Hello, I'm trying to connect a PS4 or Xbox One controller to my Arduino Nano ESP32 with the ESP32-BLE-Gamepad or Bluepad32 for NINA-W10 boards on platform io but when I'm trying to just upload code without using the Bluepad32 lib but while including it all those errors appears
In file included from /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:235, from .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Controller.h:7, from .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Controller.cpp:4: /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:47:61: error: 'digitalPinToGPIONumber' is not a type #define pinMode(pin, mode) pinMode(digitalPinToGPIONumber(pin), mode) ^~~~~~~~~~~~~~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.h:44:8: note: in expansion of macro 'pinMode' void pinMode(uint8_t pin, uint8_t mode); ^~~~~~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:42:65: error: 'digitalPinToGPIONumber' is not a type #define digitalRead(pin) digitalRead(digitalPinToGPIONumber(pin)) ^~~~~~~~~~~~~~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.h:45:7: note: in expansion of macro 'digitalRead' int digitalRead(uint8_t pin); ^~~~~~~~~~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:46:66: error: 'digitalPinToGPIONumber' is not a type #define digitalWrite(pin, val) digitalWrite(digitalPinToGPIONumber(pin), val) ^~~~~~~~~~~~~~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.h:46:8: note: in expansion of macro 'digitalWrite' void digitalWrite(uint8_t pin, uint8_t value); ^~~~~~~~~~~~ In file included from /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:235, from .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Controller.h:7, from .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.h:9, from .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.cpp:4: /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:47:61: error: 'digitalPinToGPIONumber' is not a type Indexing .pio/build/arduino_nano_esp32/lib085/libAdafruit PWM Servo Driver Library.a #define pinMode(pin, mode) pinMode(digitalPinToGPIONumber(pin), mode) ^~~~~~~~~~~~~~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.h:44:8: note: in expansion of macro 'pinMode' void pinMode(uint8_t pin, uint8_t mode); ^~~~~~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:42:65: error: 'digitalPinToGPIONumber' is not a type #define digitalRead(pin) digitalRead(digitalPinToGPIONumber(pin)) ^~~~~~~~~~~~~~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.h:45:7: note: in expansion of macro 'digitalRead' int digitalRead(uint8_t pin); ^~~~~~~~~~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:46:66: error: 'digitalPinToGPIONumber' is not a type #define digitalWrite(pin, val) digitalWrite(digitalPinToGPIONumber(pin), val) ^~~~~~~~~~~~~~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.h:46:8: note: in expansion of macro 'digitalWrite' void digitalWrite(uint8_t pin, uint8_t value); ^~~~~~~~~~~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:47:61: error: variable or field 'pinMode' declared void #define pinMode(pin, mode) pinMode(digitalPinToGPIONumber(pin), mode) ^~~~~~~~~~~~~~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.cpp:44:17: note: in expansion of macro 'pinMode' void Bluepad32::pinMode(uint8_t pin, uint8_t mode) { ^~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.cpp:44:33: error: expected primary-expression before 'pin' void Bluepad32::pinMode(uint8_t pin, uint8_t mode) { ^~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:47:84: note: in definition of macro 'pinMode' #define pinMode(pin, mode) pinMode(digitalPinToGPIONumber(pin), mode) ^~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.cpp:44:46: error: expected primary-expression before 'mode' void Bluepad32::pinMode(uint8_t pin, uint8_t mode) { ^~~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:47:90: note: in definition of macro 'pinMode' #define pinMode(pin, mode) pinMode(digitalPinToGPIONumber(pin), mode) ^~~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:42:65: error: 'int Bluepad32::digitalRead' is not a static data member of 'class Bluepad32' #define digitalRead(pin) digitalRead(digitalPinToGPIONumber(pin)) ^~~~~~~~~~~~~~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.cpp:67:16: note: in expansion of macro 'digitalRead' int Bluepad32::digitalRead(uint8_t pin) { ^~~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.cpp:67:36: error: expected primary-expression before 'pin' int Bluepad32::digitalRead(uint8_t pin) { ^~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:42:88: note: in definition of macro 'digitalRead' #define digitalRead(pin) digitalRead(digitalPinToGPIONumber(pin)) ^~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:46:66: error: variable or field 'digitalWrite' declared void #define digitalWrite(pin, val) digitalWrite(digitalPinToGPIONumber(pin), val) ^~~~~~~~~~~~~~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.cpp:117:17: note: in expansion of macro 'digitalWrite' void Bluepad32::digitalWrite(uint8_t pin, uint8_t value) { ^~~~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.cpp:117:38: error: expected primary-expression before 'pin' void Bluepad32::digitalWrite(uint8_t pin, uint8_t value) { ^~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:46:89: note: in definition of macro 'digitalWrite' #define digitalWrite(pin, val) digitalWrite(digitalPinToGPIONumber(pin), val) ^~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/Bluepad32.cpp:117:51: error: expected primary-expression before 'value' void Bluepad32::digitalWrite(uint8_t pin, uint8_t value) { ^~~~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:46:95: note: in definition of macro 'digitalWrite' #define digitalWrite(pin, val) digitalWrite(digitalPinToGPIONumber(pin), val) ^~~ *** [.pio/build/arduino_nano_esp32/liba3e/Bluepad32 for NINA-W10 boards/Controller.cpp.o] Error 1 Compiling .pio/build/arduino_nano_esp32/FrameworkArduino/USB.cpp.o *** [.pio/build/arduino_nano_esp32/liba3e/Bluepad32 for NINA-W10 boards/Bluepad32.cpp.o] Error 1 .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/utility/spi_drv.cpp: In static member function 'static void SpiDrv::begin()': .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/utility/spi_drv.cpp:91:20: error: 'PINS_COUNT' was not declared in this scope if (SLAVERESET > PINS_COUNT) { ^~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/utility/spi_drv.cpp:91:20: note: suggested alternative: 'ICOUNT' if (SLAVERESET > PINS_COUNT) { ^~~~~~~~~~ ICOUNT In file included from /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/Arduino.h:235, from .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/utility/spi_drv.cpp:23: .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/utility/spi_drv.cpp:100:11: error: 'NINA_GPIO0' was not declared in this scope pinMode(NINA_GPIO0, OUTPUT); ^~~~~~~~~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:47:84: note: in definition of macro 'pinMode' #define pinMode(pin, mode) pinMode(digitalPinToGPIONumber(pin), mode) ^~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/utility/spi_drv.cpp:100:11: note: suggested alternative: 'NINA_GPIOIRQ' pinMode(NINA_GPIO0, OUTPUT); ^~~~~~~~~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:47:84: note: in definition of macro 'pinMode' #define pinMode(pin, mode) pinMode(digitalPinToGPIONumber(pin), mode) ^~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/utility/spi_drv.cpp: In static member function 'static int SpiDrv::available()': .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/utility/spi_drv.cpp:66:22: error: 'NINA_GPIO0' was not declared in this scope #define NINA_GPIOIRQ NINA_GPIO0 ^~~~~~~~~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:42:88: note: in definition of macro 'digitalRead' #define digitalRead(pin) digitalRead(digitalPinToGPIONumber(pin)) ^~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/utility/spi_drv.cpp:539:47: note: in expansion of macro 'NINA_GPIOIRQ' int SpiDrv::available() { return (digitalRead(NINA_GPIOIRQ) != LOW); } ^~~~~~~~~~~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/utility/spi_drv.cpp:66:22: note: suggested alternative: 'NINA_GPIOIRQ' #define NINA_GPIOIRQ NINA_GPIO0 ^~~~~~~~~~ /home/sasha/.platformio/packages/framework-arduinoespressif32/cores/esp32/io_pin_remap.h:42:88: note: in definition of macro 'digitalRead' #define digitalRead(pin) digitalRead(digitalPinToGPIONumber(pin)) ^~~ .pio/libdeps/arduino_nano_esp32/Bluepad32 for NINA-W10 boards/src/utility/spi_drv.cpp:539:47: note: in expansion of macro 'NINA_GPIOIRQ' int SpiDrv::available() { return (digitalRead(NINA_GPIOIRQ) != LOW); } ^~~~~~~~~~~~ *** [.pio/build/arduino_nano_esp32/liba3e/Bluepad32 for NINA-W10 boards/utility/spi_drv.cpp.o] Error 1 ============================================================================== [FAILED] Took 4.15 seconds ==============================================================================
or with ESP32-BLE-Gamepad
.pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleGamepadConfiguration.cpp: In constructor 'BleGamepadConfiguration::BleGamepadConfiguration()': .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleGamepadConfiguration.cpp:30:62: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings] _transmitPowerLevel(9) ^ .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleGamepadConfiguration.cpp:30:62: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings] .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleGamepadConfiguration.cpp:30:62: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings] .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleGamepadConfiguration.cpp:30:62: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings] .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleGamepadConfiguration.cpp:30:62: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings] .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp: In member function 'void BleNUS::begin()': .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp:21:5: error: 'delay' was not declared in this scope delay(1000); // Give some time for other services to complete their business ^~~~~ .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp:24:9: error: 'Serial' was not declared in this scope Serial.println("No pServer"); ^~~~~~ .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp:24:9: note: suggested alternative: 'Stream' Serial.println("No pServer"); ^~~~~~ Stream .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp:43:21: warning: 'bool NimBLEService::start()' is deprecated: NimBLEService::start() has no effect. Services are started when the server is started. [-Wdeprecated-declarations] pService->start(); ^ In file included from .pio/libdeps/arduino_nano_esp32/NimBLE-Arduino/src/NimBLEDevice.h:299, from .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.h:4, from .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp:1: .pio/libdeps/arduino_nano_esp32/NimBLE-Arduino/src/NimBLEService.h:51:10: note: declared here bool start() { return true; } ^~~~~ .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp: In member function 'void BleNUS::print(long int)': .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp:127:5: error: 'ltoa' was not declared in this scope ltoa(l, buf, 10); ^~~~ .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp:127:5: note: suggested alternative: 'utoa' ltoa(l, buf, 10); ^~~~ utoa .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp: In member function 'void BleNUS::print(long unsigned int)': .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp:133:5: error: 'ultoa' was not declared in this scope ultoa(ul, buf, 10); ^~~~~ .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp:133:5: note: suggested alternative: 'utoa' ultoa(ul, buf, 10); ^~~~~ utoa .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp: In member function 'void BleNUS::print(float, int)': .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp:139:5: error: 'dtostrf' was not declared in this scope dtostrf(f, 6, digits, buf); ^~~~~~~ .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleNUS.cpp:139:5: note: suggested alternative: 'strstr' dtostrf(f, 6, digits, buf); ^~~~~~~ strstr Compiling .pio/build/arduino_nano_esp32/FrameworkArduino/USBCDC.cpp.o *** [.pio/build/arduino_nano_esp32/lib864/ESP32-BLE-Gamepad/BleNUS.cpp.o] Error 1 .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleGamepad.cpp: In static member function 'static void BleGamepad::taskServer(void*)': .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleGamepad.cpp:2060:42: warning: 'void NimBLEHIDDevice::startServices()' is deprecated: Services are now started by the server when start() is called, this function is no longer needed and will be removed in a future release. [-Wdeprecated-declarations] BleGamepadInstance->hid->startServices(); ^ In file included from .pio/libdeps/arduino_nano_esp32/ESP32-BLE-Gamepad/BleGamepad.cpp:4: .pio/libdeps/arduino_nano_esp32/NimBLE-Arduino/src/NimBLEHIDDevice.h:52:27: note: declared here void startServices() __attribute__((deprecated("Services are now started by the server when start() is called, " ^~~~~~~~~~~~~ ============================================================================== [FAILED] Took 7.50 seconds ==============================================================================
Can someone help me resolving those errors or finding an another working library?
