I decided to have some fun with it again. Wondered about getting the joystick data up to the Arduino side, so I got that working today... So far just for testing...
If anyone wants to play along, current PIP is up at:
Arduino_UNO_Q/gamepad_test at main · KurtE/Arduino_UNO_Q
Note: Readme could use a bit of work, so far just put in the command lines to remind me how to build and install the sketch and how to start up the python with the uv run command...
Here is a snapshot of it:
Python:
# SPDX-FileCopyrightText: Copyright (C) ARDUINO SRL (http://www.arduino.cc)
# SPDX-License-Identifier: MPL-2.0
from arduino.app_utils import *
import time
import pygame
import inputs
led_state = False
# This dict can be left as-is, since pygame will generate a
# pygame.JOYDEVICEADDED event for every joystick connected
# at the start of the program.
joysticks = {}
pygame.init()
pygame.joystick.init()
joystick_count = pygame.joystick.get_count()
print(joystick_count)
#joystick = pygame.joystick.Joystick(0)
#joystick.init()
def loop():
global led_state
event_processed = False
#axis_motions: list[int] = [65536, 65536, 65536, 65536, 65536, 65536]
axis_motion_list: list[int] = []
for event in pygame.event.get() :
event_processed = True
if event.type == pygame.JOYAXISMOTION :
axis_motion_list.append(event.axis)
axis_motion_list.append(int(event.value * 32767))
#axis_motions[event.axis] = event.value
if event.axis == 0 :
print("Left stick X: {}".format(event.value))
elif event.axis == 1:
print("Left stick y: {}".format(event.value))
elif event.axis == 2:
print("Right stick x: {}".format(event.value))
elif event.axis == 3:
print("Right stick y: {}".format(event.value))
else :
print("Other axis {}: {}".format(event.axis,event.value))
elif event.type == pygame.JOYHATMOTION :
Bridge.notify("joy_hat_motion", event.value[0], event.value[1])
print("Hat {}: {}".format(event.hat, event.value))
elif event.type == pygame.JOYBUTTONDOWN :
Bridge.notify("joy_button_down", event.button)
print("button down: {}".format(event.button))
elif event.type == pygame.JOYBUTTONUP :
Bridge.notify("joy_button_up", event.button)
print("button up: {}".format(event.button))
# Handle hotplugging
elif event.type == pygame.JOYDEVICEADDED:
# This event will be generated when the program starts for every
# joystick, filling up the list without needing to create them manually.
Bridge.notify("joy_device_added", event.device_index)
joy = pygame.joystick.Joystick(event.device_index)
joysticks[joy.get_instance_id()] = joy
print(f"Joystick {joy.get_instance_id()} connencted")
elif event.type == pygame.JOYDEVICEREMOVED:
Bridge.notify("joy_device_removed", event.instance_id)
del joysticks[event.instance_id]
print(f"Joystick {event.instance_id} disconnected")
else :
print("Other Event: {}".format(event))
if event_processed :
if len(axis_motion_list) :
Bridge.notify("joy_axis_motion", axis_motion_list)
print("---")
#time.sleep(1)
#led_state = not led_state
#Bridge.call("set_led_state", led_state)
App.run(user_loop=loop)
And the sketch:
// SPDX-FileCopyrightText: Copyright (C) ARDUINO SRL (http://www.arduino.cc)
// SPDX-License-Identifier: MPL-2.0
#include "Arduino_RouterBridge.h"
#include <vector>
uint32_t last_led_update_time = 0;
#define BLINK_TIME 500
pinMode(LED_BUILTIN, OUTPUT);
Bridge.begin();
Monitor.begin();
Bridge.provide("joy_button_down", joy_button_down);
Bridge.provide("joy_button_up", joy_button_up);
Bridge.provide("joy_axis_motion", joy_axis_motion);
Bridge.provide("joy_hat_motion", joy_hat_motion);
Bridge.provide("joy_device_added", joy_device_added);
Bridge.provide("joy_device_removed", joy_device_removed);
if ((millis() - last_led_update_time) >= BLINK_TIME) {
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
last_led_update_time = millis();
void joy_button_down(int btn) {
printk("BDN: %d\n", btn);
void joy_button_up(int btn) {
printk("BUP: %d\n", btn);
void joy_axis_motion(std::vector<int> motions) {
for (int i = 0; i < motions.size(); i += 2) {
printk("%d:%d ", motions[i], motions[i+1]);
printk("\n");
void joy_hat_motion(int x, int y) {
printk("Hat: %d %d\n", x, y);
void joy_device_added (int index) {
printk("\nJoystick device added: %d\n", index);
void joy_device_removed (int index) {
printk("\nJoystick device removed: %d\n", index);
Some python output from run:
arduino@Uno-q2:~/gamepad_test$ uv run python/main.py
pygame 2.6.1 (SDL 2.28.4, Python 3.13.5)
Hello from the pygame community. https://www.pygame.org/contribute.html
0
======== App is starting ============================
2026-04-19 20:11:50.615 INFO - [MainThread] App: App started
Other Event: <Event(4352-AudioDeviceAdded {'which': 0, 'iscapture': 0})>
Joystick 0 connencted
button down: 12
button up: 12
button down: 4
button up: 4
button down: 3
button up: 3
button down: 1
button up: 1
Hat 0: (0, 1)
Hat 0: (0, 0)
Left stick y: -0.005554368724631489
Left stick y: 0.027802362132633443
Left stick y: 0.032654805139317
Left stick y: 0.03451643421735282
Left stick y: 0.029389324625385297
Left stick y: 0.027436140018921477
Left stick y: 0.023194067201757866
Left stick y: 0.021454512161626027
Left stick y: 0.017120883816034424
Left stick y: 0.015381328775902585
Left stick y: 0.03488265633106479
Left stick X: 0.022339548936429945
Left stick X: 0.044709616382335886
Left stick X: 0.04934842982268746
Left stick X: 0.053529465620899074
Left stick y: 0.03088473158970916
Left stick X: 0.05526902066103091
Left stick y: 0.02359080782494583
Left stick y: -0.010162663655507066
Left stick y: -0.015900143436994536
Left stick y: -0.032227546006653035
Left stick y: -0.03842280343028046
Left stick y: -0.05694753868221076
Left stick X: 0.059297463911862545
Left stick y: -0.11700796533097324
Left stick X: 0.06457716605121006
Left stick y: -0.1567430646687216
Left stick X: 0.0913113803521836
Left stick y: -0.18939786980803858
Left stick X: 0.10901211584826197
Left stick y: -0.2141178624835963
Left stick X: 0.1141392254402295
Left stick y: -0.24414807580797754
Left stick X: 0.1882381664479507
Left stick y: -0.3395184179204688
Left stick X: 0.2087466048158208
Left stick y: -0.36423841059602646
Left stick X: 0.23483993041779838
Left stick y: -0.42429883724478895
Left stick X: 0.2599871822260201
Left stick y: -0.48432874538407544
Left stick X: 0.26557206946012757
Left stick y: -0.56556901760918
Left stick X: 0.28235724967192605
Left stick y: -0.6750694296090579
Left stick X: 0.3075350199896237
Left stick y: -0.73863948484756
Left stick X: 0.3447981200598163
Left stick y: -0.7942747276223029
Left stick X: 0.36997589037751394
Left stick y: -0.8313547166356395
Left stick X: 0.40537736136967073
Left stick y: -0.8613849299600208
Left stick X: 0.45011749626148256
Left stick y: -0.9072847682119205
Left stick X: 0.45570238349559006
Left stick X: 0.46128727072969755
Left stick y: -0.8825647755363628
Left stick X: 0.46687215796380505
Left stick y: -0.8128299813837092
Left stick X: 0.47105319376201665
Left stick y: -0.7651295510727256
Left stick y: -0.6944792016357921
Left stick y: -0.620319223609119
Left stick y: -0.5682241279335917
Left stick y: -0.3845637379070406
Left stick y: -0.32715842158268993
Left stick y: -0.22296823023163548
Left stick y: -0.12936796166875209
Left stick y: -0.02868739890743736
Left stick y: 0.21326334421826837
Left stick y: 0.3280434583574938
Left stick y: 0.42429883724478895
Left stick y: 0.5152439954832606
Left stick y: 0.5850093081453902
Left stick X: 0.47233497116000855
Left stick y: 0.7183446760460219
Left stick X: 0.46586504715109717
Left stick y: 0.7536545915097507
Left stick X: 0.4174932096316416
Left stick X: 0.37183751945554977
Left stick y: 0.7086092715231788
Left stick X: 0.2786339915158544
Left stick y: 0.5267189550462356
Left stick X: 0.026062807092501604
Left stick y: 0.0004272591326639607
Left stick X: 0.024201178014465773
Left stick y: -0.0011291848506118961
Left stick y: -0.0029602954191717277
Left stick y: -0.007446516312143315
Left stick y: -0.00924710837122715
Left stick y: -0.013245033112582781
Left stick X: -0.01120029297769097
Right stick x: 0.021698660237434005
Right stick x: 0.04031495101779229
Left stick X: -0.017273476363414413
Right stick x: 0.06338694418164617
Left stick X: -0.1295815912350841
Right stick x: 0.1369975890377514
Left stick X: -0.23114719077120274
Left stick y: -0.01834162419507431
Right stick x: 0.22214423047578355
Left stick X: -0.3532517471846675
Left stick y: -0.02264473403118992
Right stick x: 0.325907162694174
Left stick X: -0.4641560106204413
Left stick y: -0.02655110324411756
Right stick x: 0.42701498458815274
Left stick X: -0.6020996734519486
Right stick x: 0.5494247260963775
Right stick y: 0.03247169408246101
Right stick y: 0.007019257179479354
Left stick X: -0.859309671315653
Right stick x: 0.7844477675710319
Right stick y: -0.0684835352641377
Left stick X: -1.000030518509476
Right stick x: 0.869594409009064
Right stick y: -0.10623493148594623
Right stick x: 0.9937742240668965
Right stick y: -0.1554002502517777
Right stick x: 0.9953306680501725
Right stick y: -0.2054506057924131
Right stick y: -0.20676290169988099
Right stick y: -0.23880733664967804
Right stick y: -0.24628437147129734
Left stick X: -0.9988708151493881
Left stick X: -0.695303201391644
Left stick y: -0.03250221259193701
Left stick y: -0.03811761833552049
Right stick x: 0.8953215124973296
Left stick X: 0.00836207159642323
Left stick y: -0.002197332682271798
Right stick x: -0.0696432386242256
Right stick y: 0.016693624683370465
Left stick X: 0.01022370067445906
Right stick x: 0.003967406231879635
Right stick y: 0.021057771538438064
button down: 12
button up: 12
Joystick 0 disconnected
And output on Serial1 from Arduino sketch (printk)
Joystick device added: 0
BDN: 12
BUP: 12
BDN: 4
BUP: 4
BDN: 3
BUP: 3
BDN: 1
BUP: 1
Hat: 0 1
Hat: 0 0
1:-182 1:911
1:1070
1:1131
1:963
1:899
1:760
1:703
1:561
1:504
1:1143
Next up, hook up Robotis Dynamixel shield and maybe put on Turtle Burger and see if I can drive the wheels with the joystick input...
Mainly just having some fun.
