Ardino - Button example.
I tried the Arduino button, but when compiling it, it sends me the below attached message.
Can someone help me with this?
Thanks and regards.
Arduino:1.8.1 (Windows 8.1), Tarjeta:"Arduino/Genuino Uno"
C:\Users\JUAN\Documents\Arduino\pushbottom-1\pushbottom-1.ino\pushbottom-1.ino.ino: In function 'void setup()':
pushbottom-1.ino:3: error: 'ledPin' was not declared in this scope
pinMode(ledPin, OUTPUT);
pushbottom-1.ino:5: error: 'buttonPin' was not declared in this scope
pinMode(buttonPin, INPUT);
C:\Users\JUAN\Documents\Arduino\pushbottom-1\pushbottom-1.ino\pushbottom-1.ino.ino: In function 'void loop()':
pushbottom-1.ino:10: error: 'buttonState' was not declared in this scope
buttonState = digitalRead(buttonPin);
pushbottom-1.ino:10: error: 'buttonPin' was not declared in this scope
pushbottom-1.ino:16: error: 'ledPin' was not declared in this scope
digitalWrite(ledPin, HIGH);
pushbottom-1.ino:19: error: 'ledPin' was not declared in this scope
digitalWrite(ledPin, LOW);
exit status 1
Post your code: you probably made a simple typo.
Guessing you might have declared ledpin and buttonpin with small "p" not "P"?
manor_royal:
Looking at the title I would say you're right :stuck_out_tongue:
This is the program as shown on the arduino page.
And it does not work, can you help me?
Thanks and regards
// initialize the LED pin as an output:
// initialize the pushbutton pin as an input:
// read the state of the pushbutton value:
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
// turn LED off:
On which page?
Anyway there should be something like
int ledPin = 13;
int buttonPin =2;
before the setup() on the page that you are referring to.
JUANSOSAM:
There is no such thing as the arduino page. The Arduino website has many many pages... So which one?
JUANSOSAM:
Of course it doesn't. I doubt that was the whole program... How is the IDE to know what you mean with buttonPin?
And please have a look at How to use this forum. That would have told you to use code tags and to post the code in the first place :wink:
This page?
Look again.....
You left a bit out, as sterretje predicted.
copy / paste can be difficult :wink:
OP, If you go File > Examples > Digital in the IDE you don't even need to copy & paste the code.
