Android Bluetooth Send GPS Data Arduino
Hi,i trying android gps location data send Arduino on bluetooth,but not working.Please help me ?
package com.led.led;
import android.support.v7.app.ActionBarActivity;
import android.os.Bundle;
import android.view.Menu;
import android.view.MenuItem;
import android.bluetooth.BluetoothSocket;
import android.content.Intent;
import android.view.View;
import android.widget.Button;
import android.widget.SeekBar;
import android.widget.TextView;
import android.widget.Toast;
import android.app.ProgressDialog;
import android.bluetooth.BluetoothAdapter;
import android.bluetooth.BluetoothDevice;
import android.os.AsyncTask;
import java.io.IOException;
import java.util.UUID;
public class ledControl extends ActionBarActivity {
    Button btnOn, btnOff, btnDis;
    SeekBar brightness;
    TextView lumn;
    String address = null;
    private ProgressDialog progress;
    BluetoothAdapter myBluetooth = null;
    BluetoothSocket btSocket = null;
    private boolean isBtConnected = false;
    //SPP UUID. Look for it
    static final UUID myUUID = UUID.fromString("00001101-0000-1000-8000-00805F9B34FB");
    @Override
    protected void onCreate(Bundle savedInstanceState)
        super.onCreate(savedInstanceState);
		// GPS
				LocationManager konumYoneticisi = (LocationManager)getSystemService(Context.LOCATION_SERVICE);
		LocationListener konumDinleyicisi = new LocationListener() {
			@Override
			public void onStatusChanged(String provider, int status, Bundle extras) {
			@Override
			public void onProviderEnabled(String provider) {
				Toast.makeText( getApplicationContext(),gpsAcildi,Toast.LENGTH_SHORT).show();
				konumText.setText("GPS Veri bilgileri Alınıyor...");
			@Override
			public void onProviderDisabled(String provider) {
				 Toast.makeText( getApplicationContext(),gpsKapatildi,Toast.LENGTH_SHORT).show();
				 konumText.setText("GPS Bağlantı Bekleniyor...");
			@Override
			public void onLocationChanged(Location loc) {
				loc.getLatitude();
				loc.getLongitude();
				String Text33 = "" + loc.getLongitude();
			 if (btSocket!=null)
            try
                btSocket.getOutputStream().write(Text33.toString().getBytes());
            catch (IOException e)
                msg("Error");
		konumYoneticisi.requestLocationUpdates( LocationManager.GPS_PROVIDER, 0, 0, konumDinleyicisi);
		// gps
        Intent newint = getIntent();
        address = newint.getStringExtra(DeviceList.EXTRA_ADDRESS); //receive the address of the bluetooth device
        //view of the ledControl
        setContentView(R.layout.activity_led_control);
        //call the widgtes
        btnOn = (Button)findViewById(R.id.button2);
        btnOff = (Button)findViewById(R.id.button3);
        btnDis = (Button)findViewById(R.id.button4);
        brightness = (SeekBar)findViewById(R.id.seekBar);
        lumn = (TextView)findViewById(R.id.lumn);
        new ConnectBT().execute(); //Call the class to connect
        //commands to be sent to bluetooth
        btnOn.setOnClickListener(new View.OnClickListener()
            @Override
            public void onClick(View v)
                turnOnLed();      //method to turn on
        btnOff.setOnClickListener(new View.OnClickListener() {
            @Override
                turnOffLed();   //method to turn off
        btnDis.setOnClickListener(new View.OnClickListener()
            @Override
                Disconnect(); //close connection
        brightness.setOnSeekBarChangeListener(new SeekBar.OnSeekBarChangeListener() {
            @Override
            public void onProgressChanged(SeekBar seekBar, int progress, boolean fromUser) {
                if (fromUser==true)
                    lumn.setText(String.valueOf(progress));
                    try
                        btSocket.getOutputStream().write(String.valueOf(progress).getBytes());
            @Override
            public void onStartTrackingTouch(SeekBar seekBar) {
            @Override
            public void onStopTrackingTouch(SeekBar seekBar) {
    private void Disconnect()
        if (btSocket!=null) //If the btSocket is busy
            try
                btSocket.close(); //close connection
            { msg("Error");}
        finish(); //return to the first layout
    private void turnOffLed()
        if (btSocket!=null)
            try
                msg("Error");
    private void turnOnLed()
        if (btSocket!=null)
            try
                btSocket.getOutputStream().write("TO".toString().getBytes());
                msg("Error");
    // fast way to call Toast
    private void msg(String s)
        Toast.makeText(getApplicationContext(),s,Toast.LENGTH_LONG).show();
    @Override
    public boolean onCreateOptionsMenu(Menu menu) {
        // Inflate the menu; this adds items to the action bar if it is present.
        getMenuInflater().inflate(R.menu.menu_led_control, menu);
        return true;
    @Override
    public boolean onOptionsItemSelected(MenuItem item) {
        // Handle action bar item clicks here. The action bar will
        // automatically handle clicks on the Home/Up button, so long
        // as you specify a parent activity in AndroidManifest.xml.
        int id = item.getItemId();
        //noinspection SimplifiableIfStatement
        if (id == R.id.action_settings) {
            return true;
        return super.onOptionsItemSelected(item);
    private class ConnectBT extends AsyncTask<Void, Void, Void>  // UI thread
        private boolean ConnectSuccess = true; //if it's here, it's almost connected
        @Override
        protected void onPreExecute()
            progress = ProgressDialog.show(ledControl.this, "Connecting...", "Please wait!!!");  //show a progress dialog
        @Override
        protected Void doInBackground(Void... devices) //while the progress dialog is shown, the connection is done in background
            try
                if (btSocket == null || !isBtConnected)
                 myBluetooth = BluetoothAdapter.getDefaultAdapter();//get the mobile bluetooth device
                 BluetoothDevice dispositivo = myBluetooth.getRemoteDevice(address);//connects to the device's address and checks if it's available
                 btSocket = dispositivo.createInsecureRfcommSocketToServiceRecord(myUUID);//create a RFCOMM (SPP) connection
                 BluetoothAdapter.getDefaultAdapter().cancelDiscovery();
                 btSocket.connect();//start connection
                ConnectSuccess = false;//if the try failed, you can check the exception here
            return null;
        @Override
        protected void onPostExecute(Void result) //after the doInBackground, it checks if everything went fine
            super.onPostExecute(result);
            if (!ConnectSuccess)
                msg("Connection Failed. Is it a SPP Bluetooth? Try again.");
                finish();
                msg("Connected.");
                isBtConnected = true;
            progress.dismiss();
I think you have the wrong forum. We deal with Arduino, programmed in C++.
its android studio and java dudes...ı dont have problem arduino,ı dont send the gps information on android studio...
I don't know what a java dude is but I'm sure it is time to read reply #2 - again....
I cant not tell my idea,okey listen.
Open GPS and bluetooth On android
GPS information send via bluetooth > arduino
Can you help me ?
@Nick_Pyner
@dannable
dopebeerxx:
This is quite clearly an android problem. I believe it is possible to do what you want, but this is an arduino forum. You have already said you do not have an Arduino problem. You will be better off going to an Android forum, and learning about something like App Inventor.
