY<-100 || joyY>100) return; // commmunication error
Serial.print("Joystick position: ");
Serial.print(joyX); Serial.print(", "); Serial.println(joyY);
// Your code here ...
void getButtonState(int bStatus) {
switch (bStatus) {
// ----------------- BUTTON #1 -----------------------
case '1':
buttonStatus |= B000001; // ON
Serial.println("\n** Button_1: ON **"); // your code here...
displayStatus = "LED <ON>";
Serial.println(displayStatus);
digitalWrite(ledPin, HIGH);
case '2':
buttonStatus &= B111110; // OFF
Serial.println("\n** Button_1: OFF **"); // your code here...
displayStatus = "LED <OFF>";
digitalWrite(ledPin, LOW);
// ----------------- BUTTON #2 -----------------------
case '3':
buttonStatus |= B000010; // ON
Serial.println("\n** Button_2: ON **"); // your code here...
case '4':
buttonStatus &= B111101; // OFF
Serial.println("\n** Button_2: OFF **"); // your code here...
// ----------------- BUTTON #3 -----------------------
case '5':
buttonStatus |= B000100; // ON
// setButtonFeedback = true; moved to button #5 (for push buttons)
Serial.println("\n** Button_3: ON **"); // your code here...
displayStatus = "Motor #1 enabled"; // Demo text message
case '6':
buttonStatus &= B111011; // OFF
Serial.println("\n** Button_3: OFF **"); // your code here...
displayStatus = "Motor #1 stopped";
// ----------------- BUTTON #4 -----------------------
case '7':
buttonStatus |= B001000; // ON
Serial.println("\n** Button_4: ON **"); // your code here...
displayStatus = "Datafield update <FAST>";
sendInterval = FAST;
case '8':
buttonStatus &= B110111; // OFF
Serial.println("\n** Button_4: OFF **"); // your code here...
displayStatus = "Datafield update <SLOW>";
// ----------------- BUTTON #5 -----------------------
case '9': // configured as momentary button
// buttonStatus |= B010000; // ON
setButtonFeedback = true; // moved from button #3
Serial.println("\n** Button_5: + pushed + **"); // your code here...
displayStatus = "Button_5: ++ pushed ++";
// case 'A':
// buttonStatus &= B101111; // OFF
// break;
// ----------------- BUTTON #6 -----------------------
case 'B':
buttonStatus |= B100000; // ON
Serial.println("\n** Button_6: ON **"); // your code here...
displayStatus = "Button #6 ON"; // Demo text message
case 'C':
buttonStatus &= B011111; // OFF
Serial.println("\n** Button_6: OFF **"); // your code here...
displayStatus = "Button #6 OFF";
EDIT: moved setButtonFeedback from button #3 to button #5 (push button)
Added 1ms delay after while(mySerial.available())
Renamed to AndroTest V1.41 see Reply #225
Not sure to understand, please clarify "This allows Apps to be closed by swiping the minimized app icon off the screen"
I understand your concern, makes sense, let me think about it...
To send back three values to Android (data_1, data_2,data_3,) just modify sendBlueToothData()
mySerial.print(data_1); mySerial.print((char)0x4); // datafield #1
mySerial.print(data_2); mySerial.print((char)0x5); // datafield #2
mySerial.print(data_3); // datafield #3
I am using a 7 inch tablet which doesn't have phone but allows multitasking.
My Samsung GT-S5570 phone won't recognise the HC-05 so I can't test on mobile phone.
However, the link below shows how to swipe on Galaxy 3. Hope this helps.
I think all Android tablets have swipe-to-close so others may also have a problem.
If you want I can video the actions. Just let me know
(anyone know why my Samsung GT-S5570 phone won't recognise the HC-05)
I addressed the situation
Please let me have your email via PM, I will send you V4.1 for testing
Hi Kas,
This version V4.1 works fine.
Wherever you touch on the yellow spot is returned as coordinate 0,0 (x,y) which is exactly what I was looking for.
No jumpy servos anymore. - Many thanks
