It's possible it's inactive I suppose. Without reading the datasheet it is hard to be sure. Your "fake" launch may prove things. The other thing would be, if possible, to hook up a scope or logic analyzer and try to see if the SCK is being pulsed at all. You would need to check you have the device configured correctly.
I am seeing nothing
The print line
Serial.println (buf);
Will not print anything (or at least nothing viewable) if for example you have low binary values in the buf array.
Just to see I'd change it to
Serial.println (buf[0], HEX);
and then maybe a loop to dump the whole thing.
for (int i = 0; i < 100; i++)
Serial.println (buf[i], HEX);
Although if the ISR is not firing of course there will be nothing useful to look at.
Rob
Thanks Rob, no joy yet, its looking like its not tramsmitting, I'll do some testing and post the results ![]()
Yep you need to verify things are working at the source then follow the data until you find where it stops.
Rob
Hi Gents, Can I just check something with you, testing tonight I noticed that when the SPI connection is plugged into the Arduino the LED marked L is flashing very faintly. Looking at the schematic this looks to be the SCK working would you agree? if so is this normal? doe sthe SCK continually send a pulse? or does thsi idicate the SPI is pumping data out were just not seeing it?
nathanBomberHarris:
... does the SCK continually send a pulse?
No it doesn't. See my logical analyzer data here:
However, it is important to note that SPI does not wait for any acknowledgement. So if you are the slave, and you are not processing the data, that's your bad luck. The master will keep sending it.
nathanBomberHarris:
... or does this indicate the SPI is pumping data out were just not seeing it?
Sounds like it is doing just that.
Sounds like either you have not configured your end as a slave, you haven't pulled SS low, or your interrupt service routine is not firing for some reason (like interrupts disabled).
Hello Nick/Rob
This is odd after studying the ARDUINO 2009 sckematic I copied the 1K resistor and LED L off the SCK PIN and did the same on my breadboard for PIN 11 boths pins flash away nicely!
I take it that this means SPI data must be traversing the connections but still no output on the seriasl monitor window????
Help! I feel its nearly there what I am I missing (PIN 10 to gnd)
Can we see the sketch for the receiving end?
Sure //note code added as suggested by Rob I tried with and without
thank you for helping
// Written by Nick Gammon
// February 2011
#include "pins_arduino.h"
char buf [100];
volatile byte pos;
volatile boolean process_it;
void setup (void)
Serial.begin (9600); // debugging
// have to send on master in, slave out
//pinMode(MISO, OUTPUT);
// turn on SPI in slave mode
SPCR |= _BV(SPE);
// get ready for an interrupt
pos = 0; // buffer empty
process_it = false;
// now turn on interrupts
SPCR |= _BV(SPIE);
} // end of setup
// SPI interrupt routine
ISR (SPI_STC_vect)
byte c = SPDR; // grab byte from SPI Data Register
// add to buffer if room
if (pos < sizeof buf)
buf [pos++] = c;
// example: newline means time to process buffer
if (c == '\n')
process_it = true;
} // end of room available
} // end of interrupt routine SPI_STC_vect
// main loop - wait for flag set in interrupt routine
void loop (void)
if (process_it)
buf [pos] = 0;
for (int i = 0; i < 100; i++)// Code added on suggestion Rob
Serial.println (buf[0],HEX); // Code added on suggestion Rob
pos = 0;
process_it = false;
} // end of flag set
} // end of loop
It helps to use the [ code ] tags (hit the # button above the post).
Anyway, you won't see anything if process_it is not true, and that hinges on getting a newline. Does the device send one?
For debugging you could change it to something like this to see if the buffer is filling up:
void loop (void)
// debugging
if (pos > 20)
for (int i = 0; i < pos; i++)
pos = 0;
} // end of loop
Nick this is GREAT as I've just discovered my none-interrupt version can't keep up with 2 bytes of transfer - it needs a gap between bytes..
So - this is GREAT but forgive my slowness- how can I SEND data from the slave - so let's say that first byte comes in under interrupts and while receiving it - I want to return some info with the second incoming byte (as SPI is bidirectional) ????
Pete
Any ideas?
hmm, another question - you're assuming constant data coming in ending in say CR.. how would one END it when the SS line goes back up...
My slave needs to accept 2 bytes - passing a byte of info back on the second incoming one - then it is done - SS line goes back up and that's when i need to know about it..
Have a function called something like spiBusy() that returns the state of the SS line , also the ISR can look at a parameter that states how many bytes to accept before setting the string ready flag (Instead of the /r/n) or whatever.
Or
Have the ISR manage a count that states how many bytes have been received and all your main loop does is wait for the right number to be received.
None of the above however deals with the zero time between bytes (IE, no empty clock cycles)
I am looking into that now
So there is no hardware flow control available to the slave. The master can use clock delay tactics to help but again, this is not the slave saying "Wait... i'm busy getting your info" so in general it would be a bad idea to tie any significant processing within the messaging loop. I guess SPI is not really geared for this type of communications, I2C has the mechanics to delay responses but not SPI.
So making the slave simply send back a status of the inverse of the sent message or something may be the best you can hope for beyond a certain speed unless the messaging it broken up into separate packets.
- Send Command
- Check Status for completion
if reading several bytes is needed then a send routine that focuses on the already prepared byte stream would be the way to go.
Many SPI devices have all this implemented in hardware and are tuned to respond within the clock cycles (SAR ADCs for instance)
The example code above where a message is sent using a /r/n as a terminator is probably not the best example of how to do an interactive SPI communications, this is probably why it is Master to Slave only. the received string is sent out the serial port once the whole message is in the buffer.
nickgammon:
That's a good question. I was wondering that too. A little research and I have an example.Hardware: Connect two Arduinos together with the following pins connected:
10 (SS), 11 (MOSI), 12 (MISO), 13 (SCK)
Also, +5v and GNDMaster (the one that sends the data) - upload this test sketch:
#include <SPI.h>
void setup (void)
// Put SCK, MOSI, SS pins into output mode
// also put SCK, MOSI into LOW state, and SS into HIGH state.
// Then put SPI hardware into Master mode and turn SPI on
SPI.begin ();
SPI.setClockDivider(SPI_CLOCK_DIV8);
} // end of setup
void loop (void)
char c;
// enable Slave Select
digitalWrite(SS, LOW); // SS is pin 10
// send test string
for (const char * p = "Hello, world!\n" ; c = *p; p++)
SPI.transfer (c);
// disable Slave Select
digitalWrite(SS, HIGH);
delay (1000); // 1 seconds delay
} // end of loop
Slave (the one that receives the data) - upload this test sketch:#include "pins_arduino.h"
char buf [100];
volatile byte pos;
void setup (void)
SPCR |= _BV(SPE);
// turn on interrupts
SPCR |= _BV(SPIE);
pos = 0;
process_it = false;
} // end of setup
ISR (SPI_STC_vect)
byte c = SPDR;
buf [pos++] = c;
if (c == '\n')
process_it = true;
void loop (void)
if (process_it)
buf [pos] = 0;
pos = 0;
process_it = false;
} // end of loop
Then fire up the serial monitor on the slave and watch "Hello, world" scroll by. Points to note: - The master divides the clock down a bit, otherwise it pushes out data too fast for the slave to process - The slave is interrupt-driven. Thus it can be doing other stuff until incoming data arrives.
Hello,
I am trying to implement this using the Metro M4 Express. When I try to compile the slave code, it errors out at the slave interrupt routine. If I comment that out, then it errors out due to SPCR not being defined. I'm kinda new at this, would someone be able to help me find a work around?
hy all.....
i try to reading data from Mcu,
that is note 3 wire : sck, din,stb
that is SPI mode?and how acan read data on that.
thanks,
gunaone:
hy all.....
that is note 3 wire : sck, din,stbthat is SPI mode?and how acan read data on that.
There are few SPI examples (Section-7.3) in the pdf of this link.
thanks so much @GolamMostofa
i was try it, and i get data :
163,0,83,0,0,3,0,0,
actualy i read data 7segment from Mcu to driver 7segment GN6932 loadscale
when i put 0.030Kg i get data :
163,32,83,0,32,3,253,221,
any idea?
Hi !
Thanks a lot for the code provided here.
I was able to set up the Arduino Uno and Arduino Mega as SPI slaves. However, I am unable to
do the same with a Arduino Nano Every. Here is the code I used:
#define MAX_BUFFER_SIZE 1024
/* Configuration Flags */
Core functions
/* Globals */
bool spiMessageToBePrinted = false;
uint8_t buf [100];
volatile byte pos = 1;
volatile boolean process_it = false;
volatile byte interruptCounter = 0;
volatile byte messageSize = 0;
bool isStringMessage = true;
Serial.begin(250000); // opens and configures the USB serial port for baudrate 115200
Serial.println("Arduino: SPI Communication setup");
// have to send on master in, *slave out*
SPCR |= _BV(SPE);
SPCR |= _BV(SPIE);
if (process_it) {
if(isStringMessage){
Serial.print((char *)buf);
else {
Serial.println("SPI: packet received");
buf [pos] = 0;
Serial.println("SPI: Received data:");
for(int i=0; i < messageSize ; i++) {
Serial.println(buf[i],DEC);
process_it = false;
pos = 0;
ISR (SPI_STC_vect) {
byte c = SPDR;
// Echo Reply
SPDR = c;
//Serial.println((char)c);
//interruptCounter ++;
if (pos < sizeof(buf)) {
buf [pos++] = c;
if ((char)buf[pos-1] == '\n' and (char)buf[pos-2] == '\r' and process_it == false) {
process_it = true;
buf[pos] = '\0';
messageSize = pos;
pos = 0;
I get the following error:
'SPCR' was not declared in this scope
I assume the Nano Every has some other architecture. Now I am wondering how to set it up as a SPI slave. I am also not sure which pin is slave select now for a slave. I just assumed it is 10, like on the Uno.
Thanks a lot in advance for any ideas how to fix this!
UPDATE: I am having a look at the datasheet of the used microprocessor:
However, I am not that familiar with low level programming. I tried to replace SPCR by CTRLA/SPIn.CRTLA, but that just yield the same error..
Okay, so I am trying to figure out the low level programming required myself,
but I think I am missing something.
I used these Arduino Nano Every schematics to map the arduino pins to the chip pinshttps://github.com/MicrochipTech/TB3215_Getting_Started_with_SPI/blob/master/ATmega4809_SPI_Examples/Receiving_Data_as_Slave/main.c
I then used following guide: https://github.com/MicrochipTech/TB3215_Getting_Started_with_SPI/blob/master/ATmega4809_SPI_Examples/Receiving_Data_as_Slave/main.c
which is based on some example document.
The default code did not work so I made some tweaks and came up with this:
Core functions
/* Globals */
uint8_t buf [100];
// pinMode(MISO, OUTPUT);
PORTE.DIR &= ~PIN0_bm; /* Set MOSI pin direction to input */
PORTE.DIR |= PIN1_bm; /* Set MISO pin direction to output */
PORTE.DIR &= ~PIN2_bm; /* Set SCK pin direction to input */
PORTB.DIR &= ~PIN1_bm; /* Set SS pin direction to input */
SPI0.CTRLA = SPI_DORD_bm /* LSB is transmitted first */
| SPI_ENABLE_bm /* Enable module */
& (~SPI_MASTER_bm); /* SPI module in Slave mode */
SPI0.INTCTRL = SPI_IE_bm; /* SPI Interrupt enable */
if (process_it) {
else {
buf [pos] = 0;
process_it = false;
pos = 0;
// NEW CODE!
ISR(SPI0_INT_vect) {
byte c = SPI0.DATA;
// Echo Reply
SPI0.DATA = c;
buf [pos++] = c;
process_it = true;
buf[pos] = '\0';
messageSize = pos;
pos = 0;
// NEW CODE!
SPI0.INTFLAGS = SPI_IF_bm; /* Clear the Interrupt flag by writing 1 */
Unfortunately, it still does not work. I will do some more testing..
Okay, so checked again that my master device works by switching the slave select line to an UNO and the master sender should definitely work..
