Archery Timer Help
Hi everyone, I have now joined this wonderful site and I would like to ask for your assistance..... My local Archery Club Coach ask me if I could build him a Countdown Timer for the club. My daughter is in this club so I told him I would do some research and let him know. I am new to arduino, so I need some assistance. The principle of operation for the timmer is as follows:
At the start of the competition when the archers are on the waiting line a timmer will be set for the period to shoot which is 3 to 4 minuites or a given time. so, If the time to shoot is 3 minuites an additional 10 seconds is set on the timer for the archer to get to the shooting line.
How it works.
Lets say the shooting time is 3 Minuites with additional 10 seconds = 3:10Sec.
While the Archer is on the waiting Line a button is press and a Single Buzzer will go off and the Archer moves to the Shooting Line wihile the timer is counting down and a Yellow lights is illuminated.
after the 10 Seconds is up, a Blast of 2 Buzzing wistle will sound and the lights will change to green and the archers start shooting there arrows. After the 3 minuites are up a Blats of 3 Buzzing wistle will sound for the archers to stop shooting and the light turn Red. and this is repeated for the next rounds of competition.
Can anyone assist me with this project Schematic and Coding? I would really like to do this for our Club.
With great appreciation.
Andre
why did the coach asked you? do you have some programming or engineering background?
that's more than assistance... that's doing the work for you...
the idea of this forum is not to code for you, but assist with YOUR code to help you progress and learn. I'd suggest you give it a try , do a few tutorials and learn the basics before jumping in.
if you don't want to learn, this seems a great ask for the Jobs and Paid Consultancy forum, make sure you mention your budget
As a Tutorial, you need to show and explain much more, so others can follow up your guide.
If you want this moved to a different section, you can ask the moderators to move it.
Don’t create another thread, that’s littering.
He ask me because I do electronics repairs.
Best Regards,
What Arduino do you have ?
These lights that are yellow red and green are what kind of lights ?
Where are these lights going to be mounted ?
What buzzer are you using ?
What power supply will be available ?
What switches are you using ?
Are you having an emergency stop switch ?
What kind of visual display is being used ?
Do you want to use an RTC ?
Do you know how to solder, make cabling and mount things in a chassis ?
See below for the answer to your question
What Arduino do you have ? Arduino UNO R3
These lights that are yellow red and green are what kind of lights ? Flood Lights connected via a relay
Where are these lights going to be mounted ? In the Same Cabinet
What buzzer are you using ? Horn or Similar
What power supply will be available ? 110 AC Volts for lights and Can break it down from that to supply any DC voltage that is necessary
What switches are you using ? Push Buttons
Are you having an emergency stop switch ? No
What kind of visual display is being used ? Might use 6mm LEDs because the timer has to be large enough to see from 20 Feet
Do you want to use an RTC ? yes
Do you know how to solder, make cabling and mount things in a chassis ? Yes, I am an electronics service technician with lots of experience.
Please let me know if you require any additional information.
What’s your budget ?
What kinds of things have you done with the Arduino ?
Suggest you make up your own 7 segment displays using Neopixel LED strips.
Therfore only one data out line would be needed for the display.
The strip can be made all yellow then count down to all green then made all red.
Oops.
Please remove all the unrelated material like the address, phone numbers, and corporate logo.
Thank you for your response. Please see below
What’s your budget ? It might vary for my currency budget, but USD is around 500 USD
What kinds of things have you done with the Arduino ? I am now learning, I have program some binary codes, learn how to read voltages on Arduino, led chaser lights etc. Not much but getting there.
Suggest you make up your own 7 segment displays using Neo pixel LED strips. Yes, plan to do just that.
Therefore only one data out line would be needed for the display. Yes.
https://www.youtube.com/embed/r_yobwaBWr0
The strip can be made all yellow then count down to all green then made all red. That would be perfect.
Is this better?
please STOP the advertising. This is not a place for you logo (nor personal information)
Sounds like you should be able to accomplish this.
Suggest you decide on the size of each segment in the display, hence the number of pixels needed.
Building this display and programming it, should be one of the first tasks to start with.
You need to finalize a block diagram showing the components in the project, include physical distances between each.
You need to finalize the schematics for each component block.
Ok no Problem.
Best Regards,
The size in the video is just the right size that I need. I just have to get some local to print the digit for me.
Okay, looks like you are not taking the recommendations seriously :face_with_raised_eyebrow:
Yeah! Sorry about that. It come on automatically when I send emails, So I disabled it.
See post #12
  • Always start with a block diagram then the schematics, brain storm, then order parts.
Ok thanks.
