App inventor question
I wrote a code for an RC car, and I want to control it with a joystick in the APP INVENTOR. How do I set the block?
#include <SoftwareSerial.h>
#include <Servo.h>
Servo myServo;
int motor_pwm = 8;
int motor_pwm1 = 2;
int motor_pwm2 = 3;
int r_motor_n = 10; //PWM control Right Motor +
int r_motor_p = 11; //PWM control Right Motor -
int l_motor_p = 9; //PWM control Left Motor -
int l_motor_n = 6; //PWM control Left Motor +
int s_motor_p = 4; //PWM control Left Motor -
int s_motor_n = 5; //PWM control Left Motor +
int serv = 13;
int speedy = 255;
char incomingByte = 0; // for incoming serial data
SoftwareSerial ble ( 0, 1 );
  Serial.begin ( 9600 );
  ble.begin ( 9600 );
  myServo.attach(13);
  myServo.write(0);
  pinMode(motor_pwm, 0);
  pinMode(motor_pwm1, 0);
  pinMode(motor_pwm2, 0);
  pinMode(r_motor_n, OUTPUT); //Set control pins to be outputs
  pinMode(r_motor_p, OUTPUT);
  pinMode(l_motor_p, OUTPUT);
  pinMode(l_motor_n, OUTPUT);
  pinMode(s_motor_p, OUTPUT);
  pinMode(s_motor_n, OUTPUT);
  digitalWrite(r_motor_n, LOW); //set both motors off for start-up
  digitalWrite(r_motor_p, LOW);
  digitalWrite(l_motor_p, LOW);
  digitalWrite(l_motor_n, LOW);
  digitalWrite(s_motor_p, LOW);
  digitalWrite(s_motor_n, LOW);
  analogWrite(motor_pwm, 255);
  analogWrite(motor_pwm1, 255);
  analogWrite(motor_pwm2, 255);
  if (ble.available() > 0)
    incomingByte = ble.read();
    Serial.println(incomingByte);
    switch (incomingByte)
      case 'S': // control to stop the robot
        Serial.println("Stop");
        incomingByte = '*';
      case 'R': //control for right
        analogWrite(r_motor_n, speedy);
        analogWrite(l_motor_p, speedy);
        Serial.println("right");
        incomingByte = '*';
      case 'L': //control for left
        analogWrite(r_motor_p, speedy);
        analogWrite(l_motor_n, speedy);
        Serial.println("left");
        incomingByte = '*';
      case 'F': //control for forward
        Serial.println("forward");
        incomingByte = '*';
      case 'B': //control for backward
        Serial.println("back");
        incomingByte = '*';
      case 'M': //control Mopper
        digitalWrite(s_motor_n, speedy);
        analogWrite(s_motor_p, LOW);
        Serial.println("mopper on");
        incomingByte = '*';
      case 'm': //Stop Mopper
        Serial.println("mopper off");
        incomingByte = '*';
      case 'U': // roller up
        myServo.write(0);
        Serial.println("roller up");
        incomingByte = '*';
      case 'u': // roller down
        myServo.write(135);
        Serial.println("roller down");
        incomingByte = '*';
      case 'a':
        speedy = 100;
        Serial.println("speed= 10");
        incomingByte = '*';
      case 'b':
        speedy = 150;
        Serial.println("speed= 25");
        incomingByte = '*';
      case 'c':
        speedy = 200;
        Serial.println("speed= 75");
        incomingByte = '*';
      case 'd':
        speedy = 255;
        Serial.println("speed= 100");
        incomingByte = '*';
Without even looking, I’ll ask to see the schematic and power supply arrangements.
Hi.
How far have you gone in learning how to use MIT AI and build apps?
If you are seeking help in building the app, the MIT AI forum is a better place to get that help.
I'm new to app inventor, thanks for the advice
Here's the link to the MIT AI forum:
https://community.appinventor.mit.edu/c/mit-app-inventor-help/52
