Hi all,
I would like to build this small battery powered project :
In idle time only the PIR sensor is powered on. When it detects motion, it starts arduino board which run some code and when the task is finished, it cuts off the power. Only PIR sensor stay on and listen for new events.
I don't want to use deep sleep mode. Better is lower power consumption. I measured my PIR sensor current is only 0.001mA (very good) and the high output signal duration is 2.4 seconds.
What components I should use between PIR sensor and Arduino to be able to realize this project?
