for powerful night driving spotlight I will probably use some ready made bike light with its own batteries (put a transistor+relay to switch on)
With Total RC Commander, you may also use IR ligths combined with an IP camera. I use a Wanscam JW0004 with integrated IR leds.
The stealth robot will move in total darkness while delivering a clear picture to the android smarphone 8)
@kas I am having issues with my robot. It seems to work fine unless you hit the buttons for function controls. If you notice in this video you see button 1 is selected and the red led is on . Than it behaves erratically like it loses signal and than restarts ??? Ive tried everything that I could think of and came up no where so I figure I would consult the Oracle
it operates a servo , however it is disconnect now as i thought it might be causing an issue so the led is in its place so you could easier see the issue I am having. Should I get a new uno or hc-05 ?
I did some more testing on my smaller robot using a different uno board but same hc-05 and its performing the same way. I suppose my hc-05 has gone bad ?
fullspool:
What happens when you just test a plain UNO + HC-05 on a table with nothing attached ??
Hello! Any chance on new "Tank control lessons", with that pan/tilt control, or something?
No rush, I am just curious, and thanks for everything coded so far.
kas:
Did you already connect your IP camera to Total RC Commander ??
How do you want your pan/tilt control cooked ? using one or two servo's ?
I am fighting with camera right now... But I will win!!
(EDIT: camera EDIMAX feed is working with native Android apk EdiView, and from PC web browser, but I am not sure how to feed cameras username and password for RC Total Commander for now. It is late night, will continue tomorrow.)
As for pan/tilt, it will be two servos config. Left/Right and Up/Down. Not assembled yet, but I can test with servos.
Button #3 now toggles joystick between motor control and Pan/Tilt control, for camera or other devices
Vertical servo travel and offset are fully adjustable (MIN_Y, MAX_Y & ZERO_Y)
Don't forget to rename buttons according to their specific tasks (Options/Buttons properties/Buttons labels/...)
Thank You for new version! Will try tonight or next days.
I am wondering, what would be best guess how to feed in commandline my camera's username and password? If I simply enter IP address in browser, it asks user/pssw, and then all is fine (see picture).
Link in browwser shows this: http://10.0.0.45/live.asp?r=20130724
I had some experiments, looking at examples in Internet, how login and password is added to link, but did not succeed yet (Total RC Commander says "error 401: remove camera User Access Control".
I would appreciate some good suggestions here. Thanks!
by the way, I appologize in advance, if I missed something obvious, probably even written somewhere. I just haven't had much free time, so I asked in advance to more experienced Author who probably knows that without looking anywhere
UPDATE:
link that works in android VLC player is: http://IPADDRESS/mjpg/video.mjpg
but the same string does not show picture in RC TC.
kas:
If I load a hc05 setup sketch I can send AT commands through the serial monitor.
I tried 2 different hc05 and 2 different uno and they are all behaving the same.
During testing it almost seems the buttons commands time out. So if b1 to light up an led , b2 for turbo , and b3 turns my motors on they all kick off after x amount of time but with no buttons selected the rover behaves normal.
Humm... something is wrong :
Please post a copy of your current rover Arduino sketch
Hello! I got camera picture in "Total RC Commander" now
For now, I allowed anonymous access to camera, and just in case reinstalled "Commander". Now I got picture, so, basically all is fine now. I will eventually experiment with user/passw for camera, now that I really know it is working at all.
Pan/Tilt servos cod not tested yet, need a bit more free time.
