I want to display the FILE and _DATE- on a lcd in the following: I do not know the correct format.
sprintf(line0, " %s, %s", _FILE_, _DATE_); -- how do I do this
lcd.setCursor(0, 0); lcd.print(line0);
sprintf(line0, _FILE_ ", " _DATE_);
you don't need sprintf for this. those are all string literals.
lcd.print(" " _FILE_ ", " _DATE_);
You need TWO underscores before and after FILE and DATE.
On my system, FILE is quite long:
/Users/john/Documents/Arduino/sketch_jan06b/sketch_jan06b.ino, Jan 11 2022
Are you sure 'line0' is big enough to hold it? Try:
snprintf(line0, sizeof line0, " %s, %s", __FILE__, __DATE__); -- how do I do this
What he had will also work just as well...
Yeah, I also forgot the leading space - I just went for the minimalist approach.
You are correct John, it FILE does show the complete path which is too long. I was looking for somethings that would indicate the name of the SKETCH and possibly the date - .
If that not possible I will stay with the date and setting the version number.
The lcd is 20x4.
This is so much more fun with a real live example:
// 11 Januari 2022, by Koepel, Public Domain
// Version 1 : Initial version, working in linux in Wokwi.
// Version 2 : added some fun code in the loop()
// Version 3 : fixed big bug for the Arduino IDE in Windows.
LiquidCrystal_I2C lcd( 0x27, 20, 4);
char buffer[40];
float version = 1.00;
Serial.println( "__FILE__ : " __FILE__);
Serial.println( "__DATE__ : " __DATE__);
Serial.println( "__TIME__ : " __TIME__);
Serial.println( "__VERSION__ : " __VERSION__);
Serial.print( "ARDUINO : ");
Serial.println( ARDUINO);
// Trying to extract the name of the sketch
// This part is bad code, my apologies in advance
char *p = strrchr( __FILE__, '/'); // find last forward slash
if( p == nullptr)
p = strrchr( __FILE__, '\\'); // perhaps it is a backward slash
if( p != nullptr)
p++; // strip the leading forward or backward slash
strcpy( buffer, p);
// strip the extension
char *pDot = strrchr( buffer, '.');
if( pDot != nullptr)
*pDot = '\0';
Serial.print( "Name of the sketch : ");
Serial.print( '\"');
Serial.print( buffer);
Serial.println( "Oops, can not find the sketch name");
lcd.init();
lcd.backlight();
lcd.setCursor( 0, 0);
lcd.print( "\"Real\" Live Example");
lcd.setCursor( 0, 1);
lcd.print( "Version ");
lcd.print( version);
lcd.setCursor( 0, 2);
lcd.print( "Name : ");
lcd.print( '\"');
lcd.print( buffer);
lcd.print( '\"');
lcd.setCursor( 0, 3);
lcd.print( __DATE__ " " __TIME__); // One space in the middle for exactly 20 characters
delay( 10000);
// Have some fun with the digits of the time and the number of the version
int col = random( 0, 6);
col += col / 2;
int digit = random( 0, 10);
lcd.setCursor( col + 12, 3);
lcd.print( digit);
if( millis() % 4000 < 2000)
version += float( digit) / 100.0;
version -= float( digit) / 100.0;
lcd.setCursor( 8, 1);
lcd.print( version, 2);
delay( 150);
Well, maybe not "real", but the sketch is alive in a simulation:
[EDIT] Oops, there was a big bug. I have updated the sketch above. Version 3 should work in Windows.
Thanks for the real life experience - however when run on my system the following is showing on the Serial Monitor and on the lcd.
FILE : C:\Temp\sketch\sketch.ino
DATE : Jan 11 2022
TIME : 16:54:30
windows 10
char buffer[40];
if( p == nullptr)
char *p = strrchr( __FILE__, '\\'); // perhaps it is a backward slash
if( p != nullptr)
strcpy( buffer, p);
*pDot = '\0';
lcd.init();
lcd.backlight();
lcd.print( "Version 1.00");
lcd.print( '\"');
lcd.print( buffer);
lcd.print( '\"');
void loop() {}
I am very ashamed, I declared the pointer p twice.
I have updated the sketch here in Reply #8 and also on Wokwi.
Thank you for reminding me that coding is FUN. Also for the informative way of resenting a solution.
