I was trying to burn an sketch into an atmega328p that was on a breadboard without an external oscillator.
The guide available on http://arduino.cc/en/Tutorial/ArduinoToBreadboard#.Uwkbv5U2fNM can be simplified to do this.
It would be nice to have a section for programming the atmega328p without using the bootloader ( and without removing the microcontroller from the arduino board ). I've tested it on Arduino Board UNO R3
To do this, I do the following steps:
1.- Wire the arduino with the breadboard using the following image:
2.- Edit the Example -> Arduino ISP: Change speed from 19200 to 9600 bauds
3.- Burn the modified Arduino ISP to your Arduino Board
4.- Add to hardware/arduino/avr/boards.txt the following section:
atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
atmega328bb.upload.tool=avrdude
atmega328bb.upload.protocol=avrisp
atmega328bb.upload.maximum_size=30720
atmega328bb.upload.speed=9600 -F
atmega328bb.bootloader.low_fuses=0xE2
atmega328bb.bootloader.high_fuses=0xDA
atmega328bb.bootloader.extended_fuses=0x05
atmega328bb.bootloader.path=arduino:atmega
atmega328bb.bootloader.file=ATmegaBOOT_168_atmega328_pro_8MHz.hex
atmega328bb.bootloader.unlock_bits=0x3F
atmega328bb.bootloader.lock_bits=0x0F
atmega328bb.build.mcu=atmega328p
atmega328bb.build.f_cpu=8000000L
atmega328bb.build.core=arduino:arduino
atmega328bb.build.variant=arduino:standard
5.- Restart the IDE
6.- Select on the boards "ATmega328 on a breadboard (8 MHz internal clock)"
7.- On preferences be sure to disable verbosity on upload
8.- Press on upload
Notes:
- I've forced the burning even if the microcontroller doesn't match: ( after 9600 I added a -F )
