Hi Morning Sir,
I want to try out this Ardublockly because it use visual programming editor for arduino and is sound good to me.
I've try it out but got that "Waiting for the IDE output...." issue?
And I also try out copy from those Arduino program which is generate out from Ardublockly side, then I use the Arduino software to upload it to my Arduino R3 and it works. So it will help me to create some project programming parts, so I wonder anybody got use these type of visual programming?
Thanks
Yeo
I have no idea. One thing might be the IDE version. Ardublockly - Embedded Log mentions IDE 1.6 and higher but it might not work with IDE 2.x; IDE 2.x is newer than Ardublockly.
The above page has some social media links that might help you to find help.
Looking at GitHub - carlosperate/ardublockly: Visual programming for Arduino. Based on blockly, implements Arduino code generation and facilitates program uploading., there does not seem to be active development for a couple of years. Looking at Issues · carlosperate/ardublockly · GitHub issues mostly don't seem to have been attended to since 2018. So it is possible that the project has been abandoned and help might be difficult to find.
Hi Sterretje,
Thanks for the info, yes I did try that IDE 1.8.19 version also the same COM issue.
But nevermind at least I still can use that "Block To Code" function and then copy it to the Arduino IDE 2.3.2 to upload it to my Arduino R3 for testing use.
And also I got see that Ardublock vs Ardublockly are they the same type of software, and did you use them before?
Oh yes I also see that Arduino PLC IDE some thing like that, is it the same using "visual blocks framework"?
Thanks
Yeo
No
No experience but I don't think that it works for "normal" boards; to my knowledge it's specific to the Arduino Opta.
Ha ok thanks Cheers!
Ardublockly is no longer maintained, but there are a lot of forks of it (like Blockly@rduino, Blocklino or Blockly4Arduino).
Maybe you would be interested in trying another block-based environment for Arduino.
After trying many of them, I personally recommend this one: aele.dc.uba.ar.
Greetings.
