Anyone willing to help bash some existing code to work with one of my TFT screens?
Hello, trying to build a motorised camera slider and have all the mechanical and hardware sorted, but my Achilles' heel is always the code side of things.
I got the existing code from a youtube video, but it won't work with any of the TFT screens I have (all just show a white screen).
The ones I have:
Adafruit 2.8" TFT Touch Shield v2
OpenSmartStore 2.8" TFT ILI9320 Touch LCD
mcufriend 2.4 inch LCD monitor ili9325, ili9341
And here is the code I really need some help with (added the libraries and it compiles fine)
#include <Encoder.h>
#include <stdint.h>
#define DEBUG
#include <TouchScreen.h>
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
#include <Fonts/FreeSans9pt7b.h> // Hardware-specific library
#include <Fonts/FreeSans12pt7b.h> // Hardware-specific library
#include <Fonts/FreeSans18pt7b.h> // Hardware-specific library
#include <Fonts/FreeSans24pt7b.h> // Hardware-specific library
#include <Fonts/FreeMono24pt7b.h> // Hardware-specific library
#include <Fonts/FreeMono18pt7b.h> // Hardware-specific library
#include <Fonts/FreeMonoBold18pt7b.h> // Hardware-specific library
#include <Fonts/FreeMonoBold24pt7b.h> // Hardware-specific library
// These are the pins for the shield!
#define YP A2  // must be an analog pin, use "An" notation!
#define XM A3  // must be an analog pin, use "An" notation!
#define YM 8   // can be a digital pin
#define XP 9   // can be a digital pin
//IM - Touch Screen presure
#define MINPRESSURE 10
#define MAXPRESSURE 10000
//IM - Define the limits of the touch screen
#define TS_MINX 204
#define TS_MINY 195
#define TS_MAXX 948
#define TS_MAXY 910
//IM - TRINAMIC 2130 STEPPER DRIVER
#include <SPI.h> // SPI FOR SPI COMMS to the 2130 driver
#include <TMC2130Stepper.h>
#include <TMC2130Stepper_REGDEFS.h>
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// Assign human-readable names to some common 16-bit color values
// Modify these to match the colorspace of your LCD
#define	WHITE   0x0000 //
#define	YELLOW    0x001F //
#define	CYAN     0xF800 //
#define	PURPLE  0x07E0 //
#define RED    0x07FF //
#define GREEN 0xF81F //
#define BLUE  0xFFE0 //
#define BLACK   0xFFFF //
#define PIN_BATTVOLT 15
#define STEPSMM 160
//IM - Pins for the Encoder with button. If the encoders running backwards swap enc0 and enc1 pins
#define PIN_BUTTON 19
#define PIN_ENC0 21 //encoder pin 1
#define PIN_ENC1 20 //encoder pin 2
//IM - Stepper Driver Enable Pin
#define PIN_ENABLE 40
#define PIN_DIR 42
#define PIN_STEP 41
#define PIN_CS 53
#define MOSI_PIN 51
#define MISO_PIN 50
#define SCK_PIN 52
//IM - Step and direction pin settings for the Stepper driver
#define MAX_SPEED  40 // In timer value
#define MIN_SPEED  1000
#define STALL_VALUE 5 // [-64..63]
#define DEBOUNCE 300
#define MINRUNTIME 10000
//number of battery voltage points
#define LOOKUP 20
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// If using the shield, all control and data lines are fixed, and
// a simpler declaration can optionally be used:
// Adafruit_TFTLCD tft;
long day = 86400000; // 86400000 milliseconds in a day
long hour = 3600000; // 3600000 milliseconds in an hour
long minute = 60000; // 60000 milliseconds in a minute
long second =  1000; // 1000 milliseconds in a second
//IM - Instansiate the encoder (on the rotary button) and tell it what pins we have used
Encoder myEnc(PIN_ENC1, PIN_ENC0);
//Config for the Trinamic 2130 set the pins pins
TMC2130Stepper driver = TMC2130Stepper(PIN_ENABLE, PIN_DIR, PIN_STEP, PIN_CS);
long oldPosition  = 0;
//long MaxSlide = 73235; //IM - Test value for max slide (aprox 1mtr)
long MaxSlide = 0; //IM - holds the maximum number of steps for the length of the slide rail. Its set during initialisation proccess.
long calSteps = 0; //IM - holds the value of steps whilst performing the calibration.
long RailLength = 0; //IM - holds the value for the lenght of the rail;
float StepsPerMM = 80.3; //IM - the number of steps on my stepper motor that cover 1mm of rail travel.
volatile long numruns = 0;
volatile long period = 10000;
volatile long carragePos = 0; //the absolute carrage position on the slider.
volatile long lastTriggered = 0;
long nextBattMillis = 0;
long runtime = 0;
long offset = 0;
long sspeed = 0;
long decimals = 0;
//IM - Defines the mid point of the touch screen, this will determin the direction of movment, buy pressing either side of this line.
int ts_MID = 195;
byte oldDays = 0;
byte oldHours = 0;
byte oldMinutes = 0;
byte oldSeconds = 0;
boolean buttonPressed = false; //Holds the value seeing if the button has been pressed by the user
boolean srunning = false;
boolean sdir = 0; //Bit Direction of travel of the motor
boolean oldsdir = !sdir; //Bit holding the last known Direction of travel of the motor
boolean needsInit = false;
boolean drawnStatusBlank = 1;
boolean drawnStatus = srunning;
boolean driverEnabled = false; //set the default to the stepper driver disabled.
boolean calibratedSlider = false; //sets true if the slider rail has been calibrated to the length.
boolean stall = false; //set the motor stall value to false.
boolean TMC2130enabled = false;
boolean carrageHomed = false; //has the carraged reached its home position (during calibration)
boolean lcdFlipped = false; //has the LCD been installed physically upsidedown?
boolean haltCarrage = false;
boolean countCarrage = true;
boolean carrageHalted = false;
boolean stallSleep = false; //some times we dont want to detect a motor stall, like right after it just happend.
int stallSleepDuration = 1000;
int calibrationStep = 0; //IM - stores the value of the calibrations step 1 - 3. 3 is fully calibrated and homed.
float rawVolt;
float volt;
int checkInerval = 50; //use as a delay to count down too.
void catchButton() {
  if (lastTriggered + DEBOUNCE < millis()) {
    buttonPressed = true;
    lastTriggered = millis();
    Serial.print("catchButton: Button Pressed");
//enable the stepper driver
void enableTMC2130(){
  Serial.println("enableTMC2130: stepper ENABLED");
  digitalWrite(PIN_ENABLE, LOW);
  TMC2130enabled = true;
//dissables the stepper driver
void disableTMC2130(){
  Serial.println("disableTMC2130: stepper dissabled");
  digitalWrite(PIN_ENABLE, HIGH);
//IM - VSense for Trinamic 2130
bool vsense;
//IM - RMS current for Trinamic 2130
uint16_t rms_current(uint8_t CS, float Rsense = 0.11) {
  return (float)(CS+1)/32.0 * (vsense?0.180:0.325)/(Rsense+0.02) / 1.41421 * 1000;
//IM - Sets up the screen based on its physical mounted positon. Some screens may be mounted upsidedown for physical reasons
//this flips the image if required so the screen contents appear the right way up for the user. Other thigs get messed up when
//the screen is flipped round so we must account for that tool, setting the LCDFlipped bool helps track.
void SetScreenOrientation(bool flip){
    if(flip){
      tft.setRotation(3);
      lcdFlipped = true;
    else{
      tft.setRotation(1);
      lcdFlipped = false;
//##################################### SETUP #####################################
#ifdef DEBUG
  Serial.begin(250000);
  Serial.println(F("TFT LCD test"));
  Serial.print("TFT size is ");
  Serial.print(tft.width());
  Serial.print("x");
  Serial.println(tft.height());
#endif // DEBUG
  Serial.println("Setup Started");
  Serial.println("Instansiate TMC2130");
  //set TMC2130 config
  driver.begin();
  driver.rms_current(600); // mA
  driver.microsteps(16);
  driver.diag1_stall(1);
  driver.diag1_active_high(1);
  driver.coolstep_min_speed(0xFFFFF); // 20bit max
  driver.THIGH(0);
  driver.semin(5);
  driver.semax(2);
  driver.sedn(0b01);
  driver.sg_stall_value(STALL_VALUE);
  driver.stealthChop(1);
  Serial.println("Set stepper interrupt");
  // Set stepper interrupt
  cli();//stop interrupts
  TCCR1A = 0;// set entire TCCR1A register to 0
  TCCR1B = 0;// same for TCCR1B
  TCNT1  = 0;//initialize counter value to 0
  OCR1A = 256;// = (16*10^6) / (1*1024) - 1 (must be <65536)
  //turn on CTC mode
  TCCR1B |= (1 << WGM12);
  // Set CS11 bits for 8 prescaler
  TCCR1B |= (1 << CS11);// | (1 << CS10);
  // enable timer compare interrupt
  TIMSK1 |= (1 << OCIE1A);
  //sei();//allow interrupts
  //TMC2130 outputs on (LOW active)
  disableTMC2130();
  vsense = driver.vsense();
  //IM - SET THE STATE OF ALL THE PINS WE WILL BE USING
  //IM - Set the pins for the stepper driver
  //pinMode(PIN_STEP, OUTPUT); //step pin
  //pinMode(PIN_DIR, OUTPUT); //direction pin
  //pinMode(PIN_ENABLE, OUTPUT); //enable pin
  //IM - Set the initial pin states
  digitalWrite(PIN_BUTTON, HIGH); //IM - set the initial state of the button pin to high
  digitalWrite(PIN_ENABLE, LOW); //IM - set the initial state enable pin for the stepper driver
  tft.reset();
  uint16_t identifier = tft.readID();
  if (identifier == 0x9325) {
#ifdef DEBUG
    Serial.println(F("Found ILI9325 LCD driver"));
  } else if (identifier == 0x9328) {
    Serial.println(F("Found ILI9328 LCD driver"));
  } else if (identifier == 0x7575) {
    Serial.println(F("Found HX8347G LCD driver"));
  } else if (identifier == 0x9341) {
    Serial.println(F("Found ILI9341 LCD driver"));
  } else if (identifier == 0x8357) {
    Serial.println(F("Found HX8357D LCD driver"));
#endif // DEBUG
#ifdef DEBUG
    /*Serial.print(F("Unknown LCD driver chip: "));
    Serial.println(identifier, HEX);
    Serial.print(F("I try use ILI9341 LCD driver "));
    Serial.println(F("If using the Adafruit 2.8\" TFT Arduino shield, the line:"));
    Serial.println(F("  #define USE_ADAFRUIT_SHIELD_PINOUT"));
    Serial.println(F("should appear in the library header (Adafruit_TFT.h)."));
    Serial.println(F("If using the breakout board, it should NOT be #defined!"));
    Serial.println(F("Also if using the breakout, double-check that all wiring"));
    Serial.println(F("matches the tutorial."));*/
#endif // DEBUG
    identifier = 0x9341;
  tft.begin(identifier);
  //main timer for the slider application
  Timer1.initialize(period);         // initialize timer1, and set a 1/2 second period
  //  Timer1.pwm(9, 512);                // setup pwm on pin 9, 50% duty cycle
  Timer1.attachInterrupt(callback);  // attaches callback() as a timer overflow interrupt
  Timer1.stop();
  // IM - This is the interupt that will fire when the button is pressed
  attachInterrupt(digitalPinToInterrupt(PIN_BUTTON), catchButton, FALLING);
  //##################################### LCD ORIENTATION #####################################
  //IM - Set the screen orientation. True is normal, False upsideown.
  SetScreenOrientation(true);
  tft.fillScreen(BLACK);
  updateLCDTime(true);
  updateLCDStatus();
  rawVolt = ((float) + analogRead(PIN_BATTVOLT) + analogRead(PIN_BATTVOLT) + analogRead(PIN_BATTVOLT) + analogRead(PIN_BATTVOLT)) / 5;
  volt = toVolt(rawVolt);
  //enable the stepper motor.
  enableTMC2130();
//IM - Run the stepper motor.
//IM - this runs every half step
void callback()
  //IM - If the device has been calibrated we can check we dont hit the end of the rail
  if(calibratedSlider){
  //Run the position as a half time
  if(countCarrage){
      //if the direction is false then we are moving away from the home position towards MaxSlide
      if(sdir == true){
       if(carragePos != MaxSlide){
         //if it does then stop
          carragePos++;
       else{
          haltCarrage = true;
     //otherwise were heading for home watch out for 0
      }else{
       if(carragePos != 0){
          carragePos--;
        }else{
          haltCarrage = true;
      countCarrage = false;
    }else{
    //IM - Unless halt carrage is true run the slider
    if(!haltCarrage){
      numruns++;
      digitalWrite(PIN_STEP, digitalRead(PIN_STEP) ^ 1);
    }else{
      if(!carrageHalted){
        Serial.println("############  Carratge halted! ############");
        //stopSlider();
        catchButton(); //IM - emulate the button being pressed.
        carrageHalted = true;
  }else //if its not calibrated we'll just hit the buffers.
      numruns++;
void stopSlider(){
  Serial.println("############  stopSlider! ############");
  srunning = 0;
  //disableTMC2130();
  Timer1.stop();
  updateLCDStatus();
//cDir is ture for left false for right. Unless the screen has been flipped
void carrageDirection(bool cDir){
  if(cDir){
      if(oldsdir != cDir){
        digitalWrite(PIN_DIR, 0);
        sdir = true;
        Serial.print("#################################### Carrage Direction: ####################################");
        Serial.println(cDir);
        oldsdir = cDir;
        updateLcdDirection(cDir);
      digitalWrite(PIN_DIR, 1);
      sdir = false;
      oldsdir = cDir;
ISR(TIMER1_COMPA_vect){
  PORTF |= 1 << 0;
  PORTF &= ~(1 << 0);
//##################################### LOOP #####################################
  //##################################### Check Endstop Initiailisation #####################################
  //if the unit has just been switched on then perform a calibration of the rail.
  if(!calibratedSlider){
    Calibrate();
  }else{
  //if the calibration has already been done then
    MainLoop();
//calibrate the slider for MAXSlide.
void Calibrate()
    //if the carrage hasnt been homed then home it.
    if(!carrageHomed){
      HomeCarrage();
    }else{
      if(calibrationStep == 0)
        Serial.println("calibration step 1 complete");
        calibrationStep = 1;
    if(calibrationStep == 1){
      //once the carrage is at home send it all the way to the other end of the rail.
      if(MaxSlide == 0){
        SeekEndStop();
      }else{
        Serial.println("calibration step 2 complete");
        calibrationStep = 2;
    if(calibrationStep == 2){
         HomeCarrage();
       }else{
        Serial.println("calibration step 3 complete");
         calibrationStep = 3;
         calibratedSlider = true;
         carrageDirection(true);
void SeekEndStop(){
  //rest the stall value
  //IM - only run this part the first time we start this process.
  if(!TMC2130enabled)
    Serial.println("########### SeekEndStop ###########");
    resetStallSleep();
    enableTMC2130();
  static int cal_last_time = checkInerval;
  int StallVal;
  //set the carrage direction toward home
  if((cal_last_time--) == 0)//IM - dont run every loop the stepper driver wont like it!
    //Serial.println("Calibration Mode");
    uint32_t drv_status = driver.DRV_STATUS();
    StallVal = (drv_status & SG_RESULT_bm)>>SG_RESULT_bp;
    //Serial.println(StallVal);
    if(!stallSleep){
      if(StallVal == 0){
        stall = true;
        Serial.println("SeekEndStop: stall!");
  if(stallSleep){
    decrementStallSleep();
  if(!stall){
      digitalWrite(PIN_STEP, HIGH);
      delayMicroseconds(100);
      digitalWrite(PIN_STEP, LOW);
      calSteps++;
  }else{
      if(TMC2130enabled){
        stallSleep = true;
        MaxSlide = calSteps;
        CalcRailLength();
        Serial.print(" ########### Max Slide Found: ");
        Serial.print(MaxSlide);
        Serial.println(" ########### ");
        carragePos = MaxSlide; //as were at the end of the rail then set carrage pos to maxslide.
        disableTMC2130();
//IM - Calculates the lenght of the rail based on the number of steps taken before it hit the end (MaxSlide),
//devided by the number of steps taken in one mm (a fixed value up top calculated for our stepper motor).
void CalcRailLength(){
   //calculate the rail length in MM
  RailLength = MaxSlide / StepsPerMM;
  Serial.print(" ########### Rail Length: ");
  Serial.print(RailLength);
//psudo timer, allows some clock cycles to happen to delay a redetection of a motor stall.
void decrementStallSleep(){
  if(stallSleep){
    Serial.print("Stall Sleep:");
    Serial.println(stallSleepDuration);
    stallSleepDuration-- ;
    if(stallSleepDuration == 0){
      Serial.println("STALL SLEEP END");
      stallSleep = false;
//IM - if you know your not stalling out then you can reset the stall sleeper.
void resetStallSleep(){
      stall = false;
      stallSleep = false;
void HomeCarrage(){
  if(!TMC2130enabled){
    Serial.println("########### Home Carrage ###########");
    enableTMC2130();
    resetStallSleep();
    Serial.print("Check Interval: ");
    Serial.println(checkInerval);
    Serial.print("Stall: ");
    Serial.println(stall);
  int StallVal;
  carrageDirection(false);
    //Serial.println("HomeCarrage: here");
    if(!stallSleep){
      if(StallVal == 0){
        stall = true;
        Serial.println("HomeCarrage: Stall!");
        stallSleep = true;
  if(stallSleep){
  if(!stall){
  }else{
    stallSleep = true;
    carrageHomed = true;
    carragePos = 0; //IM - Where home!
    if(TMC2130enabled){
      Serial.println(" ########### Homed ############");
      //disableTMC2130();
void StartStop(){
    Serial.println("if button pressed");
    //if the slider is running then enable or dissable the stepper.
    if ((sspeed == 0) && (decimals == 0)) {
      srunning = 0;
      Serial.print("######### StartStop: STOPPED #########");
    else {
      Serial.print("######### StartStop: STARTED #########");
      if(carrageHalted == true){
      srunning = !srunning;
      setPeriod();
    updateLCDStatus();
void MainLoop(){
  static uint32_t last_time=0;
  uint32_t ms = millis();
  //##################################### ENCODER AND BUTTON START #####################################
  long newPosition = myEnc.read();
  if ((newPosition < 0) && (newPosition < offset)) {
    offset = newPosition;
  newPosition = newPosition - offset;
  //IM If the new position of the rotary encoder is different then..
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
    updateRuntime();
    //Serial.println(newPosition);
    //Serial.print("\n");
    setPeriod();
  //IM - If the interupt has been triggered by the button being pressed, buttonPressed will be true.
  if (buttonPressed) {
    StartStop();
  //##################################### ENCODER AND BUTTON END #####################################
  //##################################### TOUCH SCREEN START #####################################
  // a point object holds x y and z coordinates
  TSPoint p = ts.getPoint();
  pinMode(XM, OUTPUT);
  pinMode(YP, OUTPUT);
  // we have some minimum pressure we consider 'valid'
  // pressure of 0 means no pressing!
  //if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
  if (p.z > ts.pressureThreshhold) {
    //IM - Map the touch screen relitive to it size
    p.x = map(p.x, TS_MAXX, TS_MINX, 0, 320);
    p.y = map(p.y, TS_MAXY, TS_MINY, 0, 240);
    //IM - Print the y position value
    //Serial.print("X = "); Serial.print(p.x);
    //Serial.print("\tY = "); Serial.print(p.y);
    //a temporary variable to store the new direction
    int DIR = 0;
    //IM - If the new point os less than the mid value then its to the left.
    //IM - Note: this depends on physical screen orientation! if it is upside down change < to >.
    if (p.x < ts_MID) {
      sdir = 0; //IM - Set the direction bit to 0
      //IM - Write to the pin the direction value
      DIR = 0;
      //Serial.println("left");
    else {
      sdir = 1; //IM - Set the direction bit to 1
      DIR = 1;
      //Serial.println("right");
    //IM - if its a new direction up date the desplay
    carrageDirection(sdir);
    if (sdir != oldsdir) {
      updateLCDStatus();
  //##################################### TOUCH SCREEN END #####################################
  //##################################### BATTERY STATUS CHECK START #####################################
 // if ((long)(millis() - nextBattMillis) >= 0) {
    //update Battery status
 //   nextBattMillis += 10000;
 //   rawVolt = ((float)analogRead(PIN_BATTVOLT)) * 0.02 + rawVolt * 0.98;
 //   volt = toVolt(rawVolt);
 //   tft.setTextColor(WHITE);
 //   if (volt < 8) {
  //    tft.setTextColor(GREEN);
  //  if (volt < 7.2) {
  //   tft.setTextColor(YELLOW);
  // if (volt < 6.5) {
  //    tft.setTextColor(RED);
   // tft.fillRect(0, 110, 150, 22, BLACK);
   // tft.setTextSize(1);
   // tft.setCursor(0, 130);
   // tft.setFont(&FreeSans12pt7b);
   // tft.print(mapFloat(volt, 6, 8.4, 0, 100));   tft.print("% ");
   // tft.print("volt");   tft.print("V ");
   // tft.print("rawVolt");   tft.print("int ");
   // Serial.print("Battery Check:"); Serial.print(volt); Serial.print("; "); Serial.println(millis());
  //##################################### BATTERY STATUS CHECK END #####################################
void updateLcdDirection(bool d){
    if (!d) {
      tft.fillTriangle(
        320, 200, // peak
        280, 240, // bottom left
        320, 240, // bottom right
        BLACK);
      tft.fillTriangle(
        0, 200, // peak
        40, 240, // bottom right
        tft.color565(255, 0, 50));
    else {
      tft.fillTriangle(
        0, 200, // peak
        BLACK);
      tft.fillTriangle(
        320, 200, // peak
void updateLCDStatus() {
  if (runtime < MINRUNTIME) {
    if (!drawnStatusBlank) {
      tft.fillRect(75, 200, 170, 35, BLACK);
      srunning = 0;
      drawnStatus = 0;
    return;
  else if (drawnStatusBlank || (drawnStatus != srunning)) {
    tft.setTextSize(1);
    tft.setCursor(0, 0);
    tft.setFont(&FreeSans18pt7b);
    if (srunning) {
      tft.setCursor(75, 230);
      tft.print("RUNNING");
    else {
      tft.setCursor(100, 230);
      tft.setTextColor(BLUE);
      tft.print("READY");
    drawnStatusBlank = 0;
//IM Updates the runtime when the rotary encoder is turned.
void updateRuntime() {
  if (oldPosition != 0) {
    runtime = 1000 * oldPosition * oldPosition / 4;
  if (needsInit) {
  else {
    updateLCDTime(false);
  updateLCDStatus();
//IM Updates the LCD with the new run time
void updateLCDTime(boolean firstrun) {
  int days = runtime / day ;                                //number of days
  int hours = (runtime % day) / hour;                       //the remainder from days division (in milliseconds) divided by hours, this gives the full hours
  int minutes = ((runtime % day) % hour) / minute ;         //and so on...
  int seconds = (((runtime % day) % hour) % minute) / second;
  tft.setCursor(0, 20);
  tft.setTextSize(4);
  tft.setFont();
  if (oldPosition == 0) {
    tft.setCursor(42, 70);
    tft.setFont(&FreeMonoBold24pt7b);
    tft.setTextSize(2);
    tft.fillRect(0, 5, 320, 28, BLACK); //clear time
    tft.fillRect(0, 54, 320, 35, BLACK); // clear speed
    tft.print("HALT");
    srunning = false;
    tft.setTextSize(1);
    tft.setFont(&FreeMono18pt7b);
    tft.setCursor(0, 100);
    //   tft.print("0 mm/s");
    sspeed = 0;
    decimals = 0;
    needsInit = true;
  else {
    if (firstrun) {
      tft.fillRect(42, 24, 230, 30, BLACK); //clear HALT/STOP
    tft.setFont(&FreeMonoBold18pt7b);
    tft.setTextSize(1);
    //DAYS
    if ((days != oldDays) || firstrun) {
      tft.setCursor(0, 30);
      tft.fillRect(0, 5, 42, 28, BLACK);
      if (days < 10) {
        tft.print("0");
      tft.print(days);
      oldDays = days;
    //HOURS
    if (firstrun) {
      tft.print("d");
    tft.setCursor(80, 30);
    if ((hours != oldHours) || firstrun) {
      tft.fillRect(80, 5, 42, 28, BLACK);
      if (hours < 10) {
        tft.print("0");
      tft.print(hours);
      oldHours = hours;
    //MINUTES
    if (firstrun) {
      tft.print("h");
    tft.setCursor(160, 30);
    if ((minutes != oldMinutes) || firstrun) {
      tft.fillRect(160, 5, 42, 28, BLACK);
      if (minutes < 10) {
        tft.print("0");
      tft.print(minutes);
      oldMinutes = minutes;
    //SECONDS
    if (firstrun) {
      tft.print("m");
    tft.setCursor(240, 30);
    if ((seconds != oldSeconds) || firstrun) {
      tft.fillRect(240, 5, 42, 28, BLACK);
      if (seconds < 10) {
        tft.print("0");
      tft.print(seconds);
      oldSeconds = seconds;
    if (firstrun) {
      tft.print("s");
      needsInit = false;
    if ((oldPosition + offset) != myEnc.read()) {
      return;
    tft.setCursor(0, 80);
    tft.setTextSize(1);
    //IM INTERESTING.speed = distance over time
    //sspeed = (1000000) / (runtime);
     sspeed = (RailLength*1000) / (runtime);
    if (runtime < (MINRUNTIME * 2)) {
    tft.print(sspeed);
    tft.print(".");
    decimals = ((1000000000) / (runtime)) - (((1000000) / (runtime)) * 1000);
    //decimals = ((RailLength*1000000) / (runtime)) - (((RailLength*1000) / (runtime)) * 1000);
    if (decimals < 100) {
      if (decimals < 10) {
        tft.print("0");
      tft.print("0");
    tft.print(decimals);
    tft.print(" mm/s");
//########################### TIMER PERIOD ###############################
void setPeriod() {
  Serial.println("########################### set period ########################### ");
  if ((runtime < MINRUNTIME) | ! srunning) {
    Serial.print("srunning: ");
    Serial.println(srunning);
    //disableTMC2130();
    Timer1.stop();
    Serial.print("setPeriod: Timer Stopped");
    Serial.print("\n");
  else {
    //IM - TIMER CODE TO WORKOUT THE RUNNING TIME
      enableTMC2130();
    //calculate the speed in mm/s by deviding the rail lenght by the desired runtime in microseconds
    float ssspeed = (RailLength*1000) / ((float) runtime);
    float sps = ssspeed * (StepsPerMM);
    float pperiod = (RailLength*1000) / sps;
    Serial.print("RunTime: ");
    Serial.println(runtime);
    Serial.print("ssspeed: ");
    Serial.println(ssspeed,7);
    Serial.print("RailLength: ");
    Serial.println(RailLength*1000);
    Serial.print("sps: ");
    Serial.println(sps,7);
    pperiod = ((float)runtime)/((float)MaxSlide);
    Serial.print("setPeriod: ");
    Serial.println(pperiod);
    Timer1.setPeriod(pperiod*500);
float toVolt(float rawADC) {
  return mapFloat(rawADC, 0, 1023, 0, 10.8); //empirical calibration
float mapFloat(float x, float in_min, float in_max, float out_min, float out_max)
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
float lookup(float inval, short lut[][2], short clamp){
   float out;
   byte i;
   for (i=1; i<LOOKUP; i++)
      if (lut[i][0] > inval)
         return lut[i-1][1] + (inval - lut[i-1][0]) * (lut[i][1] - lut[i-1][1]) / (lut[i][0] - lut[i-1][0]);
   if (i == LOOKUP){
       return clamp;
Do you have a sketch around that works with any of the TFT screens you have?
a7
I dont, just got them in for this project. sure I can find one for the Adafruit one, will go see!
OK, the example sketches dont seem to work on the Adafruit one, just a white screen, tried with 2 different Mega 2560 boards...Could I have destroyed 3 screens in one night by being a potato!?
Yeah the Adafruit one is the best bet.
It may become falling off a log easy. Worst case, well, that'll be a bit of pain but nothing impossible.
Let us hope not. These screens are a PITA to get hooked up with the right library and settings, but they are reasonably hard to damage.
But you are on the essential path - find something that makes any screen you have do its demo code or a simple sketch exercising it.
Outside the context of the swamp you are trying to drain at the same time. ;-)
a7
OK, Some success!
Got two of them working, oddly enough not the Adafruit one?
Not got the code I want working....but
After a lot of googling, and finally finding info to edit the MCUFRIEND_kbv lib I got the OpenSmartStore 2.8" TFT ILI9320 Touch LCD working with the example code:
#include <MCUFRIEND_kbv.h>   // Hardware-specific library
MCUFRIEND_kbv tft;
#include <Fonts/FreeSerif12pt7b.h>
#include <FreeDefaultFonts.h>
#define BLACK   0x0000
#define RED     0xF800
#define GREEN   0x07E0
#define WHITE   0xFFFF
#define GREY    0x8410
void setup(void)
    uint16_t ID = tft.readID();
    Serial.println("Example: Font_simple");
    Serial.print("found ID = 0x");
    Serial.println(ID, HEX);
    if (ID == 0xD3D3) ID = 0x9481; //force ID if write-only display
    tft.begin(ID);
    tft.setRotation(0);
void loop(void)
    showmsgXY(20, 10, 1, NULL, "System x1");
    showmsgXY(20, 24, 2, NULL, "System x2");
    showmsgXY(20, 60, 1, &FreeSans9pt7b, "FreeSans9pt7b");
    showmsgXY(20, 80, 1, &FreeSans12pt7b, "FreeSans12pt7b");
    showmsgXY(20, 100, 1, &FreeSerif12pt7b, "FreeSerif12pt7b");
    showmsgXY(20, 120, 1, &FreeSmallFont, "FreeSmallFont");
    showmsgXY(5, 180, 1, &FreeSevenSegNumFont, "01234");
    showmsgXY(5, 190, 1, NULL, "System Font is drawn from topline");
    tft.setTextColor(RED, GREY);
    tft.setTextSize(2);
    tft.setCursor(0, 220);
    tft.print("7x5 can overwrite");
    tft.print("if background set");
    showmsgXY(5, 260, 1, &FreeSans9pt7b, "Free Fonts from baseline");
    showmsgXY(5, 285, 1, &FreeSans9pt7b, "Free Fonts transparent");
    showmsgXY(5, 285, 1, &FreeSans9pt7b, "Free Fonts XXX");
    showmsgXY(5, 310, 1, &FreeSans9pt7b, "erase backgnd with fillRect()");
    delay(10000);
void showmsgXY(int x, int y, int sz, const GFXfont *f, const char *msg)
    int16_t x1, y1;
    uint16_t wid, ht;
    tft.drawFastHLine(0, y, tft.width(), WHITE);
    tft.setFont(f);
    tft.setCursor(x, y);
    tft.setTextSize(sz);
    tft.print(msg);
And if I roll back the MCUFRIEND_kbv lib I get the 2.4 inch LCD monitor ili9325, ili9341 works with this example code, but blue and red are the wrong way round?
MCUFRIEND_kbv tft;
// Assign human-readable names to some common 16-bit color values:
#define BLUE    0x001F
#define RED     0xF800
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define GRAY    0x8410
uint16_t version = MCUFRIEND_KBV_H_;
    if (!Serial) delay(5000);           //allow some time for Leonardo
    uint16_t ID = tft.readID(); //
    Serial.println(F("Diagnose whether this controller is supported"));
    Serial.println(F("There are FAQs in extras/mcufriend_how_to.txt"));
    Serial.println(F(""));
    Serial.print(F("tft.readID() finds: ID = 0x"));
	Serial.print(F("MCUFRIEND_kbv version: "));
    Serial.print(version/100);
	Serial.print(F("."));
    Serial.print((version / 10) % 10);
    Serial.println(version % 10);
    if (ID == 0x0404) {
        Serial.println(F("Probably a write-only Mega2560 Shield"));
        Serial.println(F("#define USE_SPECIAL in mcufriend_shield.h"));
        Serial.println(F("#define appropriate SPECIAL in mcufriend_special.h"));
        Serial.println(F("e.g. USE_MEGA_16BIT_SHIELD"));
        Serial.println(F("e.g. USE_MEGA_8BIT_SHIELD"));
        Serial.println(F("Hint.  A Mega2560 Shield has a 18x2 male header"));
        Serial.println(F("Often a row of resistor-packs near the 18x2"));
        Serial.println(F("RP1-RP7 implies 16-bit but it might be 8-bit"));
        Serial.println(F("RP1-RP4 or RP1-RP5 can only be 8-bit"));
    if (ID == 0xD3D3) {
        uint16_t guess_ID = 0x9481; // write-only shield
        Serial.print(F("Try to force ID = 0x"));
        Serial.println(guess_ID, HEX);
        tft.begin(guess_ID);
    else tft.begin(ID);
    if (tft.width() == 0) {
        Serial.println(F("This ID is not supported"));
        Serial.println(F("look up ID in extras/mcufriend_how_to.txt"));
        Serial.println(F("you may need to edit MCUFRIEND_kbv.cpp"));
        Serial.println(F("to enable support for this ID"));
        Serial.println(F("e.g. #define SUPPORT_8347D"));
        Serial.println(F("New controllers appear on Ebay often"));
        Serial.println(F("If your ID is not supported"));
        Serial.println(F("run LCD_ID_readreg.ino from examples/"));
        Serial.println(F("Copy-Paste the output from the Serial Terminal"));
        Serial.println(F("to a message in Displays topic on Arduino Forum"));
        Serial.println(F("or to Issues on GitHub"));
        Serial.println(F("Note that OPEN-SMART boards have diff pinout"));
        Serial.println(F("Edit the pin defines in LCD_ID_readreg to match"));
        Serial.println(F("Edit mcufiend_shield.h for USE_SPECIAL"));
        Serial.println(F("Edit mcufiend_special.h for USE_OPENSMART_SHIELD_PINOUT"));
       while (1);    //just die
        Serial.print(F("PORTRAIT is "));
        Serial.print(F(" x "));
        Serial.println(F("Run the examples/graphictest_kbv sketch"));
        Serial.println(F("All colours, text, directions, rotations, scrolls"));
        Serial.println(F("should work.  If there is a problem,  make notes on paper"));
        Serial.println(F("Post accurate description of problem to Forum"));
        Serial.println(F("Or post a link to a video (or photos)"));
        Serial.println(F("I rely on good information from remote users"));
    static uint8_t aspect = 0;
    const char *aspectname[] = {
        "PORTRAIT", "LANDSCAPE", "PORTRAIT_REV", "LANDSCAPE_REV"
    const char *colorname[] = { "BLUE", "GREEN", "RED", "GRAY" };
    uint16_t colormask[] = { BLUE, GREEN, RED, GRAY };
    tft.setRotation(aspect);
    int width = tft.width();
    int height = tft.height();
    tft.fillScreen(colormask[aspect]);
    tft.drawRect(0, 0, width, height, WHITE);
    tft.drawRect(32, 32, width - 64, height - 64, WHITE);
    tft.setTextSize(2);
    tft.setTextColor(BLACK);
    tft.setCursor(40, 40);
    tft.print("ID=0x");
    tft.print(ID, HEX);
    if (ID == 0xD3D3) tft.print(" w/o");
    tft.setCursor(40, 70);
    tft.print(aspectname[aspect]);
    tft.setCursor(40, 100);
    tft.print(width);
    tft.print(" x ");
    tft.print(height);
    tft.setCursor(40, 130);
    tft.print(colorname[aspect]);
    tft.setCursor(40, 160);
    tft.setTextSize(1);
    tft.print("MCUFRIEND_KBV_H_ = ");
    tft.print(version);
    if (++aspect > 3) aspect = 0;
    delay(5000);
Here you seem to add 4 numbers and divide by 5 to calculate an average.
Sum could be done in for loop. Divide by 4 is faster for integers.
(float) before + seems strange. Why not do float conversion after adding the numbers?
If your code works and only colors are swapped, your code uses a different standard. That is seen more often. These screens often use 16 bit coding. Two colors are in 5 bit resolution, one in 6 bit resolution. Usually it is in RGB but other orders are aldo used. Your standard colors are inverse... usually FFFF is black and 0000 is white...
Hello, thank you so much for the reply.
To be 100% honest with you it is not my code and I hardly understand a thing about it, I ideally need help getting it to work with my hardware as I have a different screen from the person who put the code out into the world. My programming skills are very much just basic MicroPython, I have always struggled with getting my head around Arduino/C . So, really can't say what's good or bad, but would love any recommendations for that could be changed but would settle for changing it to work with one of TFT screens I have managed to get working with their example code (to me a huge achievement in and of itself)
Thank you I will look into this!
This is what I might call a slog. It was the harder work I alluded to earlier.
Basically on your hands and knees find all calls and variables that involve the display and library you are not using, and replace them equivalent calls to the display and library you have working code for. Pick one that works…
It is unlikely that one display has features that can't be done on another.
I don't know if this is without your current level of comfort. Point out clearly the posted code you want the new display to go with, and the example code that makes the new display work.
Or post those programs.
I can't say I'll do the lifting, heavy or not, but I will engage the Umbrella Academy and see if it is a ridiculously hard or just a kinda sorta annoying task.
If you were willing to tinker with the code a bit more, you could do a two-step, where the display is temporarily eliminated in favor of the serial monitor as a stand-in, then meet halfway later with any display of any ilk as a drop in, as you will have encapsulated the display portion as a module.
a7
My comfort level is fairly low :sweat_smile: but I am willing to put the work in and at least try and learn.
So here is the code I would like to use...and I'm assuming based on all the googling last night it is meant to run on an Adafrult TFTLCD shild based on the inclusion of the Adafruit_TFTLCD lib being hardware specific and though I have one that should work, it appears to be a duffer. :man_shrugging:
#include <stdint.h>
#define DEBUG
#define TS_MINX 204
#define TS_MINY 195
#define TS_MAXX 948
#define TS_MAXY 910
#define STEPSMM 160
#define PIN_DIR 42
#define PIN_STEP 41
#define PIN_CS 53
#define MOSI_PIN 51
#define MISO_PIN 50
#define SCK_PIN 52
#define LOOKUP 20
long runtime = 0;
long offset = 0;
long sspeed = 0;
long decimals = 0;
int ts_MID = 195;
byte oldDays = 0;
byte oldHours = 0;
float rawVolt;
float volt;
bool vsense;
    if(flip){
      tft.setRotation(3);
      lcdFlipped = true;
    else{
      tft.setRotation(1);
      lcdFlipped = false;
#ifdef DEBUG
  Serial.print("x");
#endif // DEBUG
  driver.begin();
  driver.THIGH(0);
  driver.semin(5);
  driver.semax(2);
  driver.sedn(0b01);
  //turn on CTC mode
  disableTMC2130();
  tft.reset();
#ifdef DEBUG
#endif // DEBUG
#ifdef DEBUG
#endif // DEBUG
  Timer1.stop();
  updateLCDStatus();
  enableTMC2130();
void callback()
  if(countCarrage){
      if(sdir == true){
          carragePos++;
       else{
          haltCarrage = true;
      }else{
          carragePos--;
        }else{
          haltCarrage = true;
    }else{
    if(!haltCarrage){
      numruns++;
    }else{
      if(!carrageHalted){
        //stopSlider();
      numruns++;
void stopSlider(){
  srunning = 0;
  //disableTMC2130();
  Timer1.stop();
  updateLCDStatus();
  if(cDir){
        sdir = true;
        oldsdir = cDir;
      sdir = false;
      oldsdir = cDir;
  PORTF |= 1 << 0;
  PORTF &= ~(1 << 0);
    Calibrate();
  }else{
    MainLoop();
void Calibrate()
    if(!carrageHomed){
      HomeCarrage();
    }else{
      if(MaxSlide == 0){
        SeekEndStop();
      }else{
         HomeCarrage();
       }else{
void SeekEndStop(){
  if(!TMC2130enabled)
    resetStallSleep();
    enableTMC2130();
  int StallVal;
    if(!stallSleep){
      if(StallVal == 0){
        stall = true;
  if(stallSleep){
  if(!stall){
      calSteps++;
  }else{
      if(TMC2130enabled){
        stallSleep = true;
        CalcRailLength();
        disableTMC2130();
  if(stallSleep){
      stallSleep = false;
      stall = false;
      stallSleep = false;
void HomeCarrage(){
    enableTMC2130();
    resetStallSleep();
  int StallVal;
    if(!stallSleep){
      if(StallVal == 0){
        stall = true;
        stallSleep = true;
  if(stallSleep){
  if(!stall){
  }else{
    stallSleep = true;
    if(TMC2130enabled){
      //disableTMC2130();
void StartStop(){
      srunning = 0;
    else {
      setPeriod();
    updateLCDStatus();
void MainLoop(){
    updateRuntime();
    setPeriod();
    StartStop();
    int DIR = 0;
    if (p.x < ts_MID) {
      DIR = 0;
    else {
      DIR = 1;
      updateLCDStatus();
 //   if (volt < 8) {
    if (!d) {
      tft.fillTriangle(
        320, 200, // peak
        BLACK);
      tft.fillTriangle(
        0, 200, // peak
    else {
      tft.fillTriangle(
        0, 200, // peak
        BLACK);
      tft.fillTriangle(
        320, 200, // peak
      srunning = 0;
      drawnStatus = 0;
    return;
    tft.setTextSize(1);
    if (srunning) {
    else {
      tft.print("READY");
  if (needsInit) {
  else {
  updateLCDStatus();
  tft.setTextSize(4);
  tft.setFont();
    tft.setTextSize(2);
    tft.print("HALT");
    srunning = false;
    tft.setTextSize(1);
    sspeed = 0;
    decimals = 0;
    needsInit = true;
  else {
    if (firstrun) {
    tft.setTextSize(1);
    //DAYS
      if (days < 10) {
        tft.print("0");
      tft.print(days);
      oldDays = days;
    //HOURS
    if (firstrun) {
      tft.print("d");
      if (hours < 10) {
        tft.print("0");
      tft.print(hours);
      oldHours = hours;
    //MINUTES
    if (firstrun) {
      tft.print("h");
      if (minutes < 10) {
        tft.print("0");
      tft.print(minutes);
    //SECONDS
    if (firstrun) {
      tft.print("m");
      if (seconds < 10) {
        tft.print("0");
      tft.print(seconds);
    if (firstrun) {
      tft.print("s");
      needsInit = false;
      return;
    tft.setTextSize(1);
    tft.print(sspeed);
    tft.print(".");
        tft.print("0");
      tft.print("0");
    tft.print(" mm/s");
void setPeriod() {
    //disableTMC2130();
    Timer1.stop();
    Serial.print("\n");
  else {
      enableTMC2130();
   float out;
   byte i;
   if (i == LOOKUP){
       return clamp;
So, that is the code I would like to run, but on a different bit of hardware that I managed to get working last night with the lib example files bellow:
MCUFRIEND_kbv tft;
#define RED     0xF800
#define GREY    0x8410
void setup(void)
    tft.begin(ID);
    tft.setRotation(0);
void loop(void)
    tft.setTextSize(2);
    delay(10000);
    int16_t x1, y1;
    uint16_t wid, ht;
    tft.setFont(f);
    tft.print(msg);
Now this one seems to be using the MCUFRIEND_kbv lib with a few changes to the config files related to board pinouts. But that's as far as iv got!
And another quick question is there a simple way to change a liberty name, as one screen works with unmodified MCUFRIEND_kbv and one works with modified, is it possible to have both libraries with say just a suffix for the TFT model? As of right now I'm just keeping both in a random folder and moving the right one into the Arduino liberties folder as and when needed.
OK my beach buddy is late, I took a few steps. She who must not be kept waiting - the irony. I won't say it like that to her, natch.
But it seems like the easier thing to do is to get a good copy of the correct display and just use it!
Here are the unique calls made to the touch screen and the display:
// touch screen - not too bad. some constants may need fixing and it may be reversed or flipped
// display - dozens of calls. yikes.
tft.fillTriangle(
tft.print(" mm/s");
tft.reset();
tft.setFont();
tft.setRotation(1);
tft.setRotation(3);
tft.setTextSize(4);
Any library will provide those calls or a variant. All told there are a bit more than 100 lines of code to examine and adjust.
No fun at all. What's your time <-> money equation tell you about what kind of fun you want to have and at what cost? :expressionless:
a7
usually the pins used by the TS need to be switched back to 'OUTPUT' after use (being the call to .getPoint() ) before the tft can be used again.
   pinMode(XP,  OUTPUT);
   pinMode(YM,  OUTPUT);
at least when using the MCUFriend library i have.
Now these pins are specific for a shield of a particular type.
i found the most common ones to be
// most mcufriend shields use these pins and Portrait mode:
const uint8_t YP = A1;  // must be an analog pin, use "An" notation!
const uint8_t XM = A2;  // must be an analog pin, use "An" notation!
const uint8_t YM = 7;   // can be a digital pin
const uint8_t XP = 6;   // can be a digital pin
:joy: Thank you so much for the help, I will do some reading up to try and understand whats going on there and modify as needed
Think you, much appreciated.
On a related topic, found my Adafruit 2.8" works with the Adafruit_ILI9341 library, but only on a UNO, just a white screen on a Mega though???
Oh, that should be easy to fix.
Find a good solid reference on the pins and their functions, which vary from Arduino board model to Arduino board model and make sure that...
all the pins you use in one place are OK and the ones you think in the other.
Also: in the IDE, use prefernces and set the compiler to show "verbose" output and "all" warnings.
Comb through the verbose output you get when compiling or verifying, and heed the advices in the red print, or at least assure yourself or ask here if a warning is a problem or not.
a7
Ahhh awesome tip, thank you!
Is it an SPI controlled shield ? the SPI pins on the Mega are different than on an UNO
It is!
And just noticed there are 2 sets of 3 tiny jumper pads that say mega and leo (assume they are jumpers for the mega board and Leonardo.
The mega screenprint says: ICSP, then sck, sc, si
and the Leo screenprint says: 13,12,11
Time to head up the soldering iron?
maybe, but how about you disconnect the connection from the shield to pin 10, 11, 12 & 13 and connect those SPI pins of the shield to pins 50 - 53 . Check the correct wiring i think it's
  UNO   |   MEGA
SS 10 | 53
MOSI 11 | 51
MISO 12 | 50
SCK 13 | 52
that might be something unrelated, Show us the picture.
Thank you, now got all 3 screens working (the little jumper pad did need jumping.
I thought I would try running the code that I wanted to run or the Adafruit screen as I belive this is the setup the guy who wrote the code used.
#include <stdint.h>
#define DEBUG
#define TS_MINX 204
#define TS_MINY 195
#define TS_MAXX 948
#define TS_MAXY 910
#define STEPSMM 160
#define PIN_DIR 42
#define PIN_STEP 41
#define PIN_CS 53
#define MOSI_PIN 51
#define MISO_PIN 50
#define SCK_PIN 52
#define LOOKUP 20
long runtime = 0;
long offset = 0;
long sspeed = 0;
long decimals = 0;
int ts_MID = 195;
byte oldDays = 0;
byte oldHours = 0;
float rawVolt;
float volt;
bool vsense;
    if(flip){
      tft.setRotation(3);
      lcdFlipped = true;
    else{
      tft.setRotation(1);
      lcdFlipped = false;
#ifdef DEBUG
  Serial.print("x");
#endif // DEBUG
  driver.begin();
  driver.THIGH(0);
  driver.semin(5);
  driver.semax(2);
  driver.sedn(0b01);
  //turn on CTC mode
  disableTMC2130();
  tft.reset();
#ifdef DEBUG
#endif // DEBUG
#ifdef DEBUG
#endif // DEBUG
  Timer1.stop();
  updateLCDStatus();
  enableTMC2130();
void callback()
  if(countCarrage){
      if(sdir == true){
          carragePos++;
       else{
          haltCarrage = true;
      }else{
          carragePos--;
        }else{
          haltCarrage = true;
    }else{
    if(!haltCarrage){
      numruns++;
    }else{
      if(!carrageHalted){
        //stopSlider();
      numruns++;
void stopSlider(){
  srunning = 0;
  //disableTMC2130();
  Timer1.stop();
  updateLCDStatus();
  if(cDir){
        sdir = true;
        oldsdir = cDir;
      sdir = false;
      oldsdir = cDir;
  PORTF |= 1 << 0;
  PORTF &= ~(1 << 0);
    Calibrate();
  }else{
    MainLoop();
void Calibrate()
    if(!carrageHomed){
      HomeCarrage();
    }else{
      if(MaxSlide == 0){
        SeekEndStop();
      }else{
         HomeCarrage();
       }else{
void SeekEndStop(){
  if(!TMC2130enabled)
    resetStallSleep();
    enableTMC2130();
  int StallVal;
    if(!stallSleep){
      if(StallVal == 0){
        stall = true;
  if(stallSleep){
  if(!stall){
      calSteps++;
  }else{
      if(TMC2130enabled){
        stallSleep = true;
        CalcRailLength();
        disableTMC2130();
  if(stallSleep){
      stallSleep = false;
      stall = false;
      stallSleep = false;
void HomeCarrage(){
    enableTMC2130();
    resetStallSleep();
  int StallVal;
    if(!stallSleep){
      if(StallVal == 0){
        stall = true;
        stallSleep = true;
  if(stallSleep){
  if(!stall){
  }else{
    stallSleep = true;
    if(TMC2130enabled){
      //disableTMC2130();
void StartStop(){
      srunning = 0;
    else {
      setPeriod();
    updateLCDStatus();
void MainLoop(){
    updateRuntime();
    setPeriod();
    StartStop();
    int DIR = 0;
    if (p.x < ts_MID) {
      DIR = 0;
    else {
      DIR = 1;
      updateLCDStatus();
 //   if (volt < 8) {
    if (!d) {
      tft.fillTriangle(
        320, 200, // peak
        BLACK);
      tft.fillTriangle(
        0, 200, // peak
    else {
      tft.fillTriangle(
        0, 200, // peak
        BLACK);
      tft.fillTriangle(
        320, 200, // peak
      srunning = 0;
      drawnStatus = 0;
    return;
    tft.setTextSize(1);
    if (srunning) {
    else {
      tft.print("READY");
  if (needsInit) {
  else {
  updateLCDStatus();
  tft.setTextSize(4);
  tft.setFont();
    tft.setTextSize(2);
    tft.print("HALT");
    srunning = false;
    tft.setTextSize(1);
    sspeed = 0;
    decimals = 0;
    needsInit = true;
  else {
    if (firstrun) {
    tft.setTextSize(1);
    //DAYS
      if (days < 10) {
        tft.print("0");
      tft.print(days);
      oldDays = days;
    //HOURS
    if (firstrun) {
      tft.print("d");
      if (hours < 10) {
        tft.print("0");
      tft.print(hours);
      oldHours = hours;
    //MINUTES
    if (firstrun) {
      tft.print("h");
      if (minutes < 10) {
        tft.print("0");
      tft.print(minutes);
    //SECONDS
    if (firstrun) {
      tft.print("m");
      if (seconds < 10) {
        tft.print("0");
      tft.print(seconds);
    if (firstrun) {
      tft.print("s");
      needsInit = false;
      return;
    tft.setTextSize(1);
    tft.print(sspeed);
    tft.print(".");
        tft.print("0");
      tft.print("0");
    tft.print(" mm/s");
void setPeriod() {
    //disableTMC2130();
    Timer1.stop();
    Serial.print("\n");
  else {
      enableTMC2130();
   float out;
   byte i;
   if (i == LOOKUP){
       return clamp;
But run into a little trouble when compiling:
In file included from C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:10:0:
C:\Users\pigeon\Documents\Arduino\libraries\Adafruit_TFTLCD_Library/Adafruit_TFTLCD.h:20:1: error: 'define' does not name a type; did you mean 'rewind'?
 define USE_ADAFRUIT_SHIELD_PINOUT 1
 rewind
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:106:1: error: 'Adafruit_TFTLCD' does not name a type; did you mean 'Adafruit_GFX'?
 Adafruit_GFX
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino: In function 'void catchButton()':
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:179:32: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino: In function 'void SetScreenOrientation(bool)':
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:214:7: error: 'tft' was not declared in this scope
       tft.setRotation(3);
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:218:7: error: 'tft' was not declared in this scope
       tft.setRotation(1);
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino: In function 'void setup()':
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:231:16: error: 'tft' was not declared in this scope
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino: In function 'void MainLoop()':
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:703:19: warning: unused variable 'last_time' [-Wunused-variable]
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:704:12: warning: unused variable 'ms' [-Wunused-variable]
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino: In function 'void updateLcdDirection(bool)':
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:828:7: error: 'tft' was not declared in this scope
       tft.fillTriangle(
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:844:7: error: 'tft' was not declared in this scope
       tft.fillTriangle(
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino: In function 'void updateLCDStatus()':
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:868:7: error: 'tft' was not declared in this scope
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:878:5: error: 'tft' was not declared in this scope
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino: In function 'void updateLCDTime(boolean)':
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:928:3: error: 'tft' was not declared in this scope
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino: In function 'float lookup(float, short int (*)[2], short int)':
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:1159:10: warning: unused variable 'out' [-Wunused-variable]
    float out;
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:1173:1: warning: control reaches end of non-void function [-Wreturn-type]
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino: At global scope:
C:\Users\pigeon\AppData\Local\Temp\.arduinoIDE-unsaved20221010-12228-14aw40l.qusrm\sketch_nov10a\sketch_nov10a.ino:703:19: warning: 'last_time' defined but not used [-Wunused-variable]
exit status 1
Compilation error: 'Adafruit_TFTLCD' does not name a type; did you mean 'Adafruit_GFX'?
i doubt that he used an SPI screen, since the object is declared for a non-spi screen
there appears to be a '#' missing here
there are some unused variables, which is suspicious,
and some cascading from the tft object not being declared.
don't really know what to say about this function either
   float out;
   byte i;
   if (i == LOOKUP){
       return clamp;
the programming style is well don't know how to put it.
I am not going to help you fix this up, contact the author for support i'd say.
