I just got a powered mini usb hub to let me work on Arduino sensor projects that interface with a computer
that is 15 feet away. The minihub power supply is 5V 1000 mA.
The Arduino is connected to the usb hub and my DHT11 project works. I don't have a separate supply for the
Arduino.
The problem is a nearby radio is very noisy when the usb hub power supply is plugged in. I would like to
listen to the radio while I work and this could be a problem for my future wireless sensor projects.
I considered getting one of these RadioShack.com Official Site - America's Technology Store
for the hub power cord. But from info I saw on the web, these can't suppress the noise from poorly designed
power supplies. Investing in a quality supply makes more sense.
It is more likely to be the arduino itself rather than the power supply.
Check for one with an FCC approval, however cheaper power supplies say this without it being true.
If you can identify the actual frequency you might stand a chance.
Things to do:-
Look for a linear supply rather than a switching one.
Wrap the lead a few turns through a ferrite toroid.
bad_gui:
Does this mean you have 15 feet of USB cable?
bad_gui:
Arduino.
So what were you previously using to power the Arduino - presumably direct USB connection to the PC? Did that cause any problems with the radio, and was the radio previously as close to the Arduino/ PC?
bad_gui:
AM or FM? Substantial interference to AM radio is to be expected simply by proximity. If it is interfering with FM, now that's a concern!
