I found a MEGA2560 new version, seems better than old one?
Thanks
Adam
NEW:
OLD:
Thanks
Adam
NEW:
OLD:
If your project needs WiFi, I suppose that the top one is "better". If you don't use the Wifi, they are, functionally, the same.
Thanks.
that have a big difference of price? why?
I don't know. The top one (Mega + WiFi) should be more expensive, but it is from China.
I see no price on the bottom one (Mega only), but the other Mega boards are petty expensive. Perhaps due to the chip shortage.
Apart from the kudos(?) of owning one, why would you want a Mega 2560?
I mean I think I have one here somewhere for experimentation, but have no particular use for it. Do you have a use for one?
Thanks.
for home automation system which need lot of inputs.
RAM, Digital IO pins, 3 hardware serial ports, analog input pins, hardware interrupt pins, Port F and Port K all lined up in nice orderly rows, PWM pins, other than that I can't think of a thing.
study Bit manipulation, Port F and Port K. short and simple: the 16 pins on the bottom left hand side in the image above are arranged just right, both physically and electrically, to control 2 8 digital SSR relays by changing one 8 bit byte per port. you can change the status of one relay, or all 8 simultaneously, with one command
NOT Arduino! Do you see the Arduino logo?
And don't claim to be either...
