Arduino 2560 Output pin voltage
Im about to do a electronics project for my apprenticeship.
We decided to use an Arduino 2560 because we will need a lot of pins. As i am not familiar with it, what is the output voltage on a pin when I set it to logic HIGH?
I think that it is 5v because the sheet says that it operates at 5 volts. I just wanted to make sure because we need to buy other parts based on the voltage the pins give us.
Yes. It will be very near to 5V when you run your Arduino on 5V.
