Arduino 2.0 upload issue
I am currently using arduino 2.0 idle , And using to program esp32. But when i program its compiles and upload the program to full 100% but the GUI still shows "Uploading prompt" .
I cant see option to change the baudrate.
Hi @kvar_tech
The Arduino IDE developers are tracking this bug here:
If you have a GitHub account, you can subscribe to that issue to get notifications of any new developments related to this subject.
For now, the workaround is to close the Arduino IDE window and then restart the IDE in order to get it out of that stuck uploading state.
Does this problem occur always, or only after the IDE was stuck in the uploading state?
hi ptillisch,
my System is Windows 10. This problem raised today, with no windows update. But i have been upgrading and downgrading the board regularly for the project.
And the issue regarding the baud rate arrived at the similar moment.
I tried uninstalling the Arduino ide 2.0 and the problem remains the same.
the baudrate issue came when idle was stuck. i tried un installing and re installation of arduino, problem still remains the same
Thanks for the information. Even though the reporter mentioned Windows 11 specifically, there are other reports from users like you with different operating systems so I don't think it is at all specific to Windows 11. I even momentarily experienced a similar fault when doing an OTA upload on my Linux machine.
As I mentioned above, I experience this some time back while doing some uploads on my Linux machine. The problem occurred consistently for some hours, then stopped happening and I have never been able to reproduce it again despite quite some trying. The problem going away was very unfortunate for me as a beta tester, but would be welcomed by a normal user. So maybe we can hope the problem will just magically go away for you as well.
You might try restarting your computer. I don't have any specific reason to think that will solve the problem, but it can't hurt so it's worth a try.
i figured out the issue , I tried uninstalling the ide and the installing it again the. program was Successfully uploaded. But when I opened the the serial monitor , it did had issues of disappearing baudrate. and the issue continued
Thanks for the update. I'm glad the upload problem went away.
What do you mean by "disappearing"? Are there times when you see a baudrate menu at the top right corner of the Serial Monitor view?
the upload problem isn't there untili try to open serial monitor. and the problem continuous and remains there till i uninstall the software. The serial monitor doesn't appear now even after every successful install.
Then how do you explain the first screenshot you shared, in which Serial Monitor is not open?:
once the serial monitor instance is open it does not show baud rate, but can be closed.
after closing the serial monitor, the ide 2.0 gets stuck in uploading loop and never gets itself out. Even after restating the ide and again try to program it get into the loop even if i have not open the serial monitor. the upload issue gets only solved when i uninstall the ide and reinstall it again without opening the serial port.
Thanks for the clarification. That is very interesting!
I'm going to ask you to post some additional information that might help us to identify the problem.
Please do this:
  1. Start Windows "File Explorer".
  2. Open the Arduino IDE installation folder.
    (usually C:\Program Files\Arduino IDE or C:\Users\<username>\AppData\Local\Programs\Arduino IDE).
  3. In the folder listing of the Arduino IDE installation folder, hold the Shift key while clicking the right hand button on the mouse.
  4. From the context menu, click "Open PowerShell window here".
    Windows PowerShell will now open with the current directory set to the Arduino IDE installation folder.
  5. Type the following command:
    & ".\Arduino IDE"
  6. Press the Enter key.
    Debug output should now be printed to the PowerShell window as Arduino IDE starts.
  7. Wait for Arduino IDE to finish starting.
  8. Switch back to the PowerShell window.
  9. Right click on the title bar of the PowerShell window.
    This will open a context menu.
  10. Select Edit > Select All from the context menu.
    This will select all the text in the PowerShell window.
  11. Press Ctrl+C.
    This will copy the contents of the PowerShell window to the clipboard.
  12. Open a forum reply here by clicking the Reply button.
  13. Click the </> icon on the post composer toolbar.
    This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
    Code block
  14. Press Ctrl+V.
    This will paste the output into the code block.
  15. Move the cursor outside of the code block markup before you add any additional text to your reply.
  16. Click the Reply button to post the output.
Please let me know if you have any questions or problems while following those instructions.
I tried the follwing your steps, i am up with the following error:
You did forget the double quotes in step 5. You also forgot the '&' from step 5.
