App crashes when using ESP32 boards
@beablossomr @sonofcy
Heartening to hear that you both think corruption is unlikely, I certainly don't relish the prospect of putting my Mac back to factory defaults!
I have updated to IDE 2.3.10 and it made no difference, I will reinstall the relevant libraries to see if that makes a difference.
The old adage "the poor man pays twice" has certainly come to pass in this instance, I will look at ordering a couple of SEEED XIAO boards and see what happens.
As I said before, in Terminal if I use the "ls /dev.tty.*" command, the board shows up but for some reason refuses to output data as it did before. This is what is so frustrating, it seems that the boards functionality is diminishing by the day!
I didn't read the entire thread, but what happens if you load the blink sketch and then more complex sketches from the examples?
@sonofcy
The only time I have a problem is when I want to output data to Terminal on my Mac, if I direct any output to the serial monitor instead the sketches work fine.
I have a Mac, but not knowledgeable re what you are doing. Can you easily tell me what you are trying to do and I can try it with some of my esp32 modules including XIAO's.
I have it working. Did you 'kill' the IDE monitor screen? Little X left side top of monitor, see attached. Attached is my Mac screen
Looks like you can mark post 25 as Solution.
@sonofcy
It doesn’t Work for me. When I type “screen /dev/tty.usbmodem22401 38400” I get an error message saying no such file or directory, so no output. It worked before, which is why I suspected corruption somewhere, it is either that or the boards have failed. What I wanted to do was to read the data from a temperature sensor and print it on Terminal every 5 seconds. When you got that to work, did it repeat? I have tried it now with 2 x ESP32 boards and 3 x ESP32-3C boards. It worked with the two original ESP32-3C boards. I would be happy to discover the boards are at fault, meaning my Mac is OK.
I guarantee you it is not the Mac. Let's review carefully.
  1. Upload the sketch in post 18
  2. Once you see the reset message, click on the Serial monitor icon top right.
  3. First make sure the baud rate is the same everywhere, code is 38,400, monitor is 38,400 and the terminal screen command is 38,400 as seen here.
  1. Now you should see the following on the Serial monitor
  1. Click the X marked in red.
  2. Switch to a standard Terminal session, not the fancy one you used.
  3. Note the USB port at the bottom right like this
  1. Enter the screen command in the normal Terminal app like the following. Notice the same 38400 baud rate, and the USB port as in /dev/cu.usbserial-0001
If you do NOT see this, do a screen grab of whatever the Terminal app is showing.
Should not be tty. Show me the full screen after a successful upload and you click the Monitor button top right. I want to see if your port name has tty or usb in it.
BTW, do NOT buy from Temu, either Amazon or Aliexpress, eBay is suspect, but Temu is real bad.
If I am starting something new, I order one from Amazon to get it in a few days, and if I need more than I order the rest from Aliexpress since they take longer. I stay away from eBay unless it's unique due to US/Canada border issues and very poor return policy made even worse due to US/Canada border even before Trump and virtually impossible now. Temu never enters the decision.
This looks like it is wrong, I use usb you use tty mine works yours does not. Conclusion is ???
I don't use a Mac but was curious about the /dev/cu. vs /dev/tty. naming and how it maps to e.g. /dev/ttyUSB0 on Linux and other *nixes. I did a bit of Googling and found this helpful article that explains why you get two devices on a Mac. Learned something new today.
Waiting with interest to hear whether using /dev/cu.... makes a difference.
Its well known that cloned Nanos and other small 328P/B boards often have fake UARTs and dodgy 328PB chips on them, but I didn't know that there are dodgy ESP32's as well. I wouldn't be surprised if they were factory QC fails or similar. @SierraGolfMike , does the top of the ESP module can on your dev board actually look like the one in the listing photo, ie. with just ESP-32 printed on it? Or does it actually have some further information etched onto it?
I have only ever purchased one item from Temu, but it was not a development board. I think one has to be a bit careful with Ali as well. Listing titles on both employ a lot of keyword spamming. Its seems there are far more of these dodgy products around than there used to be.
I buy lots of stuff from Aliexpress. I have had very few issues with them. A couple times packages went missing and they promptly refunded my money, another time after the refund a neighbour who was away had recieved the parcel in error and when I told AE they said just keep it. I may have got a few bad parts, but I am talking about maybe one a year. I have that many or more from Amazon as well.
@sonofcy
the sketch loads but nothing appears on the serial monitor:
Try clicking the buton top right to restart the monitor, sometimes it gets sticky.
Also try the reset button once or twice. Give it some time though, maybe 3 to 5 secs. I don;t see the boot up messages, can you try the blink sketch and show us the same screen?
What are your compile warnings set to, they should look like this. Also show me the last 10 lines of the upload screen before you turn on the monitor.
Up the baud rate to 115,200 and show me the monitor after clicking the monitor button top right. It should look like the following, roughly.
@sonofcy Last lines of compile:
still nothing appears in the serial monitor
@sonofcy I really appreciate the time you are taking to try and help me, thank you. I know nothing is coming up on the serial monitor so nothing will appear in the Terminal. Out of curiosity though what are you typing into terminal? I have sketches where the form screen /dev/tty.usbmidem**** works but willing to try anything!. The boards are connecting up and allowing the code to be uploaded by the ports appear to be fairly random, could this be the problem?
Been at this for about 14 hours on an off today so signing of for the night and will pick up in the morning.
Many thanks again for your sterling efforts.
That's the upload, now press the Serial.monitor button top right.
You may need to click it more than once, but if after a few tries you don;t see junk in the Serial.Monitor then the board is damaged. Do the same thing with a known working board to see the difference.
