Arduino 6V Power Supply
Hello guys, I've got 6V power supply http://www.shopatron.com/products/productdetail/part_number=5465/135.0.1.1 and i just want to ask question how i should power the arduino, 6V is good for other circuit's but as I know it's no good for Arduino
my only solution is to get it to 5V and power arduino via USB, but should I limit the max current via the usb?
SquirrelCZECH:
6 volts is a awkward value to wire to an arduino. Wiring it to the external DC connector or Vin pin is marginally too low for the required drop out voltage for the onboard +5vdc regulator. Applying 6vdc directly to the +5v pin is right at the absolute maximum safe voltage rating for the controller chip on the board.
There is already a on-board 500ma thermofuse protecting the USB power input to the board, however +6vdc is still too high to wire directly to the USB power input. The easiest way to wire +6vdc to an arduino board is to wire a series diode between the +6vdc to the arduino 5v pin, this will drop the voltage about .6vdc and be safe to directly power the boards +5vdc bus. The cathode end of the diode would wire to the arduino 5v pin.
Lefty
Thanks, unfortunetly i do not have free diode, so i have to buy some...
1N4148 should be OK?
SquirrelCZECH:
No, that is a low current signal diode, use one of the 1N400X series of rectifier diodes, they are good for 1 amp of forward current flow.
Lefty
