I am not able to write a code in arduino which will do the following work: we have two buttons, we press the first button the amount of time that we want. Once the second button is pressed, the program should tell us how many times the first button has been pressed before.
Send those values to a textbox in visual basic.
I dont know how to do the communication between an arduino and vb, and i need help to write the arduino code.
Thank you all
Do you know how to do something if a button is pressed ?
Do you know how to add 1 to a variable ?
Serial.println(count);
Now over to you to write the VB code to receive it.
to add one to a variable i guess i am supposed to use a counter. But how to write the code for the second button. Once the second button is pressed, i should be able to know how many times the first button was pressed before.
I am not too good at arduino and visual basic. Thats the reason why i got confused with the previous answer.
Thanks for helping.
Any idea about the Vb part?
Moussou:
Thanks for helping.
Dim number as integer = 0
Try
Dim message As String = _serialPort.ReadLine()
number = Int32.Parse(message)
End Try
